Old 03-27-2016, 05:51 PM   #1723
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Mach V Awesome / TRD Lowering Springs / 255/40 NT01 / 8mm Spacer / ~2.4* Camber
Did some test fitting this afternoon.
Joe-G is offline   Reply With Quote
The Following 5 Users Say Thank You to Joe-G For This Useful Post:
FujiwaraTofu86 (02-16-2017), Hicklinc (02-26-2018), NyC Zn6 (03-31-2016), PandaSPUR (03-27-2016), PeterFRS (03-29-2016)
Old 03-29-2016, 08:02 PM   #1724
PeterFRS
PeterFRS's Avatar
Drives: FRS
@Joe-G nice!! meaty tire so much win.. now..let me see the car in person!
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 03-29-2016, 08:20 PM   #1725
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I love my 275s but will definitely go wider in the rear soon!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 03-29-2016, 10:28 PM   #1726
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
ajaxthebetter (03-30-2016)
Old 03-30-2016, 08:27 PM   #1727
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
hey guys. i searched in the forum if 255/35/18 on 18x9.5 +38 lowered on coilovers will fit. ive only seen confirmation that it fits on eibach springs. currently lower than 1.5. any idea? i know 245/35/18 will clear. just mainly concerned up front.
Sent from my HTC One M9 using Tapatalk
b rawr z is offline   Reply With Quote
Old 03-31-2016, 12:57 PM   #1728
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It will fit with coilovers. Did you read through this thread? It contains all the info you are looking for. (most of it in the first post)
Old 03-31-2016, 01:03 PM   #1729
b rawr z
b rawr z's Avatar
I read but most of what I read it says they're on springs not coilovers. So if i go lower than spring drop which like what 1.5 inches. Will I rub? Basically what im concerned
Old 03-31-2016, 01:37 PM   #1730
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Please read post #1 on page #1.
Here it is...
Meaty Tire Thread
Because i have no idea where my original thread went i figured i start a thread
for ALL BRZ/FRS's that run meaty tire size. anything 255+ would be considered meaty for these purposes, everything else is just "normal" tire size.
just a few things that get asked ALL the time in here:
1) Most of us run a coilover, you really won't fit a 9.5 wheel up front with stock struts and will have minimal clearance with a 245 tire on a 9 inch wide rim with a 40-ish offset.
2) not all suspensions are created equal and not all cars are created equal. if something works on someones car, that doesn't mean it will be identical on yours, generally its true but not always applicable.
3) LCA are needed to adjust rear camber unless you don't care to correct it, you may also need toe arms or more toe adjustment via a bushing depending on your vehicle.
4) rolling and slightly pulling your fenders will give you more clearance than you think
please post up you modifications, any fitment tips, and obviously
feel free to use this is a photo dump for others to get ideas. if i need to edit something in the OP just lmk.
and now here is what i went through with my BRZ.
brought to you by @AZP Installs give them a shout
if you need anything, ESPECIALLY alignments, suspension work and track prep.
wheel/tires combo's i've fitted.
18x9.5 +40 Rays Gramlights 57xtreme w/ 265/35 RE-11 tire
18x9.5 +40 Rays Gramlights 57getter w/ 265/35 MPSS tire
Current suspension:
RCE t2 coilover
Group-n top hats front
GR STi rear tophats
SPC camber bolt
SPC rear control arms
Whiteline adjustable toe arms
perviously on AST 4150 and KW V3 and in pictures with xtreme's)
PARTS I DO NO RECOMMEND:
CUSCO rear LCA (PITA to adjust, if you don't do your own alignment then disregard and pay in labor)
WHITELINE COM C tophats (bearing failed 3 times)
YOU WILL RUB at first. its the plastic part of the rear bumper,
its not a big deal and will rub itself out of you can dremel it. (the corner to the bumper inside the fender)
Second I had an issue with my passenger fender, it rubbed on the part closest to the sidemarkers.
if you feel the fender there, it flares out towards the side marker, you want to roll that part in
to avoid any issues in the future or else you risk chipping the paint or gashing the tire....i luckily caught it early.
Third, and probaby most important. once we let the KW's settle we had to take camber out.
it settled to around -3.5' in the rear at the heigh i'm at. i did not want to run that much at
all, nor do i need that much for clearance issues. once it settle i fixed the camber with the
control arms however the STOCK toe arms did not cut it with the Cusco arms..so i upgraded to whitelines
My alignment specs are as follows:
camber F/R= -1.8/1.6 (-2.7 f/-1.8 rear for track)
front toe out= .08
Rear toe in= .08
car drives like a dream.
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
go_a_way1 (03-31-2016), Hicklinc (02-26-2018)
Old 03-31-2016, 01:44 PM   #1731
b rawr z
b rawr z's Avatar
Here it is...
Meaty Tire Thread
Current suspension:
RCE t2 coilover
GR STi rear tophats
SPC camber bolt
front toe out= .08
Rear toe in= .08
Right. None of there says +38 offset in 255/35 tire. Nor does it say how much drop he has. So my question stands.
Old 03-31-2016, 02:42 PM   #1732
Mindsucker
Mindsucker's Avatar
Drives: Honda Civic Type-R FK2
A 9.5" +38 wheel will bring the wheel 4,3mm closer to the strut than a 9" +40 wheel. Ad a wider tire to that and the answer to your question is no, it won't fit with stock struts.
Mindsucker is offline   Reply With Quote
The Following User Says Thank You to Mindsucker For This Useful Post:
b rawr z (03-31-2016)
Old 03-31-2016, 02:44 PM   #1733
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You're talking about a 2mm difference in offset, and a 10mm difference (roughly) in tire size.
If Jive's setup rubs at the height he is (look at pictures and you'll see its a good 1" to 1.5" lower), you most likely will too. Of course, you can always just run more camber to keep from that happening, but that's on you.
The answers are here in this thread. Multiple times, in fact. A little searching a reasonable (or common) sense would be enough to quickly answer your question.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 03-31-2016, 02:45 PM   #1734
TylerLieberman
Drives: '24 GR86
Wrong. a +38 will push the wheel 2mm out (away from the strut) compared to a +40.
Old 03-31-2016, 02:46 PM   #1735
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I can't do all the work for you. Turn to page one and give this thread a few minutes. I have read the whole thing. Everything is explained in detail. Many questions asked, just like yours, with answers. Also, I already told you it will fit with coilovers.
Jive Turkey (04-01-2016)
Old 03-31-2016, 02:49 PM   #1736
Mindsucker
Mindsucker's Avatar
Not compared to a 9" +40 that jive mentioned barely fit with stock struts. That extra 0.5 inch in wheel width will bring it closer to the struts.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
