02-20-2023, 05:15 PM | #645 | |
Drives: None
I think there is a lot of time on the table, I don't have much seat time CW. I really get sucked into the stupid TT thing where it is hard to try different stuff or push more since a 4 off is a DQ / there are cars a second or two behind me / I need to put down a lap time. I'd like to: Get off the brakes earlier at 1 and carry more speed through 2 Figure out where I'm supposed to turn in at 4, I think I am too early Not lift as early at 6 Figure out what is going on at 7 Not brake at 8 and instead carry the speed in and brake up the hill to 9 10 is important, probably run it out wider to be on throttle longer Carry more speed into 11 Probably enter the bowl up higher since the car pushes terribly mid corner / steering is bound up and I am getting on and off the throttle to try and get the back end moving a bit Off the brakes earlier at 14 and just lift for 15 like I could in my S2000
02-20-2023, 06:01 PM | #646 | ||
btr.life
Drives: 2022 GR86
T4 I have done a lot of experimenting there and think I have it ok. I try to turn in at the end of the right kerb then make a single big arc from T4 apex cone through to T5 exit cone. If I get it right it is just one steering input and throttle modulation to maximize corner speed. The T6 to T7 is still a mystery to me as well, feels so awkward and trying to get the downshift in just doesn't feel right, and very slow. I'm still getting up the courage to go faster into T8 and T11 too. I've been braking there a little bit, and it is such a waste of momentum and time, I'm sure. Although for T8, I'm not sure the GR86 could slow down quick enough on the uphill to T9, at least with stock tires. I've blown through T9 a few times trying to go faster into T9. Same with T14/15 for me, the visuals are hard there, especially T14. We'll have to sit down at next event and share ideas!
The Following User Says Thank You to justinco For This Useful Post: | RedReplicant (02-20-2023) |
02-26-2023, 12:34 AM | #647 |
Drives: 2020 86 Hakone
Willow Springs IR (Big Willow)
2:20 in the morning. 1:39 in the afternoon when things cleared up. I rarely get to run Big Willow so it was nice to get some runs in when things are not so perfect out, vs somewhat perfect conditions. Great experience imho as far as learning. |
The Following 3 Users Say Thank You to downshiftxlr8 For This Useful Post: |
03-12-2023, 11:26 AM | #648 |
Drives: '23 GR86 Neptune PMT
Here is a very wet lap of Thunderhill West. Some spins from the day at the end too.
03-14-2023, 09:26 PM | #649 |
Drives: '22 GR86
Radford school course with looper. was 0.16 off the nasa TT5 record
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
The Following 2 Users Say Thank You to staples323 For This Useful Post: | Nick Dugdale (04-16-2023), RedReplicant (03-15-2023) |
03-19-2023, 10:56 AM | #650 |
86cup round 4
CVR CCW SX2s 245-40-17 2:09.3 with optimal at a 2:08.1 Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
03-20-2023, 12:29 PM | #651 | |
03-20-2023, 12:52 PM | #652 |
Drives: None
Yeah, here you go I'm going to try and make the Chuckwalla 86Cup events in December this year. Maybe our schedules will align
The Following User Says Thank You to RedReplicant For This Useful Post: | jflogerzi (03-20-2023) |
03-27-2023, 10:10 PM | #653 |
Plan to be there as it's the last events
The Following User Says Thank You to jflogerzi For This Useful Post: | RedReplicant (03-28-2023) |
03-28-2023, 11:43 AM | #654 |
Drives: None
Attesa CCW / Podium Club in Arizona
TT5 record 1:41:579 on amb official timing 205whp / 2880lb on the scales after this lap / 4" flat splitter / Verus High Efficiency Wing / 255 Maxxis RC1
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | Nick Dugdale (04-16-2023), Pat (03-28-2023) |
03-28-2023, 12:45 PM | #655 |
how do you like the HE Wing? I am eyeing this very hard!
03-28-2023, 02:29 PM | #656 |
Drives: None
I like it a lot.
The car feels pretty aero balanced with it set one below max AoA (12* by the Verus chart). Going to max AoA noticeably makes the car pretty pushy, I haven't done a coast down test or set it to 0 AoA on a long straight to test what it is worth MPH wise though. When I compare data to my friend's TT5 GR86 he is seeing 5-7mph faster down a ~120mph straight than I am even with a couple mph lower entry speed. (117-118mph vs 124-125mph), but he is making 10whp peak more than I am and doesn't have aero. Looking at the data that Verus has available it seems like 4* on the UCW is roughly close to the HE at 12* DF wise, but the drag looks like a toss-up. I definitely don't need the extra DF the UCW can make since I have no way to balance it. A fair number of people have made fun of the wing in person at the track, but that doesn't mean much to me
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | jflogerzi (03-30-2023), staples323 (03-28-2023) |
04-02-2023, 02:41 PM | #657 |
New 86Drive Challenge Street class record yesterday with a 2:01.66 at Buttonwillow CW13. Conditions were good in the first session. This lap is actually my second fastest, a 2:01.67, but the footage was a bit better and lap cleaner.
I also threw on some 255 V730s and went sub 2 in the second session, video from that coming later. |
The Following 2 Users Say Thank You to Will_ For This Useful Post: | jflogerzi (04-02-2023), RedReplicant (04-02-2023) |
04-03-2023, 01:18 PM | #658 |
Drives: 01 911 Turbo, 03 G500
2023 GR86
Palmer Motorsports Park Stock MPS4. Only upgrades are C1/C11 Pads, SRF and SPC Camber Bolts First day here in ~ 5 years, 4th track day in the GR 1:56.96 |
The Following User Says Thank You to smoltz For This Useful Post: | RedReplicant (04-03-2023) |
Similar Threads | ||||
Track Brake Pad Discussion Thread | CSG David | Tracking / Autocross / HPDE / Drifting | 420 | 02-06-2023 08:55 PM |
S2000 vs BRZ at the track: track oriented discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 33 | 01-13-2013 06:54 PM |
Mike's track videos. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-16-2012 04:00 AM |
Scion Canada FR-S Track Day Videos! | DjDATZ | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 22 | 08-13-2012 11:51 PM |
Track/Racing Discussion | Allch Chcar | Tracking / Autocross / HPDE / Drifting | 9 | 05-26-2012 04:39 PM |
