06-21-2022, 09:11 PM | #995 |
Yeah Mishimoto did some dyno testing on the resonator chamber on the 1st gen and found it was good for a few hp on the top end. It's not a huge difference though so I could see someone deleting it if they really wanted the extra sound.
2022 BRZ Build 2013 FR-S Build |
06-21-2022, 10:53 PM | #996 | |
Drives: zd8 brz
I’m considering printing a few and selling them for cheap to those who don’t want to dish out the $100ish for the GS pipe and those who prefer keeping the engine bay looking stock… this is all assuming it does make an actual difference in sound. It likely won’t make a noticeable difference in power loss(if there is a loss) Losing 2-3whp isn’t gonna change my life and I’m not a fast enough driver on track to need every ounce of power from this car |
06-24-2022, 01:22 PM | #997 |
Drives: 2022 Subaru BRZ 6MT IR
Just curious about your printer/settings. Solid ABS or with infill?
2022 BRZed, Red, Base, Manual, Simple
06-24-2022, 04:51 PM | #998 | |
Drives: zd8 brz
50% infill with 4mm walls. unsure of his temp settings. its not perfect by any means and is a very rough print. definitely strong enough to withstand some clamping force and heat i might even try PETG. it would be able to handle higher temps |
06-24-2022, 05:23 PM | #999 | |
Drives: 22 BRZ limited
06-24-2022, 05:42 PM | #1000 |
Drives: 22 BRZ
Real exciting stuff here... got the oem sunshade, Part Number: SOA3991530.
Works as advertised. |
The Following 2 Users Say Thank You to AK2112 For This Useful Post: | soundman98 (06-24-2022), Xed32 (06-24-2022) |
06-24-2022, 05:47 PM | #1001 |
Drives: Mini
06-24-2022, 10:44 PM | #1002 | |
Drives: zd8 brz
i had a PLA cupholder in my 996 that i printed and it survived a whole california summer being parked outside with untinted windows. PLA has a far lower melting point than PETG does. PETG is a bit more flexible than PLA which is why it may seem to deform more easily especially it's relatively thin in structure or isnt nearly solid. Interior parts also resort to A LOT more heat than people think.. far more than IATs. This plug being in the intake will have constant air flowing near and around it which should keep it safe. I think a few companies even offer PETG fluid cap sets(brake fluid reservoir cap, clutch fluid reservoir cap and Washer fluid cap) that have been tested and proven for a few years now |
06-25-2022, 08:48 PM | #1003 |
Really happy with the face on the car now. Decided to take a hole saw to the tow hook cover so I could reinstall it behind the license plate relocate. The "BRZ" plate is Billetworkz, fits the factory threaded inserts and covers the holes left by the dealers self-tappers. I never thought I'd like a relocate kit, but I was proved wrong.
Got the Perrin trunk handle installed, in a completely incorrect manner, but it holds really well.
06-25-2022, 08:55 PM | #1004 |
Drives: "I drives like a Porsche"
I have the same color car in the same sunshade.
The Following User Says Thank You to Liquidsnake For This Useful Post: | AK2112 (06-26-2022) |
06-26-2022, 04:53 PM | #1005 |
Drives: 22 BRZ
First oil change. Castrol Edge and a Subaru filter. Nice and easy.
06-26-2022, 05:24 PM | #1006 |
Drives: 2022 BRZ Limited 6MT; '05 OB 5MT
Finally had a chance to catch my breath and post today!
One of the more recent things I did was install the Greddy hood dampers. These are specific to the Gen 2 cars and I had to wait several weeks for them to come in from Japan as I couldn't find any US vendors selling them. Overall very pleased, they look and feel great, and I love not having to fiddle with the hood prop anymore! |
The Following 6 Users Say Thank You to Rallywhale For This Useful Post: | DarkSunrise (06-27-2022), DocWalt (06-28-2022), jongers (06-26-2022), Panda Grahams (06-29-2022), Stonehorsw (06-27-2022), weederr33 (06-28-2022) |
06-26-2022, 05:50 PM | #1007 |
Drives: 19 86, 22 BRZ
Passenger RSG-K installed a couple days ago:
Waiting on amazon for another 3.3 ohm resistor for the passenger side to get rid of the airbag light. Does anyone have experience with the new gens and how the passenger seat sensor works? Will I need to remove the sensor sheet/membrane from the stock seat and put that into the aftermarket seat to get the airbags working on the passenger side?
06-26-2022, 05:51 PM | #1008 |
Camber bolts installed, and I'm getting an alignment in just over a week.
Trying to make future plans for wheel spacers, and I've run into a problem. I want to run 20mm all around, but the stock studs are 25mm long. Unfortunately my winter wheels (steelies from an XV Crosstrek) have absolutely no clearance for studs poking thru spacers (whereas the stock 17s on my car have 8mm clearance). So thats annoying. And running 25mm spacers makes me concerned that the studs might be ever so slightly longer than the spacer, causing the wheel to sit crooked.
Similar Threads | ||||
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
