07-11-2022, 11:41 AM | #911 | |
1st86 Driver!
I doubt this will happen, and if it does, it will likely be more or less a placebo. Even the Toyota patent you reference seems to just be "faking" gear changes. I understand some people are MT or die, and I get that and if that's what is wanted, and there is enough market for it I hope it happens for those that want it. I would think though that ones that want it, would want it to actually do something and not simulate something.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (07-11-2022) |
07-11-2022, 12:28 PM | #912 |
Drives: '23 BRZ
For my electrified SV650 motorcycle build, I kept the transmission, but motor placement precluded use of the clutch. Clutchless up- and downshifts are no prob with the sequential gearbox tho Fun...
07-11-2022, 01:16 PM | #913 | |
Drives: Crapcan
OooooOOOoo Pics ?
07-11-2022, 03:29 PM | #914 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | NoHaveMSG (07-11-2022) |
07-11-2022, 04:20 PM | #915 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Pedals + shifter attachment to the chair, steering wheel attached to the desk and you can play gran turismo or Forza like a real racecar driver including real shifting and pedal modulation action! It'll feel exactly like playing a video game rather than driving an actual car. |
07-11-2022, 05:20 PM | #916 |
Drives: '23 BRZ
Well, you asked! This was a while back, 2010? Damn...
Here it is with some body panels expertly painted satin black by me: If you like yo pixels BIG: I was working at a now long since defunct electric vehicle company called Vectrix. Basically I removed the cylinder heads, hacked off 2/3 of the crankshaft and made a coupler and bolted a Vectrix motor up. ~28hp at ~5500rpm. Similar torque to SV650, but you gotta shift WAY sooner! Battery pack is NiMH, so *heavy*. I might be about to rebuild it with Li batteries and cut about 100 lb. out. Yeah.... |
The Following 6 Users Say Thank You to ZDan For This Useful Post: | bcj (07-11-2022), Dadhawk (07-11-2022), Kiske (07-12-2022), NoHaveMSG (07-11-2022), soundman98 (07-11-2022), TurboLag23 (07-12-2022) |
07-11-2022, 05:30 PM | #917 | |
Drives: Crapcan
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
07-12-2022, 09:28 PM | #918 | |
Drives: 2018 BRZ w/Performance Package
2. Adding a mechanical manual trans & clutch to an EV does not make any engineering sense - it's purely an emotional decision. Any increases in efficiency from being able to optimize gear ratios would likely be offset by the additional weight, but whatever - it's more fun! It is not "simulating" shifts - you are very much still driving a manual car, just without the idle! I've ridden in an EV-swapped Karmann Ghia, and it is truly sublime. You don't need to clutch out from a stop, but you should definitely still use clutch between gears. If the electric motor's redline mimics that of the ICE it replaces, your shift points don't even need to change that much; you just need to optimize for the electric motor's powerband. But you will definitely want a more robust clutch - aforementioned Karmann Ghia blew its first (stock) clutch into a million pieces a few miles into its maiden voyage because of all the torque! It now has a competition-spec clutch and has been going without a problem. Here - watch this for more details: One last point: a super-easy way into auditory feedback in a manual EV is to just switch the motor/trans mounts to polyurethane or solid metal, to transmit more whine into the cabin. |
07-13-2022, 03:40 PM | #919 |
Drives: 2020 BRZ/86, 2020 BMW 330i
07-13-2022, 03:49 PM | #920 |
07-14-2022, 01:28 PM | #921 |
1st86 Driver!
More good charging news thanks to Federal funds. Not only is Tesla getting ready to open up charging in the US to all vehicles, but GM/evGo and Pilot/Flying J are installing 2,000 charging units at the 500 outlets along the Interstate Highways.
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (07-15-2022), ZDan (07-14-2022) |
07-16-2022, 12:01 AM | #922 |
Drives: Q5 + BRZ + M796
Lots wrong here. For instance, lithium ion holds a charge extremely well. Cars have battery drain in Sentry mode or for other reasons, but they can be charging when parked, or a service can charge the car for you remotely, if someone was worried. They already have these services. But a car really only loses 2-3% per month sitting, so I don’t know where he is getting his numbers. My motorcycle sat for over a year with a Shorai lithium iron battery without a trickle charger and active immobilizer and started right up.
Dude assumes a lot. 18 wheelers could do battery swapping and have the batteries charge slower and at night and not need fast charging. Lithium sulfur and sodium sulfur batteries could dramatically change EV potential, including cost, longevity, performance, material ecology and sustainability, cut weight by a third or triple range, etc. To think things will stay at the current standard is silly. Oil isn’t renewable, so it isn’t sustainable. It is also better to drive an EV with today’s batteries on coal electricity than a similar ICE, and all that only improves with renewables and lithium/sodium sulfur batteries or whatever they come up with. Oil is also more volatile than electricity. Lithium, sodium and sulfur will need to ramp up, as demand will likely spike and so will costs, but the long term is a more stable product. Recycling will definitely ramp as well. The best recycling is reuse for things like grid storage or to those who require less range, but recycling will be huge, as it is already progressing. The best thing he said was recognizing that housing is a big part of the solution. We need more multifamily homes and less urban sprawl for sure.
07-16-2022, 12:23 AM | #923 |
So much wrong and outdated thinking with redundancies already mentioned. And no, old cars aren’t better than new cars or EVs.
07-16-2022, 01:22 AM | #924 |
Lol, "engineering explained", ev shill disguised as car enthusiast.
The Following User Says Thank You to Arthur-A For This Useful Post: | soundman98 (07-16-2022) |
Similar Threads | ||||
Tcoat banned? | Hotrodheart | Off-Topic Lounge [WARNING: NO POLITICS] | 95 | 07-06-2019 01:46 AM |
Does anyone know why pansontw got banned? | Soloside | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 10-26-2018 04:20 AM |
Got banned from gf's complex | jdmblood | Other Vehicles & General Automotive Discussions | 11 | 07-12-2015 12:46 PM |
Why have so many users been banned? | xuimod | Site Announcements / Questions / Issues | 9 | 03-08-2015 02:23 PM |
Banned Toyota GT 86 Advert Banned | Nevermore | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 11-16-2012 07:27 PM |
