Software Tuning Discuss all software tuning topics. |
01-16-2024, 07:14 PM | #1 |
Drives: 2015 BRZ Limited
OFT Turn off O2 Sensor Codes?
So I am fixing to install a JDL UEL header with no pre-cats. I already have an OFT and have been running it's canned tunes for years. I will be switching to the stage 2 (or whatever) tune for OEL headers after the install.
Does the OFT included tunes turn off the emissions codes set by not having pre-cats? Do I need to use antifoulers on the O2 sensors when I install or can I just install them normally? Sent from my Pixel 7 Pro using Tapatalk |
01-16-2024, 08:28 PM | #2 |
Drives: 17 Asphalt 86
Tune disables cat related codes. You are fine with just tune.
The Following User Says Thank You to RToyo86 For This Useful Post: | SlowCarFast (01-16-2024) |
01-17-2024, 10:11 AM | #3 |
Drives: 86 GT
OFT tunes for the facelifts (K00G, K01I) actually have an additional DTC (P2270) that is not found on the A01G/A01I series, which reports the post cat O2 sensor stuck lean.
That DTC may possibly trigger with aftermarket headers or preinstalled spacers, but it is not in the provided OFT definitions so it can't be disabled with RomRaider - but it apparently can be disabled using Ecutek.
DIY stuff at Compelica Works
Similar Threads | ||||
2013 Scion frs speed sensor/codes | loganmarston9696 | Engine, Exhaust, Transmission | 10 | 12-29-2018 08:43 PM |
OFT & Rear O2 Sensor Failure - Can I Temporarily Disable Codes? | nofferman | Software Tuning | 6 | 07-09-2017 11:37 AM |
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
