Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-06-2020, 11:01 PM | #1 |
Drives: Subaru BRZ S 2013
Age old Oil Cooler Kit question
Gday all,
First time poster so not 100% sure where this thread should be. However, i'm looking to purchase an oil cooler kit for my 2013 BRZ, and am planning on going FI in the near future. I have been searching all over these forums and am yet to find a definitive answer for my question which is: What is the main difference between all these oil cooling kits (HKS, Mishimoto/Greddy/Setrab), and should i purchase one with a bigger radiator if i am planning on going FI. I live in Australia where the air temps vary from 45C to -2C during the year. Any constructive information would be great. Cheers |
05-06-2020, 11:08 PM | #2 |
Drives: 2017 Toyota 86
Quality, durability, construction, and mounting location are all differences off the top of my head. If you plan on FI, try to decide what kit you’re going to use so that you make sure to choose a compatible oil cooler in terms of fitment. CSG and other reputable vendors (not to mention experienced forum members) can give you specific advice.
05-06-2020, 11:15 PM | #3 |
Thanks mate, basically exactly what i was looking for.
05-06-2020, 11:24 PM | #4 |
Drives: jrsc_brz
yeah, i second emailing csg, or talking to them on here. i get stuff from their shop, and their advise/tips/tricks is invaluable, this is their ask-o-rama thread: https://www.ft86club.com/forums/showthread.php?t=38926
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
The Following User Says Thank You to HaXx For This Useful Post: | Spuds (05-08-2020) |
05-07-2020, 11:42 AM | #5 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Do you plan to track the car? And what FI kit were you going with? If you arent tracking it, I'd suggest going with the Forester XT set up or the Jackson Racing dual oil cooler radiator.
05-07-2020, 12:11 PM | #6 |
Rust bucket enthusiast
If you know it's an age old question, you've done enough research and should be able to answer this on your own
The Following User Says Thank You to DarkPira7e For This Useful Post: | Wally86 (05-07-2020) |
05-07-2020, 12:49 PM | #7 | |
Be Kind
Drives: 2020 86
Sometimes you do a ton of research and miss something. It happens. It's nice to be reassured by those who live, eat, and breathe it.
05-08-2020, 02:10 AM | #8 |
Drives: 2017 toyota 86
There is nothing really proprietary about an oil cooler. Most companies just piece it together add a mounting method slap on their brand and charge you the premium.
JR dual radiator is the only really unique one but also the most expensive. It’s simple and doesn’t add more stacks though. Forestor xt heat exchanger also unique and cheap but at least effective. DIY and mount behind fog light bezel, open bezel for airflow. Surprisingly easy and much cheaper to DIY and be able to mount anywhere of your choosing really. |
05-08-2020, 08:42 AM | #9 |
Before you go with an oil cooler decide on what FI you are going with. Then buy an oil cooler that will be compatible with it.
05-16-2020, 12:52 AM | #10 |
Drives: 2014 Scion FRS (Asphalt)
On top of fitment, you should consider how much cooling you actually need. Each of those kits have different cores and your cooling will reflect that.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Similar Threads | ||||
Forrester oil cooler with oil to air cooler question ? | sroby | Engine, Exhaust, Transmission | 20 | 08-01-2019 09:49 AM |
Oil cooler question | Qwimby1 | Engine, Exhaust, Transmission | 16 | 04-20-2018 12:08 AM |
Oil Cooler Line Question | Dezoris | Engine, Exhaust, Transmission | 18 | 11-08-2016 06:02 AM |
Technical question about oil cooler | solma | Engine, Exhaust, Transmission | 5 | 05-27-2013 08:54 AM |
Question about Greddy oil cooler | Captain Snooze | Engine, Exhaust, Transmission | 3 | 09-10-2012 03:40 AM |
