06-08-2013, 11:02 PM | #1709 |
Red wine
Drives: Subaru BRZ(R.I.P)
Depending on my work schedule, I might only be able to go to Proving Grounds on Friday. But like ayau asked, I am also interested in knowing how our stock brake pad and brake fluid was handling at the track.
I had mines done at Maplewood Auto Salon for a great price, they were able to do my full bumper, half fenders, half hood, both side sill, and both mirrors.
06-09-2013, 03:36 AM | #1710 | |
Drives: Some rust bucket
06-09-2013, 09:25 AM | #1711 | |
Also, just an FYI to others out there, it sounds like Bravo does all the Morries dealerships and if you go directly through them vs the dealer you save a huge chunk of change (dealer is double if that helps). |
06-09-2013, 10:12 AM | #1712 | |
Drives: '13 FRS whiteout
06-09-2013, 11:01 AM | #1713 | |
Drives: FR-S White Out
As far as the OEM stuff went for me. I actually went out and did some hot laps with stock rubber, rotors and brake pads but I wouldn't recommend it. I had upgraded my brake fluid to DOT 4 but in the afternoon when I was running on my slicks I managed to get the brakes or lines too hot coming into turn 3 and just about went off the track. I went back out again after everything cooled down but I wasn't as confident about the brakes after that. Definitely going to upgrade the pads and add braided lines next. Black_tire was running braded lines/upgraded pads/strut brace and I really liked the way his car felt. Overall its a blast, but it certainly be better with those brake mods. I never felt like I was down on power, just down on brake feel. |
06-09-2013, 11:06 AM | #1714 |
06-09-2013, 05:55 PM | #1715 | |
Red wine
06-09-2013, 11:54 PM | #1716 | |
http://www.motorsportreg.com/index.c...F1FD6262E7999C For a small track such as DCTC, you might be able to get by with OEM pads. I would definitely swap fluid because it's cheap, about $15 for a DOT 4 bottle. |
06-09-2013, 11:56 PM | #1717 | |
Red wine
Which DOT 4 fluid would you recommend? Or does it not matter
06-09-2013, 11:59 PM | #1718 |
ATE Type 200. You won't boil that at a small track, and it's cheap. For bigger tracks such as BIR, you may want to consider something higher temp, eg., Project Mu Gforce.
06-10-2013, 12:02 AM | #1719 |
I'd also install some front crash bolts to save your front tires and for some additional turn in grip. Your OEM tires will roll over A LOT.
06-10-2013, 02:19 AM | #1720 |
Red wine
I never messed around with camber before because I always have one of my mechanics do the work for me, is this something I can do in the garage or am I better off going to a shop to get me the camber that I need?
06-10-2013, 11:32 AM | #1721 | |
If you're going to get coilovers and camber plates, I'd wait so you don't have to get an alignment twice. Last edited by ayau; 06-10-2013 at 02:35 PM. |
The Following User Says Thank You to ayau For This Useful Post: | LeeMaster (06-10-2013) |
06-10-2013, 06:49 PM | #1722 |
Drives: 2013 Subaru BRZ - DGM
Similar Threads | ||||
Check in, eh? | NorthFool | CANADA | 24 | 02-23-2012 07:32 AM |
*NSFW* "Check Out My Subaru" on You Tube | Axel | Other Vehicles & General Automotive Discussions | 4 | 01-17-2010 05:56 PM |
how do you check a site | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 11-21-2009 09:27 PM |
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. | JDMinc | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 10-25-2009 08:53 PM |
