#85 | |
The combination of surface area and airflow is what results in heat dissipation, and they work somewhat manipulatively. |
#86 |
NASA SpecE30 Racer
You can work on the adjustments of that pipe and have it not sit on the radiator hose. Mine was pretty close, but it wasn't touching it.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#87 |
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I have to agree with King Tut. I don't think it is just a fan issue. I think it's the radiant heat that is getting stuck in the engine bay. A better fan would assist a little though when boosting on curvy roads while not actually getting the speeds as high.
@King Tut the cowel that you were talking about is that the plastic piece below the windshield wipers? |
#88 | |
NASA SpecE30 Racer
- King Tut
#89 |
I think I have to raise up the FMIC and the bumper a little still. I made the adjustments like the build told me to but I don't think it was high enough. maybe raising the whole thing up 1/2 an inch might allow for the pipe to be raised a little as well.
#90 | |
NASA SpecE30 Racer
- King Tut
#91 | |
#92 | |
NASA SpecE30 Racer
Found it:
- King Tut
#93 | |
Drives: Scion FR-S
#94 |
Have you guys played with aftermarket fans at all? Pressure is the important factor here. It'll mitigate most of the losses of stacking. You can also change the positioning of the FMIC a bit as well.
With the given restrictions, we're looking at something like a 5x increase in airflow with the fan. This also promotes airflow OUT of the engine bay via the outlets in the rear/bottom... Just sayin', cuz this has worked for us. Oh, and uh... we've melted (stock) fans that were in proximity to hot turbos/piping before... |
#95 |
Drives: Blue Subarus
I need to try something before my next track day. Very interested in someone showing that the fans make a difference. The clearance between the turbo/downpipe worries me as well seeing how little room there is for anything bigger than the slim fans.
@King Tut - nice find on the VCMC car. I need to see how much I can easily take off around that area.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#96 |
Drives: Hydra EMS Powered FRS Raven Black
I never had any issues on the street or on the dyno in terms of operating temps. Max power 400whp (baseline 153 whp).
Element Tuning Hydra EMS FA20Club 60T turbo kit (header wrap and turbo cover) Full Blown Radiator (oem fans and shroud) 90% water and water wetter AC condenser in place E85 Ok so when I was NA and racing even with oem radiator I never had issues even in 90+ f. In boosted trim we did have problems but they may have been mostly due to a pin hole leak in the radiator. When I first raced my boosted setup at NJMP at around 350whp I can say I had real issues but it did get warm but nothing dangerous. At the next two races we overheated into the red on every session and that's when we got desperate. ![]() Most of it's common sense and the grill opening is very smal almost every inch covered by the FMIC, and the engine bay pretty sealed up. We also have an extended diffuser. We ditched the skid plate which gave us more exit volume. We cut a hole in the hood and added a gurney. We also cut holes in the bumper skin above the bumper beam (they needed to be bigger but that's what we had at the track). We also pulled the rubber seal at the wiper tray. All of this helped but one thing hurt us at one point and that was a cut through fendet liner. Do not underestimate how much pressure that will pump into your engine bay. Fix it or make new liners for bigger wheels etc. In the end we found a pinhole leak in the radiator that only surfaced under racing conditions. At the track fix was "stop leak" and it appeared to have settled engine temp but then boom and she caught on fire as most know. From my experience with cooling issues like this in general, the rad volume is just too little for 400+hp under racing conditions and their is too little entry volume of airflow. To improve flow you have to dump pressure out of the hood. Get more air to the radiator and you may have to cut bumper vents (you can do it nicer than I did). For fans its hard to beat the oem and shrouding for street and I bet for many your slim fans are worse (seen it many times). To run slim you need a shroud and you need some high dollar, super high cfm units, to do the trick. Nothing off the shelf will do the trick for what we have planned for our FRS next season. Thanks, Phil Grabow |
#97 |
E85 runs considerably cooler than pump gas, that's probably why you've never had an issue. I'm going to try a different fan setup and if I can find a decent one a vented hood.
#98 |
Drives: 2013
ducting is key, keep air moving though the radiator, not around it. Get creative.
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
