10-15-2020, 05:52 PM | #71 |
Rust bucket enthusiast
Well, I'm impulsive, what can I say. Southbend stage 3 clutch, Verus clutch fork and pivot! Interestingly enough, the clutch itself is an Exedy manufactured product. The pressure plate is just spray painted red, the paint smell was quite pungent when I opened the box, and there was some parts they missed. Not that it matters, just putting that info out there for people who may be hoping for something expertly executed with aesthetics in mind.
I love that break-in instructions are included ON PAPER. No webpage deciphering or hunting. The clutch fork is much more heavy duty feeling than I had expected. I have absolutely no doubt that this piece could withstand literally anything. The pivot looks nice, bling honestly. |
11-02-2020, 03:34 PM | #72 |
Got a wideband put together for me at VEMS with the Bosche 4.9LSU sensor. Unsure what I'm going to add as secondary (it's a dual display) but I'll figure it out.
11-07-2020, 01:43 PM | #73 |
Decided to measure the turbo, since nobody seems to run or have data on it.
Just to rehash- it's a Boostlab BL5858 journal bearing turbo. |
11-07-2020, 01:46 PM | #74 |
Drives: Bone stock
That thing is beautiful
Sent from my SM-N960U using Tapatalk |
The Following 2 Users Say Thank You to Joveen For This Useful Post: | anticubus (11-07-2020), DarkPira7e (11-07-2020) |
11-08-2020, 04:36 PM | #75 |
Got my wideband installed today!
11-10-2020, 08:35 AM | #76 |
Well, I made a decision to end my suffering. I'm ditching the CXracing manifold and bought the JDL EL manifold/downpipe setup. Not recirculating the wastegate dump back into the exhaust, if I need to be quiet I will just stay out of boost.
The build looks like this now- Engine/Fuel/Electronics- IAG Stage 1 Shortblock 10:1CR Refreshed Stock Heads w/ Kelford 62lb Springs ID1050x Injectors ECUtek W/ Racerom VEMS Wideband Gauge Drivetrain - Southbend Stage 3 Daily Clutch Fidanza Lightweight Flywheel Velox Carbon fiber Driveshaft STI Transmission Mount Torque Solutions Engine Mounts Suspension/Wheels/Brakes - Apex ARC-8 17x9 Nitto NT555R 245/45 Stock 2017 Subaru BRZ Performance Pack Sachs Struts Centric Blank Rotors TRD Brake Pads Eibach Pro-Kit Springs STI Strut Mounts Whiteline Front Endlinks Whiteline KDT925 Differential Outrigger Inserts Whiteline KDT922 Subframe Bushings Energy Suspension Swaybar Bushings MTEC Transmission Shifter Detent Springs Turbo/Exhaust- JDL Front Mount Intercooler Turbosmart Raceport BOV JDL EL T3 Manifold W/ External Turbosmart UltraGate 38mm Wastegate (open dump) Boostlab BL5858 Turbo JDL 3" Downpipe JDL 2.5" Overpipe / Dual Resonated Frontpipe FT86SpeedFactory x Remark 3" Quad Tip Catback Exhaust Other Misc- Radium Engineering PCV Oil Catch Can VTA Radium Engineering Fuel Rail Verus DI ECU Bracket ATI Vent Gauge Pod A/C Delete Mishimoto Slim Shroud w/ 1150CFM Fans Custom Suede Wrapped Center Console eBay Center Armrest JDM Black traction Control Buttons JDM Black Shifter Trim and Radio Bezel JDM Knee Pads 2017+ One Piece Dash Bezel Tomei Duracon Shift Knob Last edited by DarkPira7e; 11-10-2020 at 10:09 AM. |
11-10-2020, 08:58 AM | #77 | |
Drives: Bone stock
11-10-2020, 10:24 AM | #78 |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Joveen (11-10-2020) |
12-10-2020, 04:56 PM | #79 |
Engine is here!! No plans to install yet, just getting all the pieces together
12-30-2020, 07:43 PM | #80 |
Drives: 2014 BRZ Limited
Did that motor come with the build clearances?
12-30-2020, 08:54 PM | #81 |
I haven't opened the box. If it's something you need real bad I can open to see
12-30-2020, 10:21 PM | #82 |
The Following User Says Thank You to elitegunslinger For This Useful Post: | DarkPira7e (12-30-2020) |
12-30-2020, 10:43 PM | #83 |
Drives: jrsc_brz
My heavens, what have I been missing, ur building an iag block from the ground up? Wheres it being built??
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
The Following User Says Thank You to HaXx For This Useful Post: | DarkPira7e (12-30-2020) |
12-30-2020, 11:41 PM | #84 | |
"Getting all the pieces" means for the build in general
The Following User Says Thank You to DarkPira7e For This Useful Post: | HaXx (12-31-2020) |
Tags |
brz, frs, iag, jdl, turbo |
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
