Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-02-2021, 05:50 AM | #1 |
Drives: 2020 toyota 86
Clutch Fluid
What is everyone using??
05-02-2021, 09:37 AM | #2 |
Drives: '13 Whiteout
Motul
05-02-2021, 10:01 AM | #3 |
Rust bucket enthusiast
Parts store brake fluid DOT3+
05-02-2021, 01:29 PM | #4 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
yup, cheap DOT3 fluid. It's less hygroscopic and it doesn't have to put up with a lot of heat, so no reason for expensive fluid.
The Following User Says Thank You to B T For This Useful Post: | ermax (05-03-2021) |
05-02-2021, 02:05 PM | #5 |
ProCrastinationConsultant
brake fluid.
The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
05-03-2021, 09:29 AM | #6 |
Drives: 2018 Subaru BRZ
Never has my avatar made more sense for me than this moment, I've had my car for a year and been driving manual for years and never knew my car had a clutch reservoir or that you needed to replace for that matter. I'm a fckn noob.
The Following 2 Users Say Thank You to spcmafia For This Useful Post: | Tcoat (05-04-2021), Ultramaroon (05-03-2021) |
05-03-2021, 05:46 PM | #7 |
Whatever brake fluid is left from a bleed.
05-03-2021, 06:04 PM | #8 |
義理チョコ
Wait... it's not just piss?
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (05-03-2021) |
05-03-2021, 07:02 PM | #9 | |
No real need to replace unless it’s full of deteriorated rubber and in that case you probably have a bad master cylinder which requires you to open the system to replace which means you have to bleed the system which means you will be swapping most of it anyways so you may as well flush it all out while you are at it. Is that a run on sentence? |
The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (05-03-2021) |
05-03-2021, 07:34 PM | #10 |
Drives: 2017 PP BRZ
Valvoline Dot 3 & 4 Brake Fluid.
The Following User Says Thank You to scion fr-s For This Useful Post: | ls1ac (05-04-2021) |
05-03-2021, 08:38 PM | #11 |
i just try to follow the recommended service intervals. the manual says to replace the brake fluid at 30k, so i replaced both from the same bottle..
05-03-2021, 10:25 PM | #12 |
I changed mine out with Prestone DOT4 at around the 8 year mark. Came out dirty but no appreciable difference in feel.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | soundman98 (05-03-2021) |
05-04-2021, 05:41 AM | #13 |
Thanks to all that responded.
05-04-2021, 12:15 PM | #14 |
Drives: '23 BRZ
FWIW I occasionally use a syringe to empty the clutch reservoir and fill with fresh DOT4 when I bleed brakes. Figure over time I'm effectively refreshing the fluid without actually having to bleed the clutch...
The Following User Says Thank You to ZDan For This Useful Post: | soundman98 (05-04-2021) |
Similar Threads | ||||
What brake fluid do you use when bleeding/flushing the clutch? | MINOCIN | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 08-24-2020 12:07 PM |
Brake and Clutch fluid questions | ducky106 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 03-04-2019 08:58 AM |
Clutch fluid won't bleed. | ML | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-19-2018 08:35 AM |
Clutch Fluid Flush? Pls Hlp | Keenercarguy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-19-2016 03:26 AM |
Clutch system/MC fluid capacity? | ZionsWrath | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 07-08-2014 08:40 PM |
