Old 10-06-2012, 06:06 PM   #29
dura1198
dura1198's Avatar
Drives: 2015 WRX
Under magnification, yeah I have issues, it looks more like rust than bug but next week I'll back into my spot and see what happens. For me it's only 2 very small spots on the bumper. Really not a huge issue, I'm more curious than anything.
dura1198 is offline   Reply With Quote
Old 10-08-2012, 03:51 PM   #30
jdub512
jdub512's Avatar
Drives: Whiteout SCION FR-S
I have the same issue with my Whiteout FRS. I have this yellow spot on the front bumper just above the grill that I am unable to buff out with wax after repeated washings. Weird. I'm also parked out in the sun for about 8 hrs a day in the Texas sun. I am also curious as to where this stain came from and how to remove!
jdub512 is offline   Reply With Quote
Old 10-13-2012, 09:39 PM   #31
RowTarEEE
Drives: Mazda RX-8 MT, Scion FR-S MT
I too am getting these stains on my whiteout frs. It even leaves a yellow bump as if someone tried to touch up a rock chip, but it's with this yellow tar. Any solutions? The leave your car out in the sun solution worked on the smoother spots
RowTarEEE is offline   Reply With Quote
Old 10-13-2012, 11:17 PM   #32
Paul_S
Drives: red
If it is rail dust or other industrial fallout then claying is the first step. When that fails then a decon product is required. Iron-x and other brands mentioned on this forum will all do the job. The problem relying on clay is that clay shears off the above surface portion of the contaminate leaving the below surface part to re-appear.
Paul_S is offline   Reply With Quote
The Following User Says Thank You to Paul_S For This Useful Post:
SVThis (10-17-2012)
Old 10-20-2012, 11:41 PM   #33
Silverback
White Lighting
Silverback's Avatar
Drives: WHITE LIGHTING
Damn it I have this issue on my whiteout! Help!
Silverback is offline   Reply With Quote
Old 10-20-2012, 11:58 PM   #34
Paul_S
Drives: red
Time to get rid of the problem with Iron-X or like product.
Old 10-22-2012, 05:52 PM   #35
Silverback
White Lighting
Silverback's Avatar
I bought the Iron X on amazonian...I'll report back.
from the comments I think using a hairdryer on low might work. It seems like it's tar like in feel and the heat might loosing it up. Tried my tar and bug remover and it didn't work.
Old 10-22-2012, 06:01 PM   #36
cantaloupe
Drives: brz
I have it too on my white brz. Can't get rid of it, but haven't tried clay or iron x yet. It feels like it's under the paint though since it's silky smooth.
cantaloupe is offline   Reply With Quote
Old 10-23-2012, 07:40 AM   #37
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Bug poop. I get the same thing. They eventually go away and more come back in its place. I have my car optiguarded so it's not as bad as it could be.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 10-24-2012, 03:50 AM   #38
einzlr
Drives: several
Let us know how that goes. My guess actually is the sun trick works not so much because of the heat but rather because UV rays break stuff down.
If you are able to get the car clean, then keeping it well waxed helps a lot against all manner of crud because stuff adheres less in the first place and what does stick is on/in the wax and not the paint.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 10-30-2012, 09:12 PM   #39
SVThis
SVThis's Avatar
Drives: Scion FRS
I just picked up my whiteout last week. It had a few yellow spots on the rear bumper also. It definitely wasn't rail dust. Clay bar took it right off. The dealer never touched it before I took delivery. Smartest thing I ever did. No polishing needed as the paint was perfect with no marring.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 10-31-2012, 05:01 PM   #40
GMT
GMT's Avatar
Drives: 2013 Scion FR-S 6MT Asphalt
Has anyone tried exposing the spots to UV lights?
- and yet, it moves! ... Galileo
GMT is offline   Reply With Quote
Old 03-03-2013, 03:50 AM   #41
trinitron
Drives: gts 86
Originally Posted by MattR View Post
This is going to sound ridiculous, but the "leave it out in the sun" trick actually worked!
The smaller dots are completely gone, and the larger ones are reduced and/or faded. I will have the car out tomorrow as well, so hopefully the remainder of the dots will fade out too.
Weirdest stain I've ever encountered.
How long did you leave it in the sun for? After washing off the pollen, it left the same yellow stains Left it in the sun for good 2-3 hours and for the most part, it's still there. Not sure if it became lighter or not. Guessing its a gradual thing ?
trinitron is offline   Reply With Quote
Old 03-03-2013, 07:13 AM   #42
whaap
whaap's Avatar
If getting the car to you involved it being transported on a train it is very likely rail rust. The fine particles of dust caused by the brakes on a train will get on any and all cars transported on an open rail road car. It's just that it's not noticeable on most cars but very noticeable on white cars after the dust has been exposed to the elements and turns to rust. Dealerships are very knowledgeable of this and have a chemical wash they can use to remove it. The wash does not harm the paint of any exposed parts.
whaap is offline   Reply With Quote
Search this Thread:
Advanced Search
Water Spots MATTrocity Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 09-02-2012 01:37 AM
Hard water spots Double4Free Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-01-2012 10:14 AM
GTA Meeting Spots Brainstorm Dragon86 CANADA 33 06-20-2012 09:22 PM
Jack Spots? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-11-2012 09:09 AM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 03:17 PM
