Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-13-2018, 06:21 PM | #1 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
Oil galley plug locations?
Greetings.
On the topic of available ports for sensors (oil temp/press etc): I heard rumors that there is an oil galley plug on the passenger side rear of the block, somewhere near the ECU? Can anyone confirm? The list of access points for a sensor seems to be: Please correct any errors/ omissions:
The Following User Says Thank You to canyons For This Useful Post: | Qwimby1 (03-19-2018) |
02-17-2018, 12:44 PM | #2 |
Drives: Q5 + BRZ + M796
Sorry no one responded for days.
From this picture, and from what I believe to be the case, there are three unused oil galley plugs on the block: Part# 11024 The one on the top, driver's side, front of the motor is accessible. It is between the throttle body and ac compressor: The rear oil galley plug, on the driver's side, on the back of the motor, is not accessible. It is behind the flywheel seen here: The plug at the bottom, front, passenger side of the motor doesn't look to be accessible, as the timing cover seems to cover it: You can remove the oil pressure, dummy-light sensor or T into it, and there might be other locations to T into throughout the engine, but not anymore galley plugs: 1. A galley plug with a hole is needed and the appropriate NP or NPT threads for that hole or a NP to NPT adapter can be used. PT/BSPT https://www.rallysportdirect.com/par...il-galley-plug NPT https://www.rallysportdirect.com/par...hreaded-center Adapter https://www.walmart.com/ip/Unique-Ba...=sem#read-more 2. BSPT or NP thread. 3. No port. 4. Usually NPT threaded holes on these sandwich plates. 5. I don't think this will work...only for use as an oil return hose for turbos or recirculating catch cans. 6. See attached photos...none is the answer. Last edited by Irace86.2.0; 02-17-2018 at 01:08 PM. Reason: Added responses. |
03-28-2018, 12:06 AM | #3 |
Great reply IRace86 ! And one more new option
Great reply Irace!
It's a drag that we cannot get at more than 1 galley connector right into the block. However: I found another option for those of us using oil coolers with the passthrough plate under the oil filter: Jackson Racing and others are now selling a 4-connector oil filter adapter that will accept as many as four sensors ( two plus an oil cooler) via the appropriate adapters: And here's one from Toyhead racing: (toyota specific but not tested by me): Finally, GREDDY sells one as well (not tested by me, YMMV): Good luck guys! Canyons |
The Following 3 Users Say Thank You to canyons For This Useful Post: |
03-28-2018, 01:20 AM | #4 |
Thanks. Sandwich plates were always an option, but less desirable for some. This solution seems simpler and cleaner. Thanks for the post.
03-28-2018, 02:10 AM | #5 |
The GReddy one is on my car.
04-03-2018, 12:54 PM | #6 |
I am using the Forester XT OEM oil cooler. Do you guys think using a sandwich plate (not one of the ones listed above, but a normal one) between the filter and the cooler would be acceptable?
I've seen it done in one other instance... but that doesn't fill me with a lot of confidence. |
04-29-2019, 09:20 AM | #7 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Necro but I’m removing an oil pressure sensor that’s tapped in the top engine galley. I got SU003-00108 but can't find the torque value to tighten it to. Anyone know?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
04-29-2019, 11:37 AM | #8 | |
Wheels for Brains
I'm guessing keep going until the flange touches the face on the engine, and maybe give it 10 ft-lb? |
The Following User Says Thank You to EndlessAzure For This Useful Post: | the new guy (04-29-2019) |
05-14-2019, 06:41 PM | #9 | |
Steve Bodalenko
Drives: Toyota 86 GTS
Does anyone know how much variation there is in pressure and temp between this location, the front OEM location, and a sandwich plate? |
05-14-2019, 11:51 PM | #10 | |
義理チョコ
You can decide for yourself if you want to sweat the pressure/temp difference. http://www.ft86club.com/forums/showp...14&postcount=5
09-17-2019, 03:08 PM | #11 | |
Drives: '14 FRS TT5
Follow my NASA TT5 build here: JHill Motorsports
The Following 2 Users Say Thank You to TMF For This Useful Post: | Irace86.2.0 (09-17-2019), the new guy (09-23-2019) |
11-05-2020, 09:08 AM | #12 |
Drives: _
What's the thread size on the OEM pressure sensor?
11-05-2020, 09:55 AM | #13 |
Drives: Turbo GT86 - Fensport Performance
Dont forget the one on the right hand side head at the front under the injector cover, usually used to feed the vacuum pump on auto cars. But if you have a manual you have a good oil feed location there. M12x1.5 IIRC
11-05-2020, 10:42 AM | #14 |
Drives: _
Similar Threads | ||||
E85 locations | cuddefred | AUSTRALIA | 7 | 10-28-2017 06:13 AM |
Oil galley temp reading low | Tomita San | Engine, Exhaust, Transmission | 19 | 03-14-2017 05:22 PM |
Oil Galley Plug Adapter | Wyattkb | Engine, Exhaust, Transmission | 3 | 12-21-2015 01:10 AM |
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug | sikest | Electronics | Audio | NAV | Infotainment | 7 | 01-21-2013 09:38 PM |
