08-10-2020, 12:38 PM | #10921 | |
Drives: Hot lava FRS Monogram Charizard
Sent from my GM1915 using Tapatalk |
08-10-2020, 12:39 PM | #10922 |
Drives: FR-S,GTI
No no
I'm talking about ambient air temp not IAT. The temp as displayed on the dash gauge. You know, the difference between if it's hot or cold outside. |
08-10-2020, 12:41 PM | #10923 | |
08-10-2020, 12:43 PM | #10924 | |
Drives: FR-S,GTI
I'm talking about ambient air temp. The temp as displayed on the dash gauge. You know, the difference between if the weather is hot or cold outside. |
08-10-2020, 12:45 PM | #10925 |
Drives: FR-S,GTI
I don't know what happened!
Double posted! |
08-10-2020, 01:38 PM | #10926 | |
Drives: 2017 toyota 86
All these people talking about IAT are really referring to ambient pre blower air, this is completely different than your IAT temp that is located and reading being post blower. For all him or anyone knows there post blower IATs are the same as yours or possibly even worse. Pre blower temps will have a bigger impact on performance compared to post blower IAT temps. So not a good comparison. |
08-10-2020, 01:50 PM | #10927 | |
Ambient temps or pre blower MAF IAT temps which are usually pretty similar to each other (unless MAF is relocated post blower like his is to get a real IAT reading) will have a much bigger difference on performance, compared to post blower "real" IAT temps going into the engine vs ambient (what he is inquiring about) The question is people who are boosted, what are their before blower (typically at or near ambient) and after blower temps. is a 30-40F delta like his considered normal. |
08-10-2020, 02:48 PM | #10928 |
I'm gonna try a few things to bring down my temps a bit without hindering the boost. Idk if it will work but I'mma give it a shot. Just to try and make those extra 5 ponies
08-10-2020, 05:50 PM | #10929 | |
Space looks limited for a heat plate for the engine bay off boost filter but that would probably drop IAT another couple degrees depending on what you came up with. Which might help lessen MAF heat soak effecting on boost reading. Not sure how the ESC does with rain/water? Could get hood vents a hood vent near or above the engine bay filter would do wonders for off boost IATs. Maybe a protective shroud for the ESC from rain if it’s close to the vent. |
08-14-2020, 09:45 AM | #10930 |
Drives: SWP BRZ
I was replacing dump batteries and i accidently did not disconnect cable that goes control unit and touched battery terminal less than 1 sec then boom! I think i shorted that control unit. I am wondering that unit has some kind of fuse to protect its unit? Stupid me didnt think of it. I shouldve disconnect that red cable first. I completely screwed? Or can be fixed?
Sent from my SM-N950U1 using Tapatalk |
08-15-2020, 06:50 PM | #10931 | |
The Following User Says Thank You to BlOody_BoOger For This Useful Post: | zc06_kisstherain (08-15-2020) |
08-15-2020, 09:20 PM | #10932 | |
Drives: SWP BRZ
yeah i took apart and fuse is fine too~!! also, just call battery mart and batteries went bad? then i dont have to send replacement? what do they ask? Last edited by zc06_kisstherain; 08-15-2020 at 09:51 PM. |
08-15-2020, 10:35 PM | #10933 | |
08-15-2020, 10:37 PM | #10934 | |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
