Old 05-19-2020, 01:12 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by DarkSunrise View Post
It's interesting that with the same tuner (Zach) on the same dyno (Racer's Line) and both running E85:
- the JDL 4-1 EL header made 209 whp
- the JDL 4-2-1 EL header made 195 whp
The shape of the torque curves are pretty similar, but the 4-1 EL header seems to hold power higher in the RPM range.
I wonder why the P-Tuning 4-1 doesnt do so well in the mid-range torque dip area. They even considered the firing order designing the pipes. It's the most well made header for this car on the market, I think, in terms of craftsmanship. Performance seems to fall a little short.
Intent > Content
Old 05-19-2020, 01:25 PM   #30
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Originally Posted by solidONE View Post
50 ft lbs of torque gained at 3800.. Torque dip making exhaust and ECM recalibration vendors money since 2012.
Such a worthwhile mod.
Absolutely. The car's behavior has changed massively and the 4-1 header really rewards winding the motor to redline. Some may want more torque down low but I love the high-revving nature of the FA20 so the 4-1 EL is perfect for my driving style.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 05-19-2020, 04:08 PM   #31
solidONE
solidONE's Avatar
nearly 160 ft lbs of torque from 3600rpm up is a lot of torque, relative to stock. Relative to most aftermarket setups, for that matter.
It's a beautiful torque curve. A very peppy one.
Intent > Content
Old 05-19-2020, 06:22 PM   #32
airrick
Drives: TRD R.S. 1.0 FRS
w
airrick is offline   Reply With Quote
Old 05-19-2020, 07:20 PM   #33
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by airrick View Post
Generally 4-1 El headers are for power at the top and4-2-1 El headers are more for the mid range. 4-1 headers are for people that are actually rev their car to redline, which i dont do, alot. And i really wanted that torque dip to go away. And it has =) most people want to look at the numbers only but best comparison is to drive them.
I think his E85 % content was higher when he tuned his car. mine was at only e55. I suspect his ethanol content was higher than mine.
Unless you have a 4-2-1 long tube header. Best of both worlds.
Old 05-19-2020, 08:02 PM   #34
tomm.brz
Drives: brz 2017 hksv2
el 4-1 still give more peak power and in generally they make the car come alive brutally after you pass 5.5k rpm
Old 05-19-2020, 08:20 PM   #35
churchx
churchx's Avatar
Drives: 2014 GT86
I'm still under impression that even on track midrange & total area under curve is more important for actual goal, to accelerate/drive faster, then higher peak number. Not just peak hp for very very narrow rpm range powerband you spend second in before upshifting. Hence good longtube 4-2-1 headers like that of Ace/JDL/Nameless seem preferable choice to 4-1 .. that actually also can be as effective theoretically, if they had similar long runners to optimize scavenging at mid-rpms, but in reality are not, due packaging reasons. It was hard to get long runners in 4-2-1 design like for Ace/Nameless .. now imagine to try to get 4 tubes as long as in those 4-2-1 .. pack not just 2 but 4 tubes before engine or where overpipe goes. Hence due limited clearance 4-1 is destined to be with short tubes, which means - optimized for very highest rpm range only, and imho that is relatively rare/specific usage case (eg. built NA engine with fixed oiling limitations and running with much higher redline) where it might be beneficial over midrange or overall gains across. Even on track. Even though it's not fault of 4-1 design itself, but simply that there is no space for long enough tubes of doubled count.
Of course in hypothetical ideal world we would have as much space under bonnet as more then half a century ago to alleviate clearance/design limitations and variable adjustable (or multipath selectable) intake and exhaust tube lengths for always to be at most optimal length (IIRC like it was done in some supercars). But otherwise it's not 4-2-1 vs 4-1, but "longtube 4-2-1" vs "short tube 4-1".
Old 05-19-2020, 08:43 PM   #36
86TOYO2k17
JDL 4-2-1 isn’t a long tube header.
Nameless still has short 4-2 runners, it has long 2-1 runners before the merge for great mid range. But needs longer 4-2 runners for top end.
ACE has long 4-2 runners, the 4-2 runner length before the merge is as long or longer than the 4-1 EL runners. Allowing for good top end and then has the scavenging and efficiency of the 2-1 step down for mid range giving you best of both worlds. The later can be adjusted by the OP design 150/250/350 allowing more mid range or more top end by adjusting those lengths. But even the 350 has good top end because of the 4-2 length and the 150 has decent mid range because of the 4-2-1 design. In my personal opinion the ace 250 is the perfect no compromise header.
Old 05-19-2020, 08:43 PM   #37
PulsarBeeerz
Drives: JRSC BRZ SOLD
Believe it or not some people still think its all marketing the torque dip isnt a thing.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
CSG Mike (05-20-2020)
Old 05-19-2020, 11:33 PM   #38
PulsarBeeerz
Same dyno but different correction factors and loads on all printouts. If dynos aren't under the same test setup you can't compare a thing..
E85 JDL UEL
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
airrick (05-20-2020), CSG Mike (05-20-2020)
Old 05-20-2020, 09:52 AM   #39
DarkSunrise
DarkSunrise's Avatar
Hmm... I wouldn't say the performance falls short, just heavily skewed towards the top-end where it is still arguably the best performing header on the market. PTuning stated one of their design goals was to minimize sweep in front of the engine to keep engine bay temps down, so they were probably limited on space for runner length (and possibly midrange power).
Yeah it sounds like you picked the right header for your driving style. Glad you're happy with it setup - it looks like it'd be a lot of fun in everyday driving.
E85 JDL UEL
I'm not a dyno expert, but OP's dyno run looked like it was using a standard 1.00 correction factor. I didn't see a correction factor listed on the @PandaBRZ dyno chart. Do you have some reason to believe it was using a large CF?
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (05-20-2020), solidONE (05-20-2020)
Old 05-27-2020, 04:03 PM   #40
PulsarBeeerz
Not larger just, different. The same dyno with SAE vs STD correction factor will give a different output. Also having a load off or on effects it as well.
Old 05-28-2020, 05:00 AM   #41
solidONE
solidONE's Avatar
Another thing about mid range vs top end. Mid range torque cost less fuel than top end power. Maybe? How would we test this? Hmm...
Intent > Content
Old 05-28-2020, 05:45 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
solidONE: imho fuel economy is not worth splitting hairs about. Technically similar energy should be spent to get upto speed, be it done slower with granny shifting (but for longer period), or faster (but for shorter period and then driving longer with more efficient higher gear). Of course less pumping and drivetrain frictional losses at higher gears at lesser engine rpms may save a bit .. but also will reduce acceleration rate/wheel torque due gearing. Simpler to just not think of fuel economy and have fun driving instead of sedate ecomiling. People pay for comfort, why not pay slight premium for fun. Same reason why i fill with 98 petrol even while manual states that cheaper 95 is ok, and why often from traffic lights shift 1-2-5 or 1-2-6 .
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust pinski Software Tuning 8 11-21-2016 11:07 AM
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
