Old 02-11-2022, 03:08 AM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by systemmotorsports View Post
Some of our other projects that we are simultaneously building and working on.
Do you have a link to details on the taco build?
systemmotorsports (02-11-2022)
Old 02-11-2022, 09:45 AM   #30
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Recaro RSG in Alcantara installed.
Those Recaros look great! Were you able to take care of any dash lights?
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Old 02-11-2022, 07:02 PM   #31
systemmotorsports
FT86Club Official Vendor
systemmotorsports's Avatar
Drives: GR86/FRS/GT3RS/F80/E92M/E46M/FK8CTR
Yes - you can find it on the Tacoma World forums! I do not want to derail this thread but just look up "System Motorsports 2021 Tacoma Build"
SYSTEM MOTORSPORTS
Top Distributor for Rays Engineering / Volk / Advan / BBS / Work / SSR, & More!
www.systemmotorsports.com
thomson@systemmotorsports.com / sales@systemmotorsports.com
Follow us on Instagram! / OUR '22 GR86 BUILD THREAD
systemmotorsports is offline   Reply With Quote
The Following User Says Thank You to systemmotorsports For This Useful Post:
soundman98 (02-11-2022)
Old 02-11-2022, 07:02 PM   #32
systemmotorsports
Dash lights can be resolved with a resistor! We did not put it in yet.
SYSTEM MOTORSPORTS
Old 02-21-2022, 09:39 PM   #33
warhawk03
Drives: 2018 BRZ
Are those the Recaro universal seat sliders? Did you have to do any modification for the install?
warhawk03 is offline   Reply With Quote
Old 02-22-2022, 09:34 PM   #34
systemmotorsports
The sliders did not require any modification for install for us.
SYSTEM MOTORSPORTS
warhawk03 (02-24-2022)
Old 02-28-2022, 05:23 PM   #35
systemmotorsports
A little teaser for any fitment aficionado. We have proceeded to upgrade to adjustable FLCA that allows us to fine-tune the caster/camber adjustment on the car.
We are test-fitting 18x10 +44 5x100 TE37 Saga (Face-4 concave) in our shop spec, taken from the previous generation. Photos attached. The car will need to be realigned as we have made further adjustment to the ride height as well.
SYSTEM MOTORSPORTS
Old 02-28-2022, 07:17 PM   #36
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any chance you've taken a similar photo for the floor area under the driver's seat?
Old 03-06-2022, 01:25 AM   #37
systemmotorsports
Rays Volk TE37 Saga 18x10 +44 5x100, Face-4 Concave
255/35/18 Falken RT660
Fronts are effectiely 18x10 +34 as a 10mm spacer was utilized to gain additional inner clearance at full-lock (not needed, but we did it anyways).
SYSTEM MOTORSPORTS
The Following 4 Users Say Thank You to systemmotorsports For This Useful Post:
DarkSunrise (03-06-2022), gcmak (03-07-2022), Mike_ZN6 (03-06-2022), whataboutbob (04-06-2022)
Old 04-06-2022, 07:05 PM   #38
systemmotorsports
We have since sized down the front spacer to 8mm, which makes 18x10 +36 effectively, which has the same inner clearance as 18x9.5 +42, and the same outer clearance as 18x9.5 +30. The rear remains with no spacer, so 18x10 +44.
SYSTEM MOTORSPORTS
The Following 3 Users Say Thank You to systemmotorsports For This Useful Post:
dsc_pat (04-09-2022), Dzmitry (04-21-2022), thedollarbill (04-07-2022)
Old 04-20-2022, 01:29 PM   #39
skkk
Drives: 2022 BRZ Sport-Tech
May I know the part number of the slider and side mount that you used?
I am thinking to use that with my Pole Position.
Thanks!
skkk is offline   Reply With Quote
Old 04-20-2022, 07:12 PM   #40
systemmotorsports
0.70.9NT
REC-7207450A
SYSTEM MOTORSPORTS
thedollarbill (04-21-2022)
Old 05-09-2022, 02:18 PM   #41
systemmotorsports
Equipped with Rays Gramlights 57DR in HS Gunmetallic. Updated our blog post on our website, but for those curious, these are 17x9 +38 in the limited batch finish. 245/40/17 tire, no rubbing.
SYSTEM MOTORSPORTS
thedollarbill (05-16-2022)
Old 06-12-2022, 02:50 AM   #42
systemmotorsports
GReddy x Voltex full aero kit.
SYSTEM MOTORSPORTS
jongers (06-12-2022)
rays wheels, system motorsports, te37, thomson, volk
Canadian 2022 Brz/Gr86 build and price websites/dealer availability?? prod CANADA 15 01-27-2022 08:14 PM
2022 BRZ/GR86 Fuse Tap? Midnightsky Cosmetic Modification (Interior/Exterior/Lighting) 1 01-24-2022 12:05 PM
2022 GR86 MSRP 2k over the BRZ? mangler CANADA 5 12-06-2021 10:51 AM
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
