Old 04-21-2015, 01:04 PM   #2423
Racecomp Engineering
Originally Posted by Ddreder View Post
How much is too much? 2-3 degrees? or more? Do you know if it will cause excessive tire wear? LCA's are just fracking expensive and I was already working on a budget.. Maybe I'll just cancel my order and go for the 1inch drops..
The car will ride and handle better with 1 inch drop springs for sure...old geezers like me think they look just as good too (i'm 29 lol).
Off the top of my head I'd guess around -2.5 or more rear camber and you might see some uneven tire wear.
The SPC lower arms are okay on a budget.
- Andy
Old 04-21-2015, 01:07 PM   #2424
Ddreder
Ddreder's Avatar
Drives: 2013 FR-S, 1990 Miata
- Andy
Awesome thank you for the response. I think I am just going to try and cancel my order and reorder the H&R springs that lower 1in in the front and 1.2 in the back. I can handle a little tire wear but I drive a lot so I need something functional. I just really dislike how high up the rear of the FRS sits so I wanted it a tad lower..
Ddreder is offline   Reply With Quote
Old 04-21-2015, 01:16 PM   #2425
DeaconRoc
Drives: GT86
Originally Posted by gramicci101 View Post
Which coilovers, what spring rates, how many clicks from full hard or full soft, etc...?
The coilovers are Meister R bodied with custom Black Art Designs internals (I didn't mention the make originally as I'm pretty sure they're not available in the US). They are single adjustable and aimed at the ohlins r&t level. They were damper dyno'd while I was there and they are all at approx 98% critical damping when set on fully hard. They are 36 click adjustable units.
Spring rates are 6kg front and rear. I originally was running them 15 clicks from full hard but the bobbling was too much so have dropped them to 25 clicks from full hard. I've run them on the track at 5 clicks from full hard and they are excellent (a track instructor commented the same). They absorb big bumps, kerbs and broken roads very well but seem to be struggling with high frequency small bumps on motorways and A roads.
Thanks again for any help / thoughts.
DeaconRoc is offline   Reply With Quote
Old 04-21-2015, 01:16 PM   #2426
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Maybe reach out to your locals for help with the spring install and use the money saved on installation for the LCAs?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 04-21-2015, 01:20 PM   #2427
Ddreder
Ddreder's Avatar
I can do the install myself but I am terrible at taking my time with things in order to do it safely without possibly damaging something cosmetic near by (like a fender). After fighting with the shocks/springs in my miata I would just rather have it done by a shop so that I dont ding a fender or something with the impact gun.. lol
Old 04-22-2015, 12:31 AM   #2428
mike_frs
mike_frs's Avatar
Drives: 2015 Subaru BRZ Limited
If you track your car, a corner balance is recommended to get the most out of your coilovers. It's not 100% necessary for a street car.
The goal is even cross weights:
http://grassrootsmotorsports.com/art...orner-weights/
You should do the corner balance before you align the car.
- Andy
I'm not going to track the car. Let's say for example if I dropped my car 2 inches, how much camber will I get after a good alignment? Will it be too much camber? I'm asking this because I'm wondering if it's 100% necessary for me to get aftermarket LCA's and aftermarket toe links. Or will I be okay running stock components?
mike_frs is offline   Reply With Quote
Old 04-22-2015, 10:55 AM   #2429
With a 2 inch drop, you will have too much camber in the rear IMO especially for a street car.
You might not need toe links.
- Andy
Old 04-22-2015, 03:38 PM   #2430
mike_frs
mike_frs's Avatar
- Andy
That's what I was thinking Andy. I think with a 2" drop the rear camber would be like at -3 or higher and I want it to be at -1 or even 0. So LCA's is a must. What do you recommend being paired with the KW V3's... I'm leaning towards Whiteline or Cusco's.
Old 04-22-2015, 03:55 PM   #2431
Def don't want 0. For your uses -1.5 to -1.75 is a good spot to be.
Whitelines are not available and prob won't be for a while.
Cusco works okay, but there are a ton of options right now for LCAs. SPL, RacerX, and the new one coming from FT86speedfactory/Velox.
SPC is fine for a street car too on a budget.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
mike_frs (04-22-2015)
Old 04-22-2015, 04:09 PM   #2432
mike_frs
mike_frs's Avatar
- Andy
You think a 2" drop and the SPC (http://www.ft86speedfactory.com/spc-...e-kit-891.html) would get me in the -1.5 to -1.75 range or you think I would have to opt for SPL, RacerX, Cusco etc?
Old 04-22-2015, 04:35 PM   #2433
That kit will do it.
- Andy
mike_frs (04-23-2015)
Old 04-23-2015, 03:04 PM   #2434
DeaconRoc
Drives: GT86
Originally Posted by DeaconRoc View Post
I've had my coilovers fitted but I'm getting an issue on high frequency bumps on highway type roads (Motorway and A roads here in the UK). The firmer the dampers are set the worse it gets - to the point where the rear view mirror becomes almost pointless it is vibrating that much. At softer settings it's better but still present.
Does this sound like something that can be tuned with damper adjustments or a more fundamental issue with the dampers?
Thanks for the help!
Anyone? It's really driving me nuts now!
Old 04-23-2015, 03:18 PM   #2435
If you can't tune it out by softening the damper settings, then yes, it's a fundamental issue with the damper valving.
- Andy
DeaconRoc (04-23-2015)
Old 04-23-2015, 03:30 PM   #2436
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Can you share what brand dampers you are using?
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
