Old 10-20-2022, 07:54 PM   #743
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by FrickingReallySlow View Post
Does this update also include the edelbrock SC tunes ?
Yes.
Old 10-20-2022, 07:55 PM   #744
DeliciousTuning
Originally Posted by Grady View Post
Is there a price difference for upgrade vs new purchase?
Depends on the version you are on and when was the last time we did an update on the tune. Reach out to sales@delicioustuning.com for more info.
Old 10-20-2022, 07:56 PM   #745
DeliciousTuning
Originally Posted by Mad1723 View Post
@DeliciousTuning Can I upgrade a remote tune to 33.5 even if remote tuning isn't offered anymore? I've had so many issues with idle on my Edelbrock, I'd like to test those idle improvements
Usually remote tuning is not needed anymore, unless you have a customized setup. But you can reach out to sales@delicioustuning.com for more information, as we do not check here to often.
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Mad1723 (10-23-2022)
Old 02-27-2023, 06:10 PM   #746
DeliciousTuning
Updates: Flash & Go and All FI application tunes.
We have made quite a few changes (see list below) to our latest version of the Flash & Go tune which will also include, Edelbrock, Harrop, Innovate, and Jackson supercharger kits.
Please note: we seem to have found a small bug within the latest (and previous versions), while on speed density only, that in certain conditions (warm engine, not hot, not cold) on some 86's (does not affect all vehicles), the vehicle will start and die. This is something we have been reviewing with EcuTek and a few cars that have the issue. Otherwise the idle control should be a bit more stable now when running 100% Speed Density, with a lot less likely chance of receiving a high idle code as in previous versions of the tune.
Latest revisions offered by Delicious Tuning:
Flash & Go (all forced induction applications) Version 33.50
- 100% Speed Density Enabled
- Low speed acceleration from a dead stop.
- Low speed stock throttle, with Race Throttle or higher speeds.
- Improved Direct (mid RPM range) and Port Angle injection (low speeds)
- Improved CAM Angles (better top end power)
- Better tip in response for Speed Density
- Improved off throttle burble (add-on)
- Improved Flex Fuel (Ethanol) performance output
- Improved Idle Control for more applications
- Improved Mid Throttle / Mid RPM response and AFR ratios/targets
- More Details: Click Here
Regards,
William Knose
Old 04-01-2023, 10:25 PM   #747
stacyu18
Drives: 2014 subaru brz
nice
works like a charm
stacyu18 is offline   Reply With Quote
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
