Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-16-2022, 12:19 PM | #15 |
Purist
Drives: 2013 FRS - Hot Lava
Tsuchiya uses a high end version of ST coils on his GT86. ST is a KW brand. They are... similar to the RCE SS-1's
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
06-16-2022, 08:58 PM | #16 |
Drives: 2022 Steel GR86
06-17-2022, 04:36 AM | #17 | |
Drives: 17 BRZ ,21 GR Yaris, 23 GR86
The ones he use are most likely the higher version based on ST XTA Plus 3 which is similar in design to KW Clubsport. RCE SS1 are more similar (at least construction wise) to regular ST XTA (which ST offers in green DK version too). Both seem interesting to me because it's hard to find their direct KW counterpart. |
06-17-2022, 05:16 AM | #18 |
Drives: Toyota 86
3 ways Kw are different, compression side is monotube with piggy back canisters while rebound one is twintube, ST 3 way damper doesn’t have canisters and it’s twin tube.
06-29-2022, 09:51 PM | #19 |
Drives: 2022 White BRZ manual
I had mine installed a week after I got my 22 BRZ. Car is less floaty over big bumps and rides now comfortable using their recommended setting. Also tries it on track and it is very capable when paired with Kumho V730 tires! Everyone who drove it commented on how controlled and planted it is. Their customer service is top notch, answered all the questions I had within a day. Highly recommended.
The Following User Says Thank You to mcbat68 For This Useful Post: | Racecomp Engineering (07-12-2022) |
10-09-2023, 06:42 PM | #20 |
Drives: 18 BRZ tS, 27 GRMN 86
@Racecomp Engineering
What's the difference between SS1 and ST XTA? It is a big $ difference between the two shipped to Canada. Just debating if it is worth it to go for the SS1 over the XTA. Thanks! |
10-10-2023, 12:56 PM | #21 | |
And arguably the biggest plus with our SS1s is the ability to call us at almost any time or PM for support with install, advice on adjustments at the track, and anything else that might come up! We know these cars and these coilovers super well so when you talk to us you're talking to someone that has had these exact coilovers on the same car. - Andrew |
11-09-2023, 01:05 PM | #22 | |
Thanks! https://www.racecompengineering.com/...-2022-brz-gr86 https://www.racecompengineering.com/...21-brz-fr-s-86 In other words, the 2022+ must be for 2nd gen only? Thanks! |
11-10-2023, 06:47 PM | #23 | |
Here's a little write up I did on 1st and 2nd gen suspension/chassis differences. We have both as shop cars and developed SS2s + SSRs on both cars, plus retested SS1s on 2nd gens. https://www.racecompengineering.com/...ension-changes - Andrew Last edited by Racecomp Engineering; 11-27-2023 at 12:35 PM. |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | botbs (11-10-2023) |
11-18-2023, 01:05 PM | #24 |
How much stiffer than stock is the ride? I'm leaning towards getting a set of these but don't want to have a very stiff ride on the street.
11-23-2023, 06:28 PM | #25 | |
Drives: 2020 BRZ Sport Tech RS
They're also definitely superior in both ride comfort and handling vs. my previous set up of H&R Sport springs on stock PP shocks, which was too harsh on bigger bumps. Definitely worth the investment.
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post: | Mr_Brian (11-23-2023), Racecomp Engineering (11-24-2023) |
11-23-2023, 08:11 PM | #26 |
Drives: '13 BRZ Limited
They are about 2x the spring rate of the stock springs. In my case I can for sure feel the higher rates - the car follows up/down motions in the road more closely. Impacts are not worse - probably actually better than the stock springs/shocks. It's stiffer for sure, but not really harsher - and the trade is the handling is better.
The Following 3 Users Say Thank You to 86league For This Useful Post: |
11-26-2023, 06:51 PM | #27 | |
Drives: GR86
Curious to see the write up for 1st/2nd gen, did I miss the link to that somewhere? |
11-27-2023, 12:35 PM | #28 | |
https://www.racecompengineering.com/...ension-changes |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Ultramaroon (11-28-2023) |
Tags |
coil over, coilovers, racecomp |
Similar Threads | ||||
Racecomp Engineering Superstreet-1 | Lynxis | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 41 | 08-16-2022 01:33 AM |
FS: Racecomp Engineering Tarmac 2 Coilovers | USDM TOYOBARU | Brakes, Suspension, Chassis | 4 | 06-16-2020 05:25 PM |
FS: RaceComp Engineering Tarmac 2 Coilovers | Louder | Brakes, Suspension, Chassis | 1 | 10-16-2019 08:41 PM |
Racecomp Engineering Tarmac 2 coilovers. $1,500 | Pat | Brakes, Suspension, Chassis | 16 | 07-22-2018 10:23 AM |
RaceComp Engineering Tarmac Zero coilovers | jack43 | Brakes, Suspension, Chassis | 5 | 10-03-2014 04:17 PM |
