Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-27-2014, 06:29 AM | #1 |
Drives: AE86, 2x GT86, TE27
Essex endurance brake kit.
So I'm pretty close biting the bullet and getting the essex endurance kit for my track car.
Just wished there were more reviews and feedback on here. Lots of info about the sprint kit, not so much on the endurance kit. Any info I'm missing..? Feel free to PM me if you'd rather. |
05-27-2014, 06:46 AM | #2 |
Wheel size (aren't you running 16s?)and the ducts/ducting (with pipe routing for FI) apparently could be an issue but I forgot as I gave up on the endurance kit.
@CSG Mike would probably know.
05-27-2014, 06:57 AM | #3 | |
05-27-2014, 09:31 AM | #4 | |
Drives: 2012 BRZ Premium WRB 6MT
As mentioned above, the only "downsides" to the Endurance Kit vs. the Sprint Kit are as follows (keep in mind these are only "downsides" if you don't need the added thermal mass and cooling of the Endurance Kit!):
Your performance expectation when purchasing the Endurance Kit should be the same as if you were buying the Sprint Kit. The calipers in both kits are essentially identical, and the disc hat and brake line designs are also basically the same. All of the positive reviews and feedback we get on the Sprint Kits still hold true, you're just getting a few added features as a bonus:
Most of our FT86 customers have sub-350 whp, and most only run track sessions in the 20-30 minute range. For those individuals, the Sprint Kit is the correct solution that we push them towards, and that's why you see more feedback on it. If you plan to exceed those HP numbers or run true endurance racing, then the Endurance Kit will be the proper fit. I think as the FT86 platform matures, we'll see more feedback on the Endurance Kit. Now that the platform is a couple of years old people are really starting to push the power levels up, developing the chassis further, doing more engine swaps, etc. As that occurs brake demands & requirements will also increase stepwise. Hopefully that all makes sense. Either of our Competition Kits will get the job done, it just depends on where your needs lie now, or where they will lie in the future as you develop your car.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com |
The Following 8 Users Say Thank You to JRitt For This Useful Post: | diss7 (05-27-2014), gramicci101 (05-27-2014), GT86_PRAGUE (09-14-2015), mokinbird87 (09-10-2014), R2RO (09-03-2014), s2d4 (05-27-2014), saj (04-07-2016), SubieNate (06-01-2014) |
05-27-2014, 11:02 AM | #5 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
The Following User Says Thank You to dradernh For This Useful Post: | CSG Mike (05-27-2014) |
05-27-2014, 01:40 PM | #6 |
We'll be putting an Endurance kit through it's paces later this year
Right now, we're busy finishing up some other projects, but I have absolute confidence that the Endurance kit will work great. |
05-27-2014, 01:57 PM | #7 |
05-27-2014, 03:29 PM | #8 |
05-31-2014, 10:07 PM | #9 |
What about endurance racing, well semi-endurance, they're one hour sessions; NA power (because class racing) Car + driver weight + full tank = ~1200kg, and on 24/61-17 full slicks?
My worry with the sprint kit is that I will find its limit and wish I had gotten the endurance kit. The endurance kit has greater thermal capacity, and even then, has a provision for ducting. But it pays a weight penalty for that. Weight is something I'm equally focussed on. I feel like if there was a sprint kit, with the same provision for the brake ducting as the endurance kit, that would be the kit for me. #firstworldproblems |
The Following User Says Thank You to diss7 For This Useful Post: | s2d4 (05-31-2014) |
05-31-2014, 10:21 PM | #10 |
ditto on this one.
06-01-2014, 07:22 AM | #11 |
Does anyone know the piston sizes of the sprint and endurance kits? I've looked everywhere, and can't find that info.
There is some info on the standard pistons sizes (38.1mm and 41.2mm in the sprint caliper) but are these the sizes used in the gt86 application? Cheers Last edited by diss7; 06-01-2014 at 07:33 AM. |
06-01-2014, 09:51 AM | #12 | |
You'll probably be cheaper in the end even with increased costs for rotors since you'll probably be going through less of them than you would be with the sprint kit running so close to it's limit.
04-07-2016, 02:36 AM | #13 |
Drives: 2015 frs
CSG Mike I was looking at getting the endurance kit I saw that you stated 17x9 35 RPF1's would fit with 3mm spacers in another thread. Have you seen it done, and how was the fitment in regard to fender clearance? I asked the question in another thread and got no response. Im between the rpf1's and the mach V 17x9 any input would be greatly appreciated.
04-07-2016, 03:54 AM | #14 |
Because compromise ®
Drives: Red Herring
When addressing someone do it like this: @CSG Mike
That way Mike will get a notification that he has been named/called.
Similar Threads | ||||
Winmax USA Brake Pads - Street, Autocross, Track, Endurance! | CSG David | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 65 | 07-04-2016 09:59 AM |
All Essex/AP Racing BBK owners (Sprint & Endurance) please read | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-18-2015 10:16 AM |
CMS SEMA 2013 Coverage - AP Racing Sprint and Endurance Kits by Essex Parts | Circuit Motorsports | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-16-2013 04:08 AM |
AP Racing / Essex brake kits fit 16's? Yes! And even 15's!! | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-06-2013 07:07 PM |
Essex Competition Brake System (Endurance) fitment on 18x8.5 57Xtremes | Supermassive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-10-2012 02:08 PM |
