Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-03-2020, 09:45 AM | #29 | |
That plus you have to make sure your using high quality bearings. If driving in wet/salty/dirty conditions you'll need to replace the bearings a little sooner. They'll last longer with rubber booties. If it's a control arm with adjustable rod ends, it's pretty easy and cheap to service. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | new2subaru (12-03-2020) |
12-03-2020, 09:46 AM | #30 |
12-05-2020, 08:44 AM | #31 |
Drives: 23 BRZ 15 Impreza
Rallispec has a decent list for the STI hardened suspension bushings. http://rallispec.com/mou_bush_rstbkbrz.html
The Following User Says Thank You to cueball89 For This Useful Post: | Capt Spaulding (12-05-2020) |
12-21-2020, 04:07 PM | #32 |
12-21-2020, 10:05 PM | #33 | |
2013 Series 10 FRS #553
12-22-2020, 10:22 AM | #34 |
Nah that's not too bad...at first...but then you add installation cost to all of that and it does add up to be quite a bit.
There are a few spots where it makes more sense to replace the full arm or component instead with STI or aftermarket. - Andrew |
12-22-2020, 05:32 PM | #35 |
Drives: FR-S Whiteout
A little update on the whiteline front lower control arm bushings. So far so good. Steers straight even with a bit of toe out. No darty feeling with 1/8” of toe out before I put it back to 0°
Not quite sure how I feel about how the bushing and the control arm is held in place, but no problems so far.
Intent > Content
cowardice is the mother of cruelty. |
12-28-2020, 01:10 PM | #36 |
12-28-2020, 02:29 PM | #37 |
You are an absolute legend. Seriously cannot thank you enough for this (as well as help you've provided in other threads.)
The Following User Says Thank You to ninzuh For This Useful Post: | Racecomp Engineering (12-28-2020) |
02-13-2021, 08:35 PM | #38 |
Drives: 13 FRS
I need to replace the rear subframe / diff bushings on my car.. but after watching how-to's i realized this is outside my paygrade and i don't have the necessary tools
A shop will be doing the bushings for me. Is there anything else I should have them replace while the rear-subframe is out? I can do shocks and end links and LCAs and what not myself. but any parts i can hand them while they got the subframe bushings out that would be worth while? all parts will be OEM from Toyota. Thanks |
02-16-2021, 01:08 PM | #39 | |
https://www.subaruparts.com/oem-part...ber-20152ca000 Please keep in mind the 2017+ twins have revised front diff bushings, so be sure to get those if you are staying OEM. Hell, while you’re in there may as well throw in a 2017 diff which comes with those bushings and you get the sweet sweet 4.3FD. |
The Following User Says Thank You to norcalpb For This Useful Post: | Racecomp Engineering (02-16-2021) |
02-16-2021, 01:13 PM | #40 |
One other thing that I forgot to mention on the strut and shock parts...if you're trying to put together a complete assembly, there are a few more (small) parts needed. Usually they're parts you reuse so I didn't list them, but I'll go back and put the part numbers in at some point.
- Andrew |
02-16-2021, 01:15 PM | #41 | |
- Andrew |
03-04-2021, 08:43 PM | #42 |
Drives: 13 FRS
just realized the subframe bushings themselves dont come with the rear subframe (which includes the DIFF bushings)
Are you supposed to swap out the subframe bushings? |
Similar Threads | ||||
Air Suspension / Brembo Brakes / RUCA | bansky | Brakes, Suspension, Chassis | 17 | 04-14-2019 05:31 PM |
2014 BRZ Brakes and Suspension | AndyBRZ | Brakes, Suspension, Chassis | 1 | 03-10-2018 11:01 PM |
OEM brakes and suspension | batlwagn | Brakes, Suspension, Chassis | 3 | 04-04-2016 04:13 PM |
Memorial Day Sale. Brakes and Suspension 10-25% off! | Infamous Performance | Brakes, Suspension, Chassis | 31 | 06-06-2015 01:52 PM |
Turn in Concepts Brakes, Suspension, Chassis | Turn in Concepts | Brakes, Suspension, Chassis | 13 | 01-22-2014 04:14 PM |
