Old 02-21-2018, 11:45 AM   #1
JDM4E
Drives: Honda Accord Euro
AT vs MT WHP difference
I thought, that AT clutch locks up and the the WHP difference is negligible.
I found only one dyno graph here - http://www.ft86club.com/forums/showp...25&postcount=1
here it shows that it seems my theory is correct, until hi rpm. Why is that? Is that a bad methodology on that dyno run or there is something AT related to that?
Also is there is a info, where the lock up happens? Is it all the time or only on partial throttle etc?
Thanks
JDM4E is offline   Reply With Quote
Old 02-21-2018, 12:40 PM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
gearing is different?
Old 02-21-2018, 03:00 PM   #3
The Following 12 Users Say Thank You to Tcoat For This Useful Post:
Dadhawk (02-22-2018), JustSomeGuy (02-21-2018), Leonardo (02-21-2018), N8RH8R (02-23-2018), new2subaru (02-21-2018), p1l0t (02-24-2018), sprintertrueno86 (02-23-2018), Spuds (02-21-2018), Tectoniic (02-22-2018), ThatAsianBradah (02-22-2018), weederr33 (02-22-2018), why? (02-25-2018)
Old 02-21-2018, 03:49 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Cannibalism!
via Imgflip Meme Generator
I LIKE TIRES!
Old 02-21-2018, 03:57 PM   #5
ls1ac
ls1ac's Avatar
I do not think the graph is HP related, it should not have a line between points. It is showing ratio per gear. A step or bar not a connecting line, there is no ratio between gears.
Not HP not speed not time.
Old 02-21-2018, 08:40 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
An AT twin FBO E85 vs lose to a MT twin just headers and e85. That’s how slow the AT is. Really isn’t worth modding an AT NA wise. If you have an AT, just go turbo.
Dr. BRZ is offline   Reply With Quote
Old 02-21-2018, 11:07 PM   #7
phrosty
A Camry will still beat either.
phrosty is offline   Reply With Quote
Old 02-21-2018, 11:27 PM   #8
Tristor
Tristor's Avatar
Is there some evidence that shows this comparing similar builds AT vs MT on the dyno or something?
Tristor is offline   Reply With Quote
Old 02-22-2018, 12:22 AM   #9
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Well taking a couple steps back. An AT with headers on pump makes only about 5whp more than a stock MT on pump. The gearing on the AT is longer and not really matched for the low power NA, so the MT would still be faster than an AT with headers.
Once you get into boosted applications the long gearing of the AT pays off as the power is more suited to the power level. That's why you often see boosted MT going from the 4.1 FD to a 3.9 FD or lower.
tyler_win_photo is offline   Reply With Quote
Old 02-22-2018, 03:02 PM   #10
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
I am still waiting for an MT twin to keep up with my AT FR-S on the twistiest roads......
Why, because MT drivers miss a shift or two...........
IceFyre13th is offline   Reply With Quote
The Following 3 Users Say Thank You to IceFyre13th For This Useful Post:
Kestrel (02-22-2018), pinoy_dorifto (03-05-2018), ThatAsianBradah (02-22-2018)
Old 02-22-2018, 04:30 PM   #11
FRS Justin
Drives: 2013 Asphalt FRS
your loss of hp is caused by the fluid in your auto trans, to be a little more specific when the fluid passes thru the tq converter to create the input shaft to turn it loses energy. unlike a direct drive manual
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-22-2018, 05:41 PM   #12
Ernest72
Just press the gas pedal down a little further and she goes. Stage 2 was a big increase. Straight line speed is slow because of gearing and shifts. Putting into manual mode helps. But if you bought this car for straight-line you are doing it wrong.
Old 02-22-2018, 06:10 PM   #13
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Ive been very happy with my Edelbrock boosted, e-85, automatic FRS. 0 to 60 in 4.9 and I love the way it shifts on the track.
Lunatic is offline   Reply With Quote
Old 02-22-2018, 06:22 PM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by nikitopo View Post
Have you seen the performance figures of the AT cars? Top speed and acceleration (0-100 km/h). There is a BIG difference ...
Really? I don't know about that but my AT is plenty fast for me
What is the difference between.............. vmastros Scion FR-S / Toyota 86 GT86 General Forum 12 05-29-2016 07:58 PM
TIS and GTS, any difference? babybreath Software Tuning 1 03-28-2016 10:06 PM
bra difference from frs shift2launch BRZ First-Gen (2012+) -- General Topics 5 01-22-2015 01:00 AM
Every difference between the MT and AT BlueDubbinTDI Engine, Exhaust, Transmission 38 09-04-2013 09:32 AM
LED vs HID: what's the difference? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 13 04-06-2013 07:23 AM
