Old 04-20-2020, 01:04 PM   #29
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
Braking Distance Post 60-0 MPH dropped by 8 feet.
I tested this by setting cruise at 60mph using line spray painted on the road on a bump that can be felt to insure that I'm starting the braking at the same point. In 5 repeated stops letting the rotors cool to 115 degrees each time I had a Deviation of stops of only 4 feet from shortest to longest stop. The ABS Engagement feels just like stock.
Same method I've used 3 times previous when testing to see if coil overs and rims and tires added to shortening stopping distance. This test has given consistent results each time.
I'd guess the improvement in stopping distance is the new pad composition being better. I actually gained a better reduction in stopping distance when I upgraded my wheels and tires.
RuyGuy2 is offline   Reply With Quote
Old 04-20-2020, 01:08 PM   #30
RuyGuy2
RuyGuy2's Avatar
Originally Posted by Ernest72 View Post
Doesn’t rrracing have a good deal using Wilwoods. My only reason for not going wilwoods is they do not have dust boots. I get plenty of bad weather and snow in NY and not sure if I would have to rebuild sooner.
The Calipers I used do have dust boots. I live in South Dakota, Don't let the South in the name fool you. We just had a blizzard last week.
https://www.wilwood.com/Calipers/Cal...temno=120-7379
Old 04-20-2020, 01:36 PM   #31
Ernest72
Thanks. I will take a look at them.
Old 04-20-2020, 06:09 PM   #32
RayRay88
Drives: 2017 86 860 Special Edition
I imagine the only real downside to these calipers, if true, is one I have heard from basically every other Willwood caliper.
Deflection/torsion/warping.
It's the price you pay for a super light caliper.
I don't know many people who, under prolonged track abuse, like the feel of the Willwoods. Those that do, don't realize how bad it is until they go to a monobloc or better constructed caliper.
In drag racing, autocross, or even short stints of HDPE, they seem to do fine.
This is only some feedback i've heard about most Willwood brake kits. I would like to hear someone else's thoughts on this matter vs Brembo or AP Racing.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
RuyGuy2 (04-20-2020)
Old 04-20-2020, 07:45 PM   #33
RuyGuy2
RuyGuy2's Avatar
Correct. This would not be an excellent track setup. If I were going to build a track setup for this car I'd get stainless pistons with the largest brake pad size I could find. I'd also put the widest size rotor I could find.
When it comes to Wilwoods, most people buy the aluminum piston wilwood without dust shields and get the "Ultra-lite" or "Narrow" instead of a "Dynapro" or "AERO6" caliper and .8" rotors and end up tracking with them and warping or cracking the rotors and overheating the aluminum pistons causing the seals to get sticky. If you go with Wilwoods just make sure you're getting the right product for the right application, and they are great.
The Following User Says Thank You to RuyGuy2 For This Useful Post:
RayRay88 (04-20-2020)
Old 04-21-2020, 02:20 PM   #34
Racecomp Engineering
The BRZ and WRX sized 2 piece rotors from PFC are indeed available and in stock (in the UK). We're looking at $923 shipped for a pair. Not cheap and well on the way to a BBK, but PFC make fantastic rotors. I don't have an exact weight right now unfortunately.
I'm still tempted for my personal car since I rallyx and will be moving to 15 inch wheels. These would be very nice with the OEM calipers or FHI 4 pots or this wilwood kit.
They do also have 2 pc rotors for the PP Brembos. If anyone is interested, please contact me.
- Andrew
why? (04-22-2020)
Old 04-21-2020, 02:28 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
Please tell me you have RallyX video
Old 04-21-2020, 04:33 PM   #36
A couple of photos from last year, but this season has been busted up due to ye olde COVID-19.
Hopefully soon! Go Pro is all set.
- Andrew
NoHaveMSG (04-21-2020), RuyGuy2 (04-21-2020)
Old 04-21-2020, 10:48 PM   #37
RuyGuy2
RuyGuy2's Avatar
- Andrew
I really would have done the wilwood Kit but I Didn't want to Run the .8" Caliper. I intend on Getting wilwood 1" Calipers and aluminum hats.
These Hats,
https://www.wilwood.com/Hats/HatProd?itemno=170-9206
These Rotors,
https://www.wilwood.com/Rotors/Rotor...%20%20&appid=0
I will have to space out my calipers to go from 11.44" rotor to the 11.75"
The inside offset is the same with these rotors and hats as it is with the wilwood kit that has the .8" rotors. With that being constant these hats with these rotors will work.
Probably have about $265 into each Rotor.
Old 04-21-2020, 10:58 PM   #38
RuyGuy2
RuyGuy2's Avatar
Time for the next Step. The ABS Delete Manifold Just got here.
So the Farthest front Brake Line will get slid back to one of the back two ports in the manifold and move the middle two rear brake lines to the front two ports.
This way all I'll have to do is have the Bias Valve on the port that goes into the front of the manifold.
Track car weight reduction Irace86 BRZ First-Gen (2012+) -- General Topics 17 06-11-2016 05:21 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Weight reduction in the front only KevinBRZ Scion FR-S / Toyota 86 GT86 General Forum 16 04-12-2013 12:25 AM
the weight reduction of FR - S? raiden8383 Scion FR-S / Toyota 86 GT86 General Forum 22 11-30-2012 06:10 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
