Old 05-04-2021, 02:01 AM   #29
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Originally Posted by jflogerzi View Post
Heat soak and better reliability. Even with the IC the car was still pulling timing. It was setup that was not meant to take the abuse of lapping in hotter temperatures we are used to seeing in socal
That makes sense. Sounds like you are having a lot of fun out at the track and racking up some new PBs!
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
jflogerzi (05-04-2021)
Old 05-20-2021, 01:03 AM   #30
jflogerzi
jflogerzi's Avatar
Here some random pictures of some of the updates to the car. Love these new Apex ARC-8 wheels in Satin black. Blends just enough without disappearing to much
Pretty much this is the final form of the car. No more Mods need to be done. Soon will become weekend/toy car/Track car. Never gonna let her go. This car is such a fun car on track.
Added Parts:
APEX ARC-8's 17x9 ET 35 Satin Black
Front Splitter
OEM under panels
Cusco Strut tower with MBC brace
RCE SS'1s
P3 vent gauge with E sensor add-on(can see oil, coolant, AFR, E level, IATs)
Soon to be added:
Versus Standard rear diffuser
Diff and rear suspension tunnel flat panel
Trans Tunnel under flat panel
2013 Series 10 FRS #553
RCE SS-1s, SPC LCAs -3/2.3 camber
JDL 4-2-1 EL and OP, DynoTuned by Zach@CSG on e85
ARC-8 17x9 SX2 GTs 245s/Koing 17x8 RE71rs 235s
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
DarkSunrise (10-20-2021), saltywetman (05-20-2021), Stonehorsw (05-22-2021)
Old 05-21-2021, 03:46 PM   #31
robotleader
Drives: brzzzz
how come your +35 looks so much tucked compared to mine? i am sitting on flex Z's + sx2.
Added Parts:
Front Splitter
OEM under panels
RCE SS'1s
Soon to be added:
robotleader is offline   Reply With Quote
Old 05-21-2021, 03:49 PM   #32
jflogerzi
jflogerzi's Avatar
Originally Posted by robotleader View Post
how comes your +35 looks so much tucked compared to mine? i am sitting on flex Z's + sx2.
What's your camber? I am -3 up front. Also the track photos were with my old wheels that were 17x8 et 40
Old 05-21-2021, 07:02 PM   #33
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Im going to need a quick review on those RCE coils. Plush? Harsh? How does it change the balance? More or less understeer/oversteer at the limit? Im looking for many different perspectives.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 05-21-2021, 07:35 PM   #34
jflogerzi
jflogerzi's Avatar
check this thread. Posted a few thoughts on Track with a full lap at Buttonwillow race track
https://www.ft86club.com/forums/show...=144588&page=2
On the street compared to my old setup:
OE 2017 dampers, RCE Yellows and Peddler top hats. -2.3 up from and -2.2 rear camber.
They ride better in the following ways:
On the recommended settings for street, they soak up bumps better without punishing you. Its still stiff but not over dampened. Body roll is still well controlled. Build quality is nice. To me you got 3 major players in space and price:
Flex-A by CSG
SS's by RCE
Fast Road Pro's by Annex suspension
Old 05-22-2021, 02:27 AM   #35
Elliotw
Elliotw's Avatar
Those hood vents are gonna look great.
jflogerzi (05-22-2021)
Old 07-13-2021, 07:55 PM   #36
jflogerzi
jflogerzi's Avatar
Quick update:
Still have not put on my under panels but will get to it eventually get to it. No track time atm due to heat so I am being lazy. Will go on before my date at Sonoma on the 7th august.
Got some new rubber for putting down fast laps. Could not help myself as they were on special at Tire Rack and I have never driven on any real 200TW tires. Mounted to my 17x8 Koing Hypergrams. Next year I will get some Apex EC-7Rs for my main track tires and move my ACR-8's as my daily/lapping tire setup
Also getting a Dyno tune for my car with Zach @ CSG before Sonoma. Really want the car dialed in. Order a JDL overpipe to match my header to insure there is no restriction pre secondary cat.
The Following User Says Thank You to jflogerzi For This Useful Post:
villainous_frx (07-15-2021)
Old 07-24-2021, 03:38 AM   #37
jflogerzi
jflogerzi's Avatar
New Slotted rotors from DBA T3 4000 series. Got a steal on these from Amazon. 129$ per rotor! I could not pass it up. I was seeing them for 175-185$ each online. Needed new rotors and this is close enough to Centric Premium blanks. For track I know slotted helps keep the rotors and brake pads happier so I figured I give them a shot.
In other news passed Smog! So I celebrated by putting my Header and Flex fuel back on Screw CARB!
Dzmitry (08-20-2021), Lonewolf (07-24-2021), Stonehorsw (07-24-2021)
Old 08-20-2021, 01:15 AM   #38
jflogerzi
jflogerzi's Avatar
Here are a few shots from my first trip up to Sonoma raceway plus my best lap. Gotta say 200TW tires are fantastic
Really fun track and I know there is a sub 2 in this car on that track. For next time
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
DarkSunrise (10-20-2021), Espi (08-20-2021)
Old 08-20-2021, 11:32 AM   #39
Espi
Espi's Avatar
Drives: 17 BRZ
very nice build and good find on those rotors! Waiting for my blanks on back order until Sep 22
the car looks like alot of fun to drive!
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
jflogerzi (08-21-2021)
Old 10-18-2021, 11:54 PM   #40
jflogerzi
jflogerzi's Avatar
Did a thing. Trying to make the bottom as flat as possible. Finally got the Verus Under panels installed along with the non aggressive defuser. This kit blends well with the OEM Japan under body panels
Sent from my Pixel 5a using Tapatalk
The Following 4 Users Say Thank You to jflogerzi For This Useful Post:
DarkSunrise (10-20-2021), DiscoQuinn (10-20-2021), Stonehorsw (10-19-2021), villainous_frx (10-19-2021)
Old 10-19-2021, 05:18 AM   #41
Thefalls
Thefalls's Avatar
Drives: Corolla GT
That looks nice and tasty
Now we need a comparison of lap times with the upgrades.
Keep it up!
Thefalls is offline   Reply With Quote
Old 10-19-2021, 06:32 PM   #42
jflogerzi
jflogerzi's Avatar
Keep it up!
working on it. Current best at Buttonwillow is 2:06 from old PB of high 2:10ish
Only changes were:
Pedal Dance Mode
235 45 17 RE71's vs 245 40 17 SX2's
Under body Panels.
Thefalls (10-20-2021)
2013 FRS 10 Series GirlRepellent Cars for Sale/Trade 2 09-07-2016 10:22 AM
2013 frs 10 series eldevil Issues | Warranty | Recalls / TSB 6 03-22-2015 08:18 PM
2013 frs "10 series" or 2013 silver subaru brz limited? Please HELP! p0gsss Scion FR-S / Toyota 86 GT86 General Forum 8 04-14-2014 04:23 PM
My new 2013 10 Series mystic FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 01-08-2014 10:26 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
