Engine Swaps Discussion of engine swaps. |
07-02-2020, 01:52 AM | #15 | |
Drives: 13 BRZ
Your build sounds pretty awesome. Looking forward to seeing it done! Engine I have is actually a freshly rebuilt used engine from a race team I used to work for that works closely with Katech. It’s a pretty mild build. Stock bore with Mahle forged pistons, arp rod bolts, comp cams “hot-cam” 219/228 @ .050 with .525/.525 lift 112 LSA, Katech cnc ported heads, GM blue valve springs, 3/8” pushrods, and a high volume oil pump. It dynoed at 511 hp and 495 ft-lbs (at the crank). |
The Following User Says Thank You to kask2_6.0 For This Useful Post: | GrabTheWheel (07-02-2020) |
07-04-2020, 12:14 AM | #16 |
Drives: 13 BRZ
Got the wiring bulkheads installed today. Happy with how it turned out.
The Following 4 Users Say Thank You to kask2_6.0 For This Useful Post: |
07-05-2020, 09:24 AM | #17 | |
Drives: 2017 series yellow BRZ
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
07-23-2020, 12:09 PM | #18 | |
Drives: 13 BRZ
Both Vorshlag and Sikky swap components seem to be very high quality. There are pros and cons to both of them but I don’t think you can go wrong either way. I spent a lot of time going back and forth between the two but ultimately decided on Vorshlag for my build. |
07-23-2020, 12:20 PM | #19 |
Drives: 13 BRZ
Was able to get enough header clearance using a xrp ultra low profile orb fitting (pn: 989110). Have almost 1/2” clearance now.
[IMG]https://uploads.tapatalk-cdn.com/20200723/d6e663a54256b568aac294c9ff5***9f.jpg[/IMG] Also got these super trick stage 8 locking header bolts |
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post: |
07-26-2020, 06:10 PM | #20 | |
My BRZ Build Thread
11-26-2020, 10:31 PM | #21 | |
Drives: 13 BRZ
With the Vorshlag setup the biggest con is the engine is a bit forward versus the sikky mounts. Other than that everything seems pretty nice. |
11-26-2020, 10:44 PM | #22 |
Drives: 13 BRZ
Finished the dash assembly today. I’m using the Aim pdm32 with 6” dash.
Also made a new mount for the remote battery terminals and upgraded to Motorsport grade 1/0 cable from cheaper grade 2 ga. Battery located in the trunk with msel master relay. Previously had battery grounded in the trunk but now the grounds runs up to the terminal post. My car has always cranked a bit slow since the battery relocation and the ls3 would be even worse. |
12-01-2020, 12:42 AM | #23 |
Drives: 2014 BRZ
Sub'd
12-01-2020, 01:04 PM | #24 |
Drives: 2013 Ultramarine FR-S
Really amazing work. Excited to see more.
12-06-2020, 12:52 AM | #25 |
Drives: 13 BRZ
Needed a new project... LS3 soon!
Got some arp bolts and a bunch of parts back from cerakote today. Really liking how everything came out. Wanted to go with a color a bit out of the ordinary. Kinda looks brownish in a couple of the pics but the color looks really good in person and especially so in direct sunlight.
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post: | Irace86.2.0 (12-06-2020), Lonewolf (12-09-2020) |
12-20-2020, 11:47 PM | #26 |
Drives: 13 BRZ
eBay subframe modified for Vorshlag mounts. Dropping it off for powder coat tomorrow.
PDM and ECU mounting. Sent from my iPhone using Tapatalk |
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post: | Irace86.2.0 (12-22-2020), Mike_ZN6 (01-12-2021) |
12-22-2020, 10:18 PM | #27 |
Drives: Q5 + BRZ + M796
Very slick setup. What is the box in front? It looks like an airbag by the circular shape and connectors.
12-23-2020, 01:59 PM | #28 | |
Drives: 13 BRZ
You’re correct. Motec mounts under/behind the passenger airbag. Not a ton of options under the dash there it’s pretty tight. Sent from my iPhone using Tapatalk |
Similar Threads | ||||
What is needed for | Aluma007 | Engine, Exhaust, Transmission | 9 | 11-25-2018 02:20 PM |
Electric Power Steering Adjustment Project - Help Needed | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 12-07-2015 07:34 PM |
Logged Track Time Datasets Needed for my Web Project! :) | Zamyatin | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-11-2015 01:59 PM |
HELP NEEDED!!!! | sklimo | Issues | Warranty | Recalls / TSB | 26 | 06-14-2013 11:48 AM |
MOD's Needed. Help Please! | GT-ROKIN | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-06-2012 01:18 AM |
