Old 06-26-2019, 08:36 AM   #113
enderw88
Drives: 2015 BRZ WR Blue Series.Blue
Perfect! I picked up a 2015 Series.Blue on Friday and one of the first things I noticed was that the doors wouldn't stay open. I fabricated some shims from 18ga (0.040"/1mm) aluminum sheet I had laying around. Works a charm even with my steep driveway.
Since this is my first post I can't thank anyone. So thanks to ermax and radroach for devising the solution and capturing the pictures.
enderw88 is offline   Reply With Quote
The Following 2 Users Say Thank You to enderw88 For This Useful Post:
bcj (02-08-2022), jcw99 (06-26-2019)
Old 02-08-2022, 10:19 AM   #114
Compelica
Compelica's Avatar
Drives: 86 GT
Thread necro - getting my shins bruised and soon I will have a tibia fracture if I don't address this.
@ermax @Ultramaroon @WNDSRFR I'm trying to figure out what part of a milk jug / alcohol bottle you guys were referring to shim the plastic piece - here where I live, milk is typically sold in paper cartons, and alcohol in glass bottles or aluminium cans
I don't really want to use duct tape as it's going to leave a sticky mess from the adhesive.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 02-08-2022, 11:58 AM   #115
WNDSRFR
Drives: FR-S,GTI
Try a piece of 100 Plus plastic bottle. I think that's the name of the sports drink you have over there. I think it's made of the same material as milk bottles in the US.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
Compelica (02-08-2022), Ultramaroon (02-08-2022)
Old 02-08-2022, 12:21 PM   #116
Ultramaroon
義理チョコ
Ultramaroon's Avatar
Haha... well, it's more about finding something of appropriate thickness that can be cut easily enough. A strip from an aluminum can folded over a couple or three layers thick would work just as well. Don't cut off your fingers!
Old 02-08-2022, 12:31 PM   #117
Compelica
Compelica's Avatar
Drives: 86 GT
Ah so it's the body of the milk bottles itself? Looking at it, it's the 'frosty' types which are generally thicker and more durable over the 'clear' ones... or maybe an easier solution would be to just layer a few pieces of aluminium foil to about 1mm thickness as @enderw88 did, that might be easier to work with.
Regardless, appreciate the tips.
Old 03-26-2022, 08:19 AM   #118
Compelica
Compelica's Avatar
Drives: 86 GT
Finally got around to complete this. Door is much weightier and stays open even on a slope. As @Ultramaroon suggested - aluminium foil easily works by folding to required thickness (I did about 1.5mm on each side), flattening it with a hammer and cutting it to size with tin snips.
It's the little mods that affect everyday usage which makes the biggest difference. Thanks @ermax !
The Following User Says Thank You to Compelica For This Useful Post:
Ultramaroon (03-26-2022)
Old 05-09-2022, 03:15 PM   #119
ermax
ermax's Avatar
A friend of mine just took delivery of a 22 BRZ and I got a chance to check it out today. First thing I noticed was the door check is completely different and much more substantial. I just looked it up and they are about $45. I may buy one and see if it fits. If so I’ll get one for the other side. At a glance it looks like it would be a direct fit.
The Following 7 Users Say Thank You to ermax For This Useful Post:
bcj (05-10-2022), Capt Spaulding (05-10-2022), Compelica (05-11-2022), Jdmjunkie (05-09-2022), radroach (05-16-2022), soundman98 (05-11-2022), Ultramaroon (05-09-2022)
Old 05-11-2022, 08:48 AM   #120
Opie
Opie's Avatar
Drives: '13 BRZ TLM Spec
Subaru has a TSB for that, #12-214-17R
New Door Checker P/N: CHECKER ASSY- FRONT DOOR 61124CA001 2013-17MY BRZ
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
Opie is offline   Reply With Quote
The Following 4 Users Say Thank You to Opie For This Useful Post:
Bonburner (05-19-2022), ermax (05-14-2022), nextcar (05-16-2022), Tcoat (05-11-2022)
Old 05-11-2022, 08:54 AM   #121
Ya they must have changed something in the 2017 facelift because I had forgot this problem even existed since I got the 2020. It has never closed on me once no matter how steep an angle.
ermax (05-14-2022), Opie (05-11-2022), soundman98 (05-11-2022)
Old 05-16-2022, 01:04 PM   #122
ermax
ermax's Avatar
I just looked up this TSB and it doesn’t seem to be related to the doors staying open. It looks like it addresses corrosion issues on the cover plate. Maybe while fixing that they also fixed the door issue.
Anyways, the GR86 door check arrived yesterday. I picked it up a little while ago and installed it just fine. It was a direct fit and now my door stays open even on a steep incline. I used to be able to close the door by blowing on them. Hahaha.
I’m going to order one for the other side now but this time I’ll order it from Subaru because they sell the part for half the cost of Toyota.
Old 05-16-2022, 05:02 PM   #123
Opie
Opie's Avatar
TSB doesn't specifically address the closing issue, but the new door check p/n adds 2 additional holding positions and an increase to the detent force of the front door checker mechanism as described in TSB #12-151-13R & TSB #12-182-15R that addresses the design changes for the Forester, WRX, Crosstrek & STI models that were carried over to the BRZ in 2017.
The Following 3 Users Say Thank You to Opie For This Useful Post:
ermax (05-17-2022), nextcar (05-16-2022), Tcoat (05-16-2022)
Old 05-16-2022, 07:42 PM   #124
ermax
ermax's Avatar
Thanks for the additional details. I can’t believe we are using milk jugs and aluminum foil to fix this issue when there was a legit long term fix. Hahahaha.
The Following User Says Thank You to ermax For This Useful Post:
bcj (05-17-2022)
Old 05-16-2022, 09:14 PM   #125
nextcar
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
Thank you!!! This is my longest standing annoyance with my car. Parts ordered and a new hope for my shins!!!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 05-17-2022, 09:11 AM   #126
I am sort of embarrassed that I never noticed the change on the 2020 and could have told people there was an easy fix two years ago. Pretty sure that the face lift years had the changes done that the TSB covers. It really does work great although I do miss my car hugs every time I was parked on a 5 degree or greater slope.
Dadhawk (06-02-2022), ermax (05-17-2022)
Door Open Switch Raz BRZ First-Gen (2012+) -- General Topics 7 04-10-2022 05:07 PM
Door open light rosol16 Issues | Warranty | Recalls / TSB 6 11-22-2015 12:42 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
