06-20-2021, 08:09 PM | #1 |
Drives: 2020 BRZ (Black)
Two amps for sale, ed NINe.2 and cadence SQA-4
Located in Alamogordo NM, pick up preferred but you can pay to ship
ed NINe.2: $75 (other offers will be considered) Cadence SQA-4: $75 (other offers will be considered) Both amps for $130 Both amps are in good operating condition, and have never been overdriven. Both have been owned only by me. Original documentation included. NINe.2 Specs: 2 x 100 @ 4Ohm 2 x 200 @ 2Ohm 1 x 400 @ 4Ohm Height : 2.25 Width : 9.85 Length : 12 Signal to Noise Ratio -95dBA Variable Input Sensitivity 150 mVolt - 7.0V Remote Variable Input Sensitivity No Variable Low Pass X-Over 40-240 @12dB Current & Thermal Protection Yes Remote Bass Equalization No Variable Phase Control Yes Master / Slave Option No Efficiency 68% Variable SubSonic Filter N/A Fuse(s) 2 x 25 Max Current Draw 49 Amps Damping Factor 300 Cadence SQA-4 Specs: 4 Ohm RMS Power: 4 x 60 Watts @ 13.8 Volts 2 Ohm RMS Power: 4 x 100 Watts @ 13.8 Volts 4 Ohm Bridged RMS Power: 2 x 200 Watts @ 13.8 Volts Frequency Response: 20Hz - 30kHz S/N Ratio: >100 db Damping Factor: >200 @ 100Hz Minimum THD: <0.05% Input Voltage: 200 mV - 8 Volts Dimensions: 13" x 11" x 2.75" Last edited by Hurricane Nate; 06-21-2021 at 08:51 PM. Reason: Updating terms |
Similar Threads | ||||
A question on Add-a-Circuit fuse tap amps | chipmunk | Electronics | Audio | NAV | Infotainment | 12 | 05-20-2021 06:33 PM |
FS: Multiple OEM Amps, good SRS module | Dave-ROR | Audio/Visual, Electronics, Infotainment, NAV | 0 | 12-02-2020 12:56 AM |
custom sub box w/ subs amps for sale | BoostFed86 | Hawaii | 1 | 06-07-2017 10:00 PM |
2 X 12" Subs, 2 X Amps and NOS | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 04-28-2013 10:38 AM |
ZED amps | brianlo622 | Electronics | Audio | NAV | Infotainment | 3 | 10-11-2012 10:00 PM |
