Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-12-2024, 11:52 AM | #141 | |
However I had 2013 STi springs paired with B6 dampers and it felt awesome. Soft yet surprisingly retained its sportiness. I think you are on to something with pairing a stiffer spring with the B6 to match things up a bit better. |
The Following User Says Thank You to norcalpb For This Useful Post: | JIM THEO (03-12-2024) |
03-12-2024, 12:33 PM | #142 | |
Drives: BRZ 2018
How much lowered compared with the factory height was with this setup, do you remember? I guess the STI springs you mention were from the STI Bilstein kit not the STI Showa-pinks, nor the aftermarket STI pinks intended for the OEM shocks right? |
03-12-2024, 12:49 PM | #143 |
Yeah it's certainly not just the bumpstops that make it feel that way!
FWIW I did not have a noticeable ride height change with my Bilstein B6. If there was one at all it was less than 5mm. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | ZDan (03-12-2024) |
03-12-2024, 01:16 PM | #144 | |
Just the tip
Drives: 2017 DGM BRZ
I've got 140k kms on my original shocks and they are getting pretty tired. Considering upgrading to the B6's and keeping the Eibach pro kit. Ride height change by a few mm isn't an issue to me. A little higher would probably be nice in some scenarios... I just barely get into my underground parkade as is without scraping. |
03-12-2024, 06:15 PM | #145 | |
Drives: 2020 BRZ tS
If you are looking for daily driver comfort, I'm not sure they are worth the money. Best bet might be picking up some gently used SACHS. Negligible downgrade in performance and can probably had much cheaper. I was expecting more for the price. Maybe they are better paired with H&R Springs or something else. |
03-20-2024, 04:53 AM | #146 | |
Drives: '23 BRZ
Anyway I have a set I would sell for a lot less than used Bilsteins. Because they aren't *nearly* as good, on the street or at the track. Not even close... |
03-20-2024, 05:43 AM | #147 |
Drives: 17 Asphalt 86
For comfort the base 17-20 shocks ride quite nice. Probably go that route if you wanted comfort.
The 2022+ shocks are apparently even softer for the street, that could be an option too |
03-24-2024, 08:00 AM | #148 | |
Drives: Transit Campervan / Turbo GT86
Hello Andrew, what's the highest spring rate the B6's can handle? Andrew |
03-25-2024, 09:58 AM | #149 |
03-25-2024, 10:10 AM | #150 |
The Following User Says Thank You to tekno For This Useful Post: | Racecomp Engineering (03-25-2024) |
03-26-2024, 07:05 PM | #151 | |
Drives: BRZ 2018
According to this video (at 56"): Pink STI springs from the Bilstein/STI kit are 25% harder than the base 2013 BRZ springs rates: 27Nm front - 34Nm rear! So actual spring rates or I'd say "wheel spring rates" for the Bilstein/STI kit are 33,75Nm front - 31,8Nm rear, not bad for my use, while my current springs from the 2018+ tS are 26Nm front - 28,35Nm rear! |
The Following User Says Thank You to JIM THEO For This Useful Post: | norcalpb (03-27-2024) |
03-26-2024, 08:26 PM | #152 |
What kind of durability is expected out of these? I've got about 70,000km on my set now. 99% daily use.
Suggestions for places to service them as needed? |
03-26-2024, 10:01 PM | #153 |
Drives: 2023 BRZ
100,000 with ease
Sent from my Pixel 7a using Tapatalk
Director of Rocky Mountain 86CUP
The Following 2 Users Say Thank You to Pat For This Useful Post: | RToyo86 (03-27-2024), strat61caster (03-27-2024) |
03-27-2024, 01:55 AM | #154 |
https://bilstein.com/en-us/contact/
Contact Bilstein for service, last I checked they referred me to PSI in Sonoma. |
The Following User Says Thank You to strat61caster For This Useful Post: | RToyo86 (03-27-2024) |
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
