Old 06-02-2021, 05:36 PM   #29
CSG Mike
CSG Mike's Avatar
Check this out.
https://www.ft86club.com/forums/showthread.php?t=126107
Old 06-02-2021, 11:27 PM   #30
jflogerzi
jflogerzi's Avatar
Really enjoy my ss1's. If you need camber it's great setup. Tien flex As are good as well
2013 Series 10 FRS #553
Old 06-03-2021, 03:34 AM   #31
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I'm surprised nobody has asked this, but what are the exact clicks you have your coilovers set at front & rear? And what tires pressures? From other reviews I've read about the RS-R's, they can be set to ride similar to stock comfort.
The Following User Says Thank You to NLSP For This Useful Post:
StraightOuttaCanadaEh (06-03-2021)
Old 06-03-2021, 10:12 AM   #32
ninzuh
If you're on a budget, I'd recommend the 17+ struts with RCE Yellow lowering springs. If you you're willing to spend a bit more, the Bilstein B6's with RCE Yellows is a popular pairing as well.
I have the 17+ struts and the Yellows on my 2013 and the the ride quality has definitely improved from stock while dropping it a little bit and giving it a nice look and better turn in.
You do lose the adjustability from a coilover but for the money, I think it's a perfect street setup.
ninzuh is offline   Reply With Quote
The Following User Says Thank You to ninzuh For This Useful Post:
Thefalls (06-04-2021)
Old 06-07-2021, 12:27 AM   #33
jflogerzi
jflogerzi's Avatar
This is an excellent setup. Ran this before I got my RCE SS1. If you need or want camber get some peddler top hats and crash bolts
Old 06-11-2021, 09:53 PM   #34
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Only one pic showing the two piece design.
Xida/949 is two piece as well, even on the Miatas the lower mount is threaded. It's not the devil and everything has some form of compromise, even $10k Penske's aren't magic.
That is incorrect. All Xidas are one piece.
Our lower mount is simply built into the cap and has a lockring so it looks similar to the Asian shocks that use an adjustable threaded adapter on a sealed cylinder. The Asian shocks are complete and sealed then they thread a separate mount adapter on the bottom. In their marketing that is a "feature".
The Xida cap is not removeable or adjustable. All one piece aluminum race shocks have a cap on the otherwise open cylinder.
If the lower cap can actually be removed without opening the shock, it's a two piece shock.
If the lower cap seals the cylinder, keeps the oil in and is not adjustable, its a one piece shock.
I prefer to call the two piece shocks "length adjustable" and one piece "non-length adjustable". If both types have threaded bodies, they have adjustable preload of course.
949 Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to 949 Racing For This Useful Post:
churchx (06-12-2021), norcalpb (06-13-2021), strat61caster (06-11-2021)
Old 07-27-2022, 04:31 PM   #35
Amputechture
Drives: 2014 BRZ
This is the first I've seen RSR spoken of as low end and uncomfortable...I was actually under the impression they had the reputation of having one of the softer rides due to their rubber inserts? Been trying to decide between Sport-I and the rce ss1...
Amputechture is offline   Reply With Quote
Old 07-27-2022, 07:51 PM   #36
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
RCE SS1 all the way. More travel than RSR, specialized valving and quiet camber plates.
Lincoln Logs is offline   Reply With Quote
The Following 3 Users Say Thank You to Lincoln Logs For This Useful Post:
Amputechture (07-28-2022), kevaughan (07-30-2022), Racecomp Engineering (07-27-2022)
Old 08-02-2022, 06:03 PM   #37
Amputechture
Drives: 2014 BRZ
Right on, ordered a set of ss1s earlier.
Help needed BC BR Coilovers too bouncy 8k! CoryeWest Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 10-25-2018 01:18 PM
FR-S owner's bumpy ride crushes through the cracks of the streets SquadRon Off-Topic Lounge [WARNING: NO POLITICS] 43 07-10-2016 06:14 PM
FR-S/BRZ Vs. 2015 WRX ride quality rennlistuser3 FR-S / BRZ vs.... 65 01-11-2016 11:33 PM
Reducing bumpy ride with sportline springs Lemar58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-11-2013 09:24 AM
How harsh is the ride on 18" vs 17" wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-18-2012 03:08 PM
