05-07-2016, 01:22 AM | #533 | |
ECU has two fuelling modes open loop (WOT and hard acceleration) and closed loop (cruising light acceleration and idle) Closed loop = When fuelling is calculated from inputs from MAF and O2 sensor (generally idle and cruise) Open loop = Fuelling calculated from MAF sensor and OL Fuelling table targets (Generally Wide open throttle or quick throttle movements) OFT or Tactrix logs – Fuel system status indications 1= Warmup not up to temp 2=Closed Loop, 4=Open Loop or de-celeration fuel cut 8=Open Loop due to system failure Simplified explanation Open loop/Closed loop fueling Usually open loop is used on initial start and during warmup, until the 02 sensor reaches its operating temperature and produces a reliable signal , at which point the ECU switches to closed loop for idle. Warmup mode is Fuel System status =1 Under heavy acceleration or abrupt throttle movement the system will generally go open loop. Fuel system status =4 During cruise and idle it will generally be in Closed Loop mode Status = 2 When the engine is running in closed loop, it is using the signal from the O2 sensor to regulate the AFR in conjunction with the MAF sensor. There is a feedback "loop" between the O2 sensor and ECU so the ECU continuously makes adjustments based on the O2 sensor data. The correction applied by the ECU due to the O2 sensor input will be in the form of STFT, if the STFT stays negative or positive consistently for a period of time it will be written to LTFT. There are several bands of LTFT based on MAF sensor flow rates (roughly related to engine RPM) where the ECU stores the LTFT. This is a continuous learning process and other offsets and compensations are applied due to IAT, Pressure , coolant temp ect. In open loop the O2 sensor isn't used and the ECU sets fueling based on stored maps(OL fueling AFR target maps) the MAF sensor input and LTFT trims learned when engine was running in Closed loop mode. So if you MAF scaling is out of wack you will build up large LTFT when on Closed loop mode these will be stored and then applied as corrections when you go Wide open throttle.(Open loop mode). maybe read links below on Flashing RESET Logging and MAF scaling |
05-08-2016, 08:50 PM | #534 |
Drives: 2013 ScionFRS
My tablet stopped connecting with my computer, keeps trying to connect with device and doesn't. Re installed software still nothing. Any ideas?
Sent from my SM-G930P using Tapatalk |
The Following User Says Thank You to Tonypepatone For This Useful Post: | MrFisty (05-10-2016) |
05-08-2016, 09:25 PM | #535 | |
OFT doesn't like USB-3 ports (blue inside) try as USB 2/1 port (usually white/black) Try a new usb cable if you have one if that fails ring the oft guys |
The Following User Says Thank You to steve99 For This Useful Post: | Tonypepatone (05-09-2016) |
05-09-2016, 03:41 PM | #536 |
The Fistiest
Drives: 2013 Argento FR-S
Isnt OFT supposed to auto update to the newest template? Mine will not.
They said my last sig was too big.
05-12-2016, 06:16 PM | #537 |
talk to oft guys their was a bug a while back but was supposed to be fixed
05-16-2016, 09:09 AM | #538 |
Drives: '13 BRZ
Just a quick question. Can OFT read codes off of other cars that are not supported? i.e Suzuki SX4 showing a check engine light and I want to know if I can use OFT to figure the code
05-16-2016, 06:32 PM | #539 | |
something like the torque app on an addroid phone will work with a 10 dollar blutooth elm327 adapter. |
05-17-2016, 09:16 PM | #540 |
Drives: FRS RS1
I'm having trouble reading my stock tune. 2015 FRS bought last July. Made sure ignition was full on without engine running and got an error when trying to read. Turned the car off and tried again after a minute and same thing. Diagnostics work when I run the engine and check real time data though... So idk what's going on... Help? Automatic transmission as well.. And was recently received back from dealership for TSB on the idle issue around 1000rpm.
Sent from my ONE A2005 using Tapatalk
My 2015 Scion FR-S RS1 Build Thread
http://www.ft86club.com/forums/showt...19#post2718119 |
05-17-2016, 10:41 PM | #541 | |
assume its was brand new and no chance of an ecutek or brzedit tune in it In the diagnostics screen or ecu info screen can you read the vehicle VIN number and calibration ID ? ive seen one case where the dealer did not set the vin in ecu. also try resetting ecu by turning car off and removing a battery terminal then press brake pedal, leave it for a minute then reconnect battery. Unfortunatly this will also reset entertainment system setting and may require you to enter the radio security code so make sure you have that. then try reading the ecu again oh forgot make sure you have selected toyota and ZN6 as vehicle in the oft screens |
05-18-2016, 07:49 AM | #542 | |
Drives: FRS RS1
I can read the VIN and CAL ID with the OFT. When you mean press the brake pedal, do you mean leave it depressed for a minute or just press it and then leave it alone for a minute? Also, do you know where I can get the radio security code? Is it in the owners manual? Thanks Sent from my ONE A2005 using Tapatalk
05-18-2016, 07:12 PM | #543 | |
if it still does not work contact the oft guys on phone you might have a faulty unit |
05-19-2016, 10:13 AM | #544 | ||
Drives: '13 BRZ
Just to follow up on this. It does not work on cars that are not supported in case anyone else is interested in this. |
05-19-2016, 12:03 PM | #545 |
Drives: BRZ SWP Limited -6MT
ran into issue updating OFM & newest template on a new machine. WINDOWS 7 pro, downloaded OFM1_25_1 from their site. ran the set up .exe and restarted as prompted. upon restart open OFM and plug in device, it begins the auto update searching for files automatically. it makes it down past the *dev.dll files, then says found new software version click ok to continue. click yes to allow permission to change whatever on the hardrive, at that point it pops an error box saying "access to path C:\OFM.exe is denied.
I have restarted the cpu several times, tried plugging the provided usb cable into two different slots (1 @ front 1 @ back). ive uninstalled OFM, redownloaded the file from the site, all attempts arrive @ the above denial. i am an existing OFT user having ran the OTS stage 2 tune for about 9 months now with only relevant mod concerning the tune is a CNT header. it was originally loaded up to a windows pc running winXP that I no longer have access to. I wanted to try out the recently released OFH stage 2 tune most everyone is raving about. the current view of the OFT when plugged into the current cpu notes Hardware version 100 & firmware version 133. and i dont believe my cpu has the newer USB3 plugs. @steve99 any suggestions? oh and thank you in advance Last edited by bababooey; 05-19-2016 at 12:05 PM. Reason: thanking the go to |
05-19-2016, 04:36 PM | #546 | |
The Following User Says Thank You to Killadelphia For This Useful Post: | steve99 (05-19-2016) |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
