Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-05-2012, 09:11 AM | #1 |
Drives: 12Focus, 16MX5, 99VFR
What tire PSI are you using
I've noticed it doesn't take much to get the tires on my FR-S howling in a turn. I'm curious what tire PSI other people are using. The max for these tires is around 50 PSI but my dealer had it at 32. I do think the noise is a function of the tires rolling under, not a lack of overall grip. Anyone arrive at the perfect pressure yet?
SEC
07-14-2012, 02:12 PM | #2 |
It looks like 45 PSI in the front, 42 in the rear is a good combination.
SEC
07-14-2012, 02:53 PM | #3 |
07-14-2012, 05:52 PM | #4 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Personally I think the tires suck for grip and I think the noise is likely a function of lack of said grip. Feel free to add more air to try and get them not to squeal. IIRC mine were around 38 psi all around when I picked mine up, squealed badly any time I cornered hard. Stock tires are off the car now (less than 2 weeks after I bought it)
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
07-14-2012, 06:23 PM | #5 |
I find the front tires howl way too easily under hard cornering. I’ve added air pressure to stiffen the sidewalls in hopes of eliminating this problem. With 45 pounds in the fronts, it seems to be improving.
SEC
07-14-2012, 06:26 PM | #6 | |
SEC
07-15-2012, 12:30 AM | #7 |
Drives: '13 FR-S
I've run the stock tires for the past couple of auto-x's .38-40 lbs might be ok for the fronts, but the (stock) rear tires seem to want more like 33-36lbs. More just rounds off the tire and makes for more fun than speed. Take this as what it is, though - one guy's very narrow scope of experience.
07-30-2012, 09:09 AM | #8 |
Drives: BRZ Ltd WRB
I knew the stock tires had low grip, but I was surprised how easily the broke loose and made sound. I checked the tire pressure yesterday and the wheels were at 31 psi. The recommendation in the door is 35 psi. I am surprised Subaru delivered the car without adjust tire pressure to the recommendation. Anyway, I set the tire pressire to 36 psi. That helped on the tire noise and the steering feels a little crisper as well.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
Similar Threads | ||||
WTB: 1 OEM wheel with or without tire | #87 | Wheels and Tires | 11 | 01-31-2013 01:21 AM |
Tire Rack still needs a BRZ! | Lonewolf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-12-2012 02:35 PM |
Tire Prices | abigailwatkins007 | ASIA | 0 | 05-30-2012 07:04 AM |
Plus 0 tire sizing | Brzer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 01-30-2012 08:15 PM |
Would you want a spare tire in your FR-S? | iff2mastamatt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 122 | 01-13-2012 01:40 AM |
