05-09-2020, 09:10 PM | #21869 | |
Drives: 2020 Toyota 86 GT 6M
I took it super slow but I am also quite OCD. I chose to tuck all of the cables up in the roof liner rather than have some parts up in the liner while other parts under the rubber trim. Some pointers for the install: - For the A-piller, it would be a good idea to pop it off and let it loosely hand from the securing clip that keeps the trim attached to the a piller in the event the curtain airbags deploy. I made sure to route the cables behind all the curtain air bag stuff so there is no chance of the cables interfering with the air bag deployment if the cable somehow went across and over the air bags as the cable ran downwards - You may find it easier to remove the sun visor on the side you plan on tucking the table to give the roof liner a bit more play. Unscrew the 2 screws. The plastic clip for the visor detaches by inserting a flathead on the gap on either sides of the clip to release the claw. Simply pulling will break this clip - Running the cables in the headliner across the top of the door frame is straight forward, there is lots of play in the hoodliner to allow you to just tuck the cables in with your fingers - Across the top of the B piller becomes tricky. if you are lazy, you can tuck a bit of the cable under the B-piller trim and call it a day. If you are OCD and want everything under the roof liner, the B-piller trim has 2 clips that extend inwards to hold the roof liner in place. You will not be able to tuck everything under the roof liner because of these 2 clips and the roof liner will rip if you try forcing it down to tuck the cables. What you need to do is partially pop the the quarter panel interior trim below the b-piller trim (this will undo 3 white christmas tree clips). This will give you enough room to stick your hand in with a 10mm socket to remove the 2 bolts holding the b-piller trim to the frame. By removing these 2 bolts, the b-piller trim can be partially popped off and shifted down a bit to allow the roof liner enough play to use a trim tool to tuck the cables under the liner. -Routing the cable from the b-piller around to the rear windshield you will run into the same inward clips on the c piller that will stop you from shoving the cables in with your fingers. undo the claws at the bottom of the c-piller trim to allow you to partially pop the trim pieces off so you can get it to partially pop off enough for some more play in the head liner. - You will also want to pop the 3 round clips holding the headliner in place to allow you lots of room tucking the cable above the rear windshield under the roof liner - Some videos suggest the c-piller has lots of room to tuck in excess wire (and you WILL have TONS of excess! I only used half the length of the included cable to connect the front camera to the rear) I do not recommend blindly shoving excess cable into the c-piller due to the presence of the curtain airbags under the panel. Fortunately, you have tons of room under the roof liner in the rear. once you get past the c-piller you can just tuck all the excess stuff you have under the roof liner. Last edited by saltywetman; 05-10-2020 at 03:27 AM. |
The Following 5 Users Say Thank You to saltywetman For This Useful Post: | Compelica (05-10-2020), humfrz (05-10-2020), ichitaka05 (05-10-2020), MJones_RB (05-11-2020), squall leonhart (05-10-2020) |
05-09-2020, 09:38 PM | #21870 | |
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | DarkSunrise (05-09-2020), Overdrive (05-09-2020) |
05-09-2020, 10:32 PM | #21871 | |
Sittin' Sideways
Drives: 2016 Toyota FR-S
-O/D
2016 FR-S, Hot Lava |
The Following User Says Thank You to Overdrive For This Useful Post: | squall leonhart (05-10-2020) |
05-10-2020, 02:28 AM | #21872 | |
The Following User Says Thank You to humfrz For This Useful Post: | saltywetman (05-10-2020) |
05-10-2020, 07:51 AM | #21874 | |
kuro kitsune
Drives: 2002 Toyota Celica GT-S
Just a tad jealous here! 99.5% of the roads here are just straight, flat grid lines surrounded by cornfields. Very nice
2002 Toyota Celica GT-S - 6 speed manual
2006 Scion xA - 4 speed automatic 2013 Scion FR-S - 6 speed manual (sold) |
The Following User Says Thank You to squall leonhart For This Useful Post: | DarkSunrise (05-10-2020) |
05-10-2020, 09:55 AM | #21875 |
Thanks! Yeah definitely lucky to have some nice driving roads around here.
2022 BRZ Build 2013 FR-S Build |
05-10-2020, 11:31 AM | #21876 | |
Site Moderator
Drives: ichi 86 Project
Blackboxmycar sells a kit that can hardwire, so I'm using those as to hardwire. |
05-10-2020, 01:36 PM | #21877 | |
Drives: 86 GT
I'm OCD too when it comes to these things, which could be a really bad thing at times. I'm thinking of going the hardwire route as well, but that means I would need to get the larger fuse box 3D printed to fit the fuse addon which leads to additional work. And here's hoping those wires don't make any more unwanted sounds that I don't need! |
05-10-2020, 03:55 PM | #21878 | ||
Decided to go the external battery pack as it was only very slightly more than a new yellow top. Went with the Cellink Neo battery as it was a tad cheaper than the blackvue one (apparently the internal cells were the same according to dashcamtalk forum). The external battery packs require a hardwire kit if you want to minimize excess wiring as well. I'm a bit undecided on whether I will use the cigarette lighter in the glove compartment to plug in the battery pack while keeping the pack there (easier install but slower charging) or hardwire the battery pack to the the fuse box. There was someone in an old post that mentioned someone making an adapter hat utilizes the unused extra plug on the headunit harness that has a 12v constant/12v acc/ and ground wires all in it. This option may also by pass the need to use fuse taps and the non-fitting OEM fusecover problem too. Not sure if that guy still makes these adapters as the post is quite old. Quote:
Doing it the quick and lazy way without partially removal trim, you can tuck some of the cable under the rubber door seals then into the grooves of top of the b-piller but because of those 2 small clips at the top, you will still have tiny bits of the cable showing at the locations of the clips since the grooves are much shallower there. Same goes for the sections of the c-piller trim with those clips https://demos.starbase7.net/t3Portal..._rm_index.html The repair manual gives you a good idea of where the clips are located under the trim panels to help you with partially removing them to give you more play in the head liner. A lot of those steps will be overkill so you just want to look at the pictures for reference on where the clips are located so you can work certain areas free without risk of breaking them by blindly trying to pop the trim off |
The Following 3 Users Say Thank You to saltywetman For This Useful Post: |
05-11-2020, 12:52 PM | #21879 |
Drives: 17 Asphalt 86
Ordered some new pads, away bar end links and new brake hardware.
This also arrived and I forgot they use an 86 on the can. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | tintumz22 (05-11-2020), Ultramaroon (05-11-2020) |
05-11-2020, 04:49 PM | #21880 |
Wheels for Brains
Wired up the JDM Reverse Light /w Fog Lamp ("fourth brake light") through the cabin and fuse tapped it into the front fog lights for full switching functionality
05-12-2020, 10:50 AM | #21881 |
That isn't tar behind the wheels though. That is melted rubber from the shear power of the car. Happens to me all the time.
The Following User Says Thank You to Tcoat For This Useful Post: | tarzan_nojane (05-12-2020) |
05-12-2020, 11:15 AM | #21882 | |
Side note, all of my delayed orders have decided to all arrive within two days. Caliper paint took the longest which is odd since they're Canadian based. |
The Following User Says Thank You to RToyo86 For This Useful Post: | Tcoat (05-12-2020) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
