09-27-2020, 02:09 PM | #295 |
Only users lose drugs.
Drives: All the time
Very true about studded tires being noisy ..they're VERY loud. Although just keeping things in perspective, they're no louder than an aftermarket exhaust system, just a different sound. They're also heavy.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
09-27-2020, 02:23 PM | #296 | |
Drives: 17 Asphalt 86
I ended up ordered the Viking Contact7. Few bucks cheaper than the pirellis and it's something different to compare too. |
09-28-2020, 02:03 AM | #297 |
Drives: 2020 Toyota 86 GT 6M
I too am very curious as to how well the new xice snows perform. will have to pick up a set in the upcoming weeks once Costco launches their promotions for winter rubber. Right now i'm debating between the xice snows and Pirelli sottozero 3's
10-27-2020, 08:36 PM | #298 |
Installed the vikingcontact7's. So far I can only comment on dry/wet performance. I will update as snow season takes full swing.
They're a step down in the dry compared to the ice zero FR in terms of road feel. They're way more wobbly feeling which I am a bit disappointed about, since the pirellis were also a Nordic class tire but hardly felt like a winter tire in terms of road feel. They ride a bit better which makes sense as the sidewalls are a bit softer. They make no road noise and Steering weight is very light. If you are interested in the X-ice snows the Pirelli equivalent would be the ice zero FR. Sottozero give up some snow traction in favor of dry handling. |
The Following User Says Thank You to RToyo86 For This Useful Post: | saltywetman (10-30-2020) |
12-02-2020, 08:26 PM | #299 |
I am torn between getting the Bridgestone Blizzak or Michelin Xi3. I am here for more ideas about these tires before purchasing it on 4wheelonline.
12-02-2020, 08:42 PM | #300 |
Wes
Keep in mind Michelin just released a new snow tire called X-Ice Snow. I had them installed on the weekend and no snow yet but dry traction is fantastic and they're quiet. MUCH better than the Xi3. Can update you on snow traction when it does snow here (shouldn't be too long)
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | justalex (12-03-2020) |
12-02-2020, 10:33 PM | #301 | |
Drives: 2017 Toyota 86
The Blizzak LM-32 is also good and held up better on dry roads than the WS80s, but the Michelin is similar for less with better performance in the deep snow and ice. |
The Following User Says Thank You to anticubus For This Useful Post: | justalex (12-03-2020) |
12-03-2020, 06:20 PM | #302 |
Thanks for the tips guys, I really appreciate it. I will do my own research from here to get more insights about these winter tires.
12-09-2020, 03:36 PM | #303 |
Drives: Car
Tire: Vikingcontact 7
Size: 205/55/16 on steels Location: GTA Canada Driver: Aggressive on balding tires, granny when I just dished out $800+ for new ones. Previous tire: WS80 PSI: 38 @ 5 degrees Celsius. They seem a bit twitchy in the wet and drive pavement; feels like a squishy all season tire. I tried driving around it around my neighborhood while it was very icey (i.e stopped the car, opened the door, put one foot out and was able to slide my feet back and forth on the road) and the grip seemed phenomenal. The sidewalls are very squishy so it may not translate to a sporty feel on dry/wet pavement. |
12-09-2020, 04:05 PM | #304 | |
Size: 205/55R16 Location: Ottawa, ON, CA Paid $609 shipped + $100 mount and balance. Driver: spirited driver, car lowered on RCE yellows. Impressions: Handles snow and ice well, dry pavement grip is decent, but sidewall as I mentioned is soft. Ride is good as a result despite the springs but the car feels squishy and all over the place. I did notice the tire felt better when temperatures dropped to -10c. Compared to my previous tire which was the Pirelli ice zero FR(same size and wheel) these Conti's are slightly worse for my preference. The Pirelli performs so closely on snow, ice and slush but with stiffer sidewalls also feels more compotent if you huck it into corners. I suspect these will last me an extra season as I'm not driving the car as hard in the dry. I am also having issues balancing these. I'm not sure if I got a bad set but after 3 visits to the shop to rebalance them I still get a small vibration at 90-110kmh. |
The Following User Says Thank You to RToyo86 For This Useful Post: | Stonehorsw (06-28-2021) |
08-05-2021, 02:17 PM | #305 |
Drives: 2020 Toyota GT86
I'm guessing it's getting close to the time for this thread to liven up again.
I have had my 86 for 4 months now, so obviously this will be my first winter with it. I've started my research into what winter tires I will buy, using the OEM 17x7 wheels. I have past experience with Blizzaks and Altimax Arctics on our Camry, as well as Sottozero 3s on my BMW X1 (car the 86 replaced). I was very happy with the overall mix of dry & snow performance with Sottozeros and they are the initial front runner. The one tire that I am really interested in hearing if anyone here has had any experience with is the GT Radial Champiro Winterpro HP. I've enjoyed plowing through this thread and look forward to following it moving forward.
This post sent using 100% recycled electrons.
08-11-2021, 12:04 PM | #306 | |
Drives: '13 FRS
08-11-2021, 05:16 PM | #307 | |
Drives: 2017 86 860 Special Edition
08-12-2021, 10:01 AM | #308 | |
Drives: '13 FRS
Similar Threads | ||||
Winter tire experiences? | smbrm | CANADA | 10 | 11-06-2012 04:42 PM |
What Winter Tire for NY Weather? | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 84 | 10-29-2012 07:02 PM |
Winter tire | Dub666 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 01:32 AM |
Need some help picking a winter tire... | jm1681 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 08-29-2012 01:14 PM |
Contribute your review for California Scion/Subaru dealers | DuMa | Southern California | 20 | 02-06-2012 11:59 AM |
