11-16-2020, 07:58 AM | #22569 |
Wes
Just want to follow up on my post here. The driveshaft made the drivetrain silky smooth. There's no more of that hop when coasting in first gear, all the clunk-clunking is gone, the shifting is sooo nice now, and the power transfer is much more direct. It's worth it for the extra comfort alone.
Instagram: @gt86ws
11-16-2020, 08:40 AM | #22570 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | StraightOuttaCanadaEh (11-16-2020) |
11-16-2020, 11:33 PM | #22571 | |
11-16-2020, 11:58 PM | #22572 |
It's because the stock drive shaft is 2 piece instead of 1. I noticed the exact same things when I switched. I bought it because of the weight but I'd get it just for the driving feel/comfort of I was doing it again
The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | humfrz (11-17-2020), StraightOuttaCanadaEh (11-17-2020) |
11-17-2020, 12:50 AM | #22573 | |
I reckon my OEM driveshaft isn't all that bad. It doesn't do all these things: "There's no more of that hop when coasting in first gear, all the clunk-clunking is gone, the shifting is sooo nice now, and the power transfer is much more direct." |
11-17-2020, 06:46 AM | #22574 | |
Be Kind
Drives: 2020 86
The Following User Says Thank You to Wally86 For This Useful Post: | Dadhawk (11-17-2020) |
11-17-2020, 07:35 AM | #22575 | |
Wes
Also could be that all the various inserts and bushings I have really magnify all the audible umm... features.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | humfrz (11-17-2020) |
11-17-2020, 07:56 AM | #22576 | |
11-17-2020, 08:02 AM | #22577 | |
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (11-17-2020) |
11-17-2020, 12:47 PM | #22578 | |
Well, of course any driveline sounds will be transmitted to the cabin, if you weld all the parts of the drivetrain to the body of the car - |
11-17-2020, 02:02 PM | #22579 |
Wes
Yep I've done that to meself, first one to admit it. But now I bought the thing to fix the problem I created
Instagram: @gt86ws
11-17-2020, 02:06 PM | #22580 |
11-17-2020, 06:30 PM | #22581 |
Drives: 17 Asphalt 86
Got a Perrin inlet tube on sale 20% off.
Wanted black but would have needed to special order. Happy to be rid of all the sound generator crap. |
The Following 5 Users Say Thank You to RToyo86 For This Useful Post: | DarkPira7e (11-17-2020), FLIPDADY (11-18-2020), MJones_RB (11-18-2020), mrg666 (11-17-2020), Tcoat (11-19-2020) |
11-17-2020, 08:15 PM | #22582 | ||
Drives: RX-7 / BRZ
There are many reasons for a piece. 1. Less chance of bending/flexing at high-rpms. 2. The critical speed (failure) limit is greatly reduced. 3. Less vibration when not optimal condition... dirty/offroading due to the bushing/carrier assembly. 4. #1 means they can have tighter tolerances of the tunnel so lower floor and more passenger room. 5. Having a joint midway means less of the driveshaft (only the rear 1/2) is usually hanging lower to meet the rear diff, meaning more clearance to the road. 6. Less tubing length means they can make the diameter smaller. With a long 1 piece aluminum drive shaft you need to increase the diameter to increase the strength. With 1 piece you get all the things enthusiast want. A more direct feeling and faster response due to lighter rotating parts. The mod is very comparable pros and cons list-wise to doing a lightweight flywheel or stiffer bushings and engine mounts. Not something the everyday consumer and OEM want or notice. If your the type that can notice the effects of lightened rotating mass then this is your kind of mod. Quote:
If you ever get the chance to swing it their carbon drive shaft is another step up as it is even lighter with even less vibrations.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
