Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 02-13-2019, 08:27 PM   #1
littlenaha
Drives: scion frs
Valenti 4th brake light
Hey guys so recently I bought a Valenti 4th brake light for my 2016 Scion Frs. and had installed it, but the original light harness only has 2 pins in it. The far right and left pins and the third middle pin is not there. I looked on YouTube and found some videos but they talked about wire taps and a spare red wire that supposedly came with it but i never got anything. thought it was plug and play but I guess not. need to know what wire from the harness supplies power to tail lights
littlenaha is offline   Reply With Quote
Old 02-14-2019, 01:59 AM   #2
gpvecchi
gpvecchi's Avatar
Drives: Toyota GT86 MY19
Do you have a rear fog light? Stock wiring has fog light, rear light and ground. Valenti has the 3 wires plus a red wire for brake.
Old 02-14-2019, 12:19 PM   #3
wolffbite
Too tall for the twins
wolffbite's Avatar
Drives: 2017 DGM BRZ MT
Can you post a pic of the unit + wiring harness it came with?
There are several "Valenti Style" 4th brake lights out there with different wiring instructions. Knowing exactly what you have would help us help you.
None of them are truly plug and play because of wiring differences between USDM, JDM and European models. Your north american car will not have a separate wire for rear fogs as we don't have those since the stock reverse light just has a red reflector and no bulb in the center.
I'm assuming when you plug in the the new light with harness as is you only get working reverse lights?
wolffbite is online now   Reply With Quote
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 43 06-03-2018 11:52 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
FS: Valenti RED Tails. Valenti RED 3rd Brake Light. OEM Clear Corners. AngryS13 Exterior Parts (Aero, Lighting, Etc.) 6 08-14-2016 11:35 AM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 05:48 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 07:51 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
