06-19-2015, 04:01 PM | #323 |
Drives: 2015 FRS
Just loaded E85 stage 2 EL tune on my stock 2015. So far, so good!
What I'm wondering if there is a procedure to do throttle calibration on these cars? For example, VW/Audis have throttle body alignment feature available in VAG-COM. It's super annoying waiting till the pedal becomes responsive in these cars after a flash or ECU reset. |
06-19-2015, 04:34 PM | #324 | |
Drives: FT86
06-19-2015, 05:57 PM | #325 |
Drives: 2015 FRS
07-26-2015, 01:40 PM | #326 |
Bottled FRS
Drives: 2016 manual frs
Can running an e85 fuel cleaner help reduce General wear?
I am debating using e85 in the future, power would be awesome just don't want to break the car. I was thinking something like this
http://lucasoil.com/products/fuel-tr...th-stabilizers |
07-26-2015, 03:54 PM | #327 | |
07-27-2015, 05:27 AM | #328 |
Drives: 2014 86 GTS
Just to instil some confidence in this fuel, here is my port injector after 4000km on full time eflex and 10000km garbage 98 before that..
It's absolutely squeaky clean both inside and out, the camera exaggerates the dirt alittle and what you see on it is just pcv residue which was left also in the rest of the manifold which I cleaned out. Ethanol is awesome. |
08-27-2015, 11:24 PM | #329 |
Drives: 15 CWP
I have a greddy intake and ofh/oft do i need go get custom dyno tune so they re scale maf?before running e85 fuel and flashing to stage 2 e85 uel?thanks
08-28-2015, 02:15 AM | #330 | |
Drives: FT86
It would be better if you scaled your maf on petrol tune then transfered that scaling to the E85 tune you can do the scaling yourself if you want see here http://www.ft86club.com/forums/showthread.php?t=64790 their is also a baseline Takeda maf scaling attached shiv could do you a customised e-tune for $200 that would be heaps cheaper than dyno |
08-28-2015, 03:20 AM | #331 | |
Drives: 15 CWP
08-28-2015, 03:32 AM | #332 | |
Drives: FT86
Dyno tunes will always be better than an e-tune, as the tuner is right their at the dyno and can make changes on the fly and see the results instantly and do the runs he/she wants at specific loads ect dialed up on the dyno. However if you have a good base tune that was dialed in on dyno and it just a clean up and intake scaling required it probably not worth the expense of a full dyno tune. you might also be hard pushed to find a tuner that works with opensource tunes like openflash as they generally want to lock their tunes. |
08-28-2015, 04:07 AM | #333 | |
Drives: 15 CWP
09-05-2015, 02:51 AM | #334 |
/scion
Drives: '13 86 M/T
I understand that we are able to run e85 with OFT tune. If I wanted to have a Zeitronix ECA2 to view e% on a gauge, would I need to buy flex fuel lines to connect to the FF sensor? If so, am I better off just going with a plug n play FF kit?
09-05-2015, 03:00 AM | #335 |
A Demon
Drives: Raven GT86
09-05-2015, 06:24 AM | #336 | |
Drives: FT86
oft tunes dont yet have the software required to read the e% from the sensor and adapt the tune, your going to need ecutek flex fuel tunetune and licience and flex fuel kit for a full flex fuel setup that arround $750 or so usa from memory. |
Similar Threads | ||||
Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
