05-08-2020, 04:53 PM | #1 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Leaky Quick Jack couplers
Here's some information and pics regarding the quick disconnect couplers on the Quick Jack BL-5000SLX Car Lift (I would assume all models of Quick Jack use the same coupler)
After 2.5 years of occasional use, I had a set of couplings fail. Half of a torn O-ring from inside the male coupler got stuck inside the female coupler so both were leaking. I contacted Bendpak (https://www.bendpak.com/support/) and since my unit was out of warranty, I was given the option to purchase a new set for $79.99 plus shipping....I said no thanks. At the time I thought I needed 2 sets so that wasn't happening. So there's option 1, buy a new set from Bendpak and move on with your life. I didn't like option 1 so I went on a hunt for a suitable replacement online. Turns out, finding the correct set is not as easy as one would think. Here is what I found. The couplers are ISO 16028, 1/4" NPT Thread, 1/4" Body, flat face couplers and can be purchased on Amazon from Summit Hydraulics for $34.95. I like option 2. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 So while I'm waiting for the parts to come in, of course I had to go and "dig" a little deeper. Turns out, I was able to remove the torn O-ring from both halves and with a little finesse, replace the O-ring with a common size from the local home improvement plumbing department. It happens to be a #7 O-ring, 1/2" O.D. x 3/8" I.D x 1/16". I found that I had to remove the white plastic "retainer" first, work the new O-ring into place, then re-insert the white plastic retainer on top of the new O-ring. It's kind of delicate work so if you have big 'ol sausage fingers, you might be better off with option 2. |
The Following 5 Users Say Thank You to BirdTRD For This Useful Post: | bcj (05-09-2020), Overdrive (05-10-2020), sneaky_pete (07-20-2021), soundman98 (05-10-2020), Ultramaroon (05-10-2020) |
05-10-2020, 06:46 AM | #2 |
Drives: MY14 86 GTS Manual Velocity Orange
good work - bit of DIY saves the day and your wallet!
The Following User Says Thank You to sneaky_pete For This Useful Post: | BirdTRD (05-10-2020) |
05-10-2020, 10:25 PM | #3 |
義理チョコ
Fantastic! I have one that had damaged threads out of the box. I cuss at it every time I clean up the little red puddle. :/
I love your jig, BTW. Stealing that too.
The Following User Says Thank You to Ultramaroon For This Useful Post: | BirdTRD (05-11-2020) |
07-17-2021, 02:26 PM | #4 |
Drives: 08 335xi
Thanks!!!!
This also applies to Ranger QuickJack lifts. Thanks so much for posting this! It just saved me a boatload of time trying to measure a ripped o-ring, and saved me $45 to $80!!!!! Why buy a pair of whole fittings when the problem is just an 18 cent o-ring!!!!!
The Following 2 Users Say Thank You to atrank For This Useful Post: | soundman98 (07-17-2021), Ultramaroon (07-19-2021) |
Similar Threads | ||||
Changing oils by myself, are these a recommended jack+jack stand? | btan219 | BRZ First-Gen (2012+) -- General Topics | 67 | 10-23-2021 03:54 PM |
Leaky Exhaust | Steveiam | Engine, Exhaust, Transmission | 3 | 09-08-2019 04:45 PM |
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
Any TSB recalls for leaky cam plate / oil leaks? | radroach | Issues | Warranty | Recalls / TSB | 0 | 12-05-2014 05:18 PM |
Possible Leaky Taillight Fix | Sco2355 | Issues | Warranty | Recalls / TSB | 6 | 02-18-2013 02:26 PM |
