Old 01-04-2015, 10:30 PM   #197
Sukh
Drives: Scion FR-S, Skyline C210, F355
Does anyone with these coilovers have a pic on what they are like on their lowest setting. I'm almost ready to pull the trigger on a set of these but worried it's not going to be low enough for my desired look.
thx
2014 Whiteout FR-S - 1997 Ferrari 355 1980 - Skyline C210 - instagram: 00aujla
Sukh is offline
The Following User Says Thank You to Sukh For This Useful Post:
el-92 (01-12-2015)
Old 04-15-2015, 07:54 PM   #198
eromsdal
ERO
eromsdal's Avatar
Drives: '16 Subaru BRZ Series Hyperblue T
Originally Posted by FT-86 SpeedFactory View Post
Yes you could use a small diameter spring with a similar rate. We can customize that option. Will add money to the cost of them though.
Ive already ordered and installed my B14s, is it possible to get a higher spring rate spring for them separate?
eromsdal is offline
Old 05-04-2015, 06:12 PM   #199
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Monday bump!
FT-86 SpeedFactory is offline
Old 05-07-2015, 05:18 PM   #200
FT-86 SpeedFactory
Bump after hitting up Road Atlanta today!
Old 05-14-2015, 04:52 PM   #201
FT-86 SpeedFactory
Up we go!
Old 05-20-2015, 05:10 PM   #202
FT-86 SpeedFactory
Set of these went out today bump!
Old 05-29-2015, 03:14 PM   #203
FT-86 SpeedFactory
Up we go!
Old 05-29-2015, 04:54 PM   #204
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
B14/PSS settled. 15 F & 12 R threads from lowest
Tank is offline
The Following 2 Users Say Thank You to Tank For This Useful Post:
2015firestormFRS (12-30-2017), Createddeleted (06-28-2015)
Old 05-29-2015, 05:04 PM   #205
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Up we go!
Can you please provide a qoute for a set shipped to 90280?
Thank you
SG02WRX is offline
Old 05-29-2015, 05:26 PM   #206
simpleisbest
Senior Citizen
Drives: Scion FR-S
How are the rears? Any issues with the adjuster knobs and interference with the interior panels??
simpleisbest is offline
Old 06-01-2015, 03:57 PM   #207
Chad_W
Drives: 2013 BRZ DGM
Those wheels... how did you do that?
Chad_W is offline
Old 06-17-2015, 04:01 PM   #208
FT-86 SpeedFactory
Up we go!
Old 06-28-2015, 09:55 PM   #209
mush
mush's Avatar
got the b14 installed on 6/20/15
the first time driving with them was a little disappointing, ride was pretty bumpy at speeds under 30mph
the rears were left at factory setting and the fronts were lowered all the way for easy installation (used stock top hats)
left it like that for a few days for it to "settle" then adjusted it to 5 threads all around from lowest
got an alignment and now it rides WAY better
i had stock struts with swift frs spec springs(1in drop). the dampening is a lot better now, everything feels so much smoother
both front fender to ground is 25in
both rear fender to ground is 25 1/4in
its about 1.5 in drop from stock
mush is offline
The Following 3 Users Say Thank You to mush For This Useful Post:
JoeBoxer (07-04-2015), kevaughan (04-16-2024), YangerD (08-19-2015)
Old 07-04-2015, 02:03 PM   #210
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have the Swift BRZ springs, thinking about swapping over to these or the ST coilovers. ST are much cheaper obviously but they use a twin tube instead of monotube like the Bilstein. I wish somebody around had both but can anybody compare ride quality between the two?
JoeBoxer is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
