Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-24-2020, 01:34 PM | #1 |
Drives: 2013 FRS GTX3076R
FRS rear subframe removal?
Hi, I've searched and searched and cannot find a guide on how to remove the rear subframe. If someone could point me in the right direction that would be great. Thanks.
Sent from my SM-G950W using Tapatalk |
The Following User Says Thank You to yzf219 For This Useful Post: | humfrz (09-24-2020) |
09-24-2020, 01:46 PM | #2 |
Rust bucket enthusiast
Unbolt/remove anything between the ground and the subframe
Unbolt the subframe ??? Profit! |
The Following User Says Thank You to DarkPira7e For This Useful Post: | theneptune86 (10-01-2020) |
09-24-2020, 01:51 PM | #3 |
Drives: Crapcan
1. Disconnect driveline from diff.
2. Remove exhaust, disconnecting from mid pipe to front pipe junction back. 3. Remove parking brake cables. 4. Unbolt rear struts at the top mount inside the trunk. 2 nuts per side. 5. Disconnect TPMS and brake caliper. Zip tie up out of the way. 6. Support subframe, loosen off the 4 subframe mounting bolts. That is all I can remember off the top of my head, installation is opposite of removal. You can also unbolt the rear struts at the LCA's and let them dangle. This gives you the option to zip tie the caliper to the spring instead, but you have to deal with them dangling in the way. I used a forklift with extensions to raise and lower the subframe. A transmission jack would work well. If you have a buddy to help, it could probably be done with a floor jack too, but it will be difficult to work with, especially on reassembly.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
09-24-2020, 02:09 PM | #4 |
The Following User Says Thank You to Tcoat For This Useful Post: | theneptune86 (10-01-2020) |
09-24-2020, 04:12 PM | #5 |
Drives: 13 FRS
Are you changing your diff bushings?
This is my next project... its quite the task.. |
The Following User Says Thank You to RickyRacer For This Useful Post: | Opie (09-29-2020) |
09-24-2020, 04:12 PM | #6 |
Thanks for all the quick and helpful replies! Looks like I'll be tackling subframe and diff bushings soon enough.
09-24-2020, 04:12 PM | #7 |
The Following User Says Thank You to yzf219 For This Useful Post: | RickyRacer (09-24-2020) |
09-24-2020, 04:14 PM | #8 | |
Drives: 13 FRS
I was not looking forward to doing this... if you manage to complete this before me please share any updates / advice with the forum my bushings are on their way out as well, and I don't like the inserts will likely put the car up on all 4 jacks once weather gets bad and take my time on this project during the winter |
09-24-2020, 04:15 PM | #9 | |
Why do you want to do that? Are you sure you want to do that? |
09-24-2020, 04:18 PM | #10 | |
09-24-2020, 04:19 PM | #11 | |
The Following 2 Users Say Thank You to yzf219 For This Useful Post: | humfrz (09-24-2020), theneptune86 (10-01-2020) |
09-24-2020, 04:24 PM | #12 |
Drives: Crapcan
For the subframe, if you can get it up high enough, set it on some saw horses, your back will thank you later. The subframe bushings I recommend burning out, then use an air chisel to collapse the outer shell and it can be knocked out. If you don't have an air chisel or air hammer you can use a grinder with a cutoff wheel to cut a slit in the outer shell and hit it with hammer and chisel to collapse and knock it out. Body saw works for cutting a slit in the shell too.
The outrigger bushings on the diff can be pressed out, the rears can be burned out and then collapse the shell like the subframe bushings. I was out of gas for the torch when I did mine. I had a hole saw the right size and used it to cut the rubber bushing out. It is a messy job requiring many beers and blasphemies.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Opie (09-29-2020) |
09-24-2020, 04:39 PM | #13 | |
I do seem to recall someone on this forum saying they managed to do the subframe bushings without dropping the subframe. Rather he just lowered it enough and then cut/burned out the bushings from the bottom? I don't know how that's possible, maybe I misunderstood. Sent from my SM-G950W using Tapatalk |
09-24-2020, 05:04 PM | #14 | |
Drives: Crapcan
They may have just been doing inserts instead of the whole bushing. I’d be surprised if these came out easily on a new car.
Similar Threads | ||||
Notching Rear Subframe | ShutterSpeed | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 08-02-2020 09:27 PM |
WTB factory rear subframe | Deezee | Want-To-Buy Requests | 0 | 01-24-2020 01:00 PM |
Tubular rear subframe | Manji | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 09-24-2014 08:23 PM |
rear subframe bushings? | Roadcone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-09-2014 09:25 PM |
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-10-2014 08:59 PM |
