Old 05-23-2020, 12:19 PM   #29
Semiihcircle
Drives: 17 BRZ
So i decided to redesign and make my own brackets if anyone is interested, so i can use whatever endlinks i want to
Sent from my SM-G973U1 using Tapatalk
Semiihcircle is offline   Reply With Quote
The Following 4 Users Say Thank You to Semiihcircle For This Useful Post:
Adamf220 (03-23-2021), DarkPira7e (06-27-2020), glhs386 (06-27-2020), Opie (03-08-2022)
Old 06-27-2020, 08:05 AM   #30
new2subaru
Weight Weenie
Drives: 15 FR-S
Let's see them
The Following User Says Thank You to new2subaru For This Useful Post:
Old 12-25-2020, 11:42 PM   #31
Adamf220
Drives: 2013 frs
So has anyone solved this issue? Finally broke my endlink mount on my last track day of the year. Ive seen someone drill a hole in the lower control arm and mount the endlink to that. Seems like a good idea but if anyone has any insight into this it would be greatly appreciated.
Adamf220 is offline   Reply With Quote
Old 12-26-2020, 12:00 AM   #32
jflogerzi
jflogerzi's Avatar
Is this just as issue with the onlins dampers?
2013 Series 10 FRS #553
Old 12-26-2020, 01:23 AM   #33
Adamf220
Drives: 2013 frs
From my research it seems other coilovers have similar issues with contacting the strut body, inner wheel well, and lower control arm. The ohlins have a large lower strut mount exasperating the issue and putting stress on a cast aluminum endlink mount which results in the mount snapping in two. What I think is a good solution is to drill a hole in the lower control arm to mount the end link which is how the wrx/sti sway bar is mounted but it has a dedicated mount and is on the front side of the control arm. The issue is finding a adjustable endlink that is very short with 14mm ball joints. Also probably will need to reinforce the mounting point on the lower control arm. This will be my winter project since my car is parked for the next few months.
Old 01-15-2021, 11:58 AM   #34
RayRay88
Drives: 2017 86 860 Special Edition
Is this just happening with aftermarket sway bars or with OEM stuff too?
RayRay88 is offline   Reply With Quote
Old 01-18-2021, 10:11 AM   #35
Adamf220
Drives: 2013 frs
Ohlins claims that it doesnt happen with the stock sway bar. I have my doubts, i am using the trd sway bars but i am sure they are made by eibach.
Old 01-18-2021, 09:37 PM   #36
jflogerzi
jflogerzi's Avatar
I need to keep an eye on this. I have whiteline 20mm front sway bar on the stiff settings, whiteline end links and stock dampers on rce yellows.
Old 01-19-2021, 09:34 AM   #37
Adamf220
Drives: 2013 frs
Unless you have ohlins I think you will be fine.
Old 03-22-2021, 04:49 PM   #38
RayRay88
Just bringing this back from the dead.
OEM anti-roll bars
Ohlins R&T
Looking for adjustable endlink suggestions that will not cause contact/isssues.
Brian from Ohlins USA was adamant about only using OEM endlinks cut to length.
Anyone else have contact issues with stock bars/adjustable end links and Ohlins?
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 03-22-2021, 05:59 PM   #39
PLX92
PLX92's Avatar
Drives: 2017 BRZ Premium
Eibach links looks to be pretty slim: AK41-82-043-01-20
I may give these a try, I currently run Ohlins Mi20's with a 24mm whiteline front bar and their adjustable endlinks, it does contact at full lock.
Edit: Cusco's also look very slim
PLX92 is offline   Reply With Quote
Old 03-23-2021, 12:54 AM   #40
RayRay88
Still look thicker than Hotchkis unless someone can confirm otherwise. I haven’t been able to find anything that comes close to as thin as the hotchkis end links but I’m really going off of pictures so I don’t know how accurate that is.
Old 03-23-2021, 01:10 AM   #41
strat61caster
strat61caster's Avatar
Racer X
ineedyourdiddly
Old 03-23-2021, 01:28 AM   #42
RayRay88
Racer X
VS
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
strat61caster (03-23-2021), Tatsu333 (10-21-2021)
Eibach front and rear sway bars MST Engineer Brakes, Suspension, Chassis 3 05-23-2017 12:22 PM
Eibach 29/19mm sway bars Whitel Brakes, Suspension, Chassis 5 01-19-2017 06:17 AM
WTB: Eibach Front and Rear Sway Bars RavioliG Want-To-Buy Requests 2 11-11-2014 01:44 AM
Eibach Front and rear sway bars Review *KID* Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-29-2013 04:14 PM
Eibach Sway bars ON SALE NOW!!! Accurate Race Shop Brakes, Suspension, Chassis 27 11-12-2013 09:51 PM
