07-20-2022, 08:05 PM | #449 |
Drives: 19 86, 22 BRZ
Light shave on the rear fender, didn't cut any metal. Camber is around ~-2 to -2.5 atm.
07-21-2022, 11:40 AM | #450 | |
Drives: '23 BRZ Limited
I know there are a lot of us that want to get as much tire/wheel under the car as we can (because it looks awesome aside from the cornering benefits) with as little modification as possible.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
07-29-2022, 05:37 PM | #451 | |
Do you think if yours were +45 instead of +40 you would have still had to shave the fender. Also what rates are you running? My coils are 7k/8k
08-02-2022, 06:43 PM | #452 |
Drives: 2022 BRZ
I'm currently looking at 18x8.5 +45 offset. Will these fit on stock suspension on a 2022 BRZ?
I've been getting different answers that less aggressive offsets will hit the strut/spacer. Please advise. |
08-03-2022, 03:19 AM | #453 |
Drives: It has 4 wheels
Yep it'll be completely fine presuming you'll be running 225/40, 235/40 or 235/35 tyres.
08-07-2022, 04:04 PM | #455 | |
I've read that people are running 9.5 +45 w/ 245/35 without issues as well, but I can't really answer that for you as I had trimmed my rear fenders before test-fitting my wheels after finding posts on jp twitter. My current coils are 8k front/10k rear.
The Following User Says Thank You to jongers For This Useful Post: | OkieSnuffBox (08-07-2022) |
08-07-2022, 04:40 PM | #456 |
Drives: Frs
I just fitted rt615k+ 265 35 18 on a 18 9.5 +45….yup lots of rubbing. Lots of modifications to the back fenders. I added a 5 mm spacer to the front but still rub when full lock. Thanks to a dremel and lots of patience I managed to remedy the back with no more rubbing. The new grip is awesome! I’ll probably add a 7mm spacer up front and see if that fixes the rubbing. I previously had 255 ps4s with a 10mm pacer up front with no rubbing.
Ridiculous!
08-07-2022, 06:00 PM | #457 | |
I'm just having a really hard time deciding on what wheels to buy.
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | jongers (08-07-2022) |
08-07-2022, 10:41 PM | #458 |
Drives: zd8 brz
I have Coilovers on the way and will be test fitting 18x10 +40 with a 255/35 once they are installed. I’ll keep this thread updated on how it goes/what’s required
I’ve managed to fit some pretty aggressive wheels and tires on other platforms before and this brz will no be exception |
The Following User Says Thank You to mycrors7 For This Useful Post: | Wally86 (08-08-2022) |
08-31-2022, 09:08 PM | #459 |
Drives: 2013 Raven FRS(Sold): Fiesta ST
Currently rocking some 18x8.5 +43 TC105's. Think I'm going to pull the trigger on some 245/35 tires and pray I don't rub. I should be good correct? Currently rocking -2.5 degrees of camber in the rear and almost the same in the front.
09-01-2022, 07:28 AM | #460 | |
Drives: 2022 BRZ sport-tech
There is also this thread that have some pics of the exact setup, though he is running a 225 but it looks like there is plenty of room: https://www*********/threads/simple-...an-build.2847/ Replace ** with GR86 . ORG Start @ 1:00.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 Last edited by Petah78; 09-01-2022 at 10:46 AM. |
The Following User Says Thank You to Petah78 For This Useful Post: | Clott (09-01-2022) |
09-01-2022, 01:30 PM | #461 | |
Your 8.5 shouldn't be a problem at all with that size.
09-01-2022, 01:36 PM | #462 |
Are you sure about this? I think the referenced 86Speed GR (video above) had mentioned that exact spec which require shaving of the rear fender. There are many documented cases where 17x9, +45 is already a VERY tight fit. 17x9.5, +40 is another 11mm poke from that.
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 Last edited by Petah78; 09-01-2022 at 01:53 PM. |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
