Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-06-2016, 03:57 PM | #71 |
Drives: Crystal Black BRZ(Sophia)
12-17-2016, 06:46 AM | #72 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Ergo.. the Supra is likely gonna cost more than I'd be prepared (or able!?) to spend!
I like driving!
12-22-2016, 01:48 PM | #73 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Again all based on context and how you will drive the car honestly. I personally went with the Edelbrock due to more low end torque and "fun" at lower speeds. From what i keep hearing is that the Jackson basically drives like stock until 5k RPM and then it's like a rocket.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
12-22-2016, 01:55 PM | #74 | |
Drives: Subaru BRZ / Toyota 86 Experts
12-22-2016, 02:26 PM | #75 | |
Lowly Cartuber
Yeah. My point was that it's all based on context. Technically you could say a stock NA engine runs hotter than an edelbrock kit but without context that statement is irrelevant. Sent from my iPhone using Tapatalk
12-22-2016, 02:52 PM | #76 |
Drives: 22RE, FA20, 4G63
The good/bad old issue with intake temp. You could set a centrifugal supercharger hotter than a positive displacement supercharger or it could be made the complete opposite but you should have a goal before the build.
Everyone knows that heat increase with pressure and that it apply to compressing air, so that been said the PD and centri SC differ on how they generate heat and how they dissipate heat. The PD should be big enough (enough for what? Put your goal in here _____. So it could be use at the low-mid range of recommended rpms of the SC (to avoid heat soak). The centri in the other hand should be use at the mid-high rpms (to get good use of the compressor). Sent from my iPhone using Tapatalk |
Similar Threads | ||||
Forced Induction Comparison (twin-scroll/centrifugal/turbo) | SillySaxon | Forced Induction | 6 | 09-22-2014 11:59 AM |
Centrifugal or Twin-scroll? What Ever You Choose FR SPORT Has it for Your ZN6 Car! | FRSport.com | Forced Induction | 0 | 09-27-2013 08:15 PM |
Most reliable F/I kit? | official_george | Forced Induction | 103 | 05-14-2013 12:00 PM |
roots vs centrifugal superchargers | slaxx | Forced Induction | 15 | 04-09-2013 11:04 AM |
Centrifugal vs Positive Displacement SC | EN2_Squirrel | Forced Induction | 38 | 11-01-2012 11:58 AM |
