Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-20-2022, 12:42 PM | #1 |
Drives: Pearl White 2014 BRZ
Building a FA20
I've got a 2014 BRZ, 66k miles. I'm planning on getting a second motor to build during the summer. My goal is to build the motor to handle 400 hp. This will be the first motor I've ever built so I want to do it right.
I'm planning on going with forged internals (obviously) but I am unsure of which brand is best. I am going with a turbo for FI and need to learn everything I can about what goes into this build. The information I'm looking for is what compression ratio should I go with and what parts are going to give me the "reliability" to hit 400hp. Money is no object in this build but I'd prefer to keep it around the 10k mark. As for the transmission, I've found a forged gear set claiming to support 800whp but it's 7k so I am also needing to know any information on what people are running for transmission's in their builds. If y'all could throw out some links to other builds or even links to information that could help, that would be extremely helpful. |
01-20-2022, 12:54 PM | #2 |
Drives: Crapcan
Why not just buy a built IAG short block?
The issue with the transmission isn't the gear set. The synchro's are a bit sensitive and there is a clip on the 4th gear idler can get kicked off. Jacks transmissions has fixes for this but they are expensive. A lot of guys putting down big power use a CD09. Mazworks has a kit, I am sure others do to run that transmission.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | TommyW (01-20-2022) |
01-20-2022, 01:53 PM | #3 |
Drives: '13 Whiteout
Definitely an IAG. Has better oiling capabilities also. I have the Stage 1 and it handles 550 hp. I'm NA so should have no further problems. Price went up a grand this year from when I bought mine but you can see here what they use
The Following User Says Thank You to TommyW For This Useful Post: | Teseo (01-21-2022) |
01-20-2022, 05:18 PM | #4 | |
Human
Drives: 2015 BRZ Black
T56 or CD009. There are some kits out there.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
01-21-2022, 12:25 AM | #5 | |
Drives: 2013 Rally Blue BRZ
That being said, you'll want:
From there I'd say get a decently reliable NA build then go FI from there once you learn more about those. Probably the 10.5:1 if you want big power an are going FI. I'm sure most of this you already knew, but I know seeing a post like this would've been helpful for me before I got into replacing my short block. Last edited by demasrv; 01-21-2022 at 12:41 AM. |
01-21-2022, 10:19 AM | #6 |
Drives: 2013 frs base
How much of the work are you planning on doing yourself? From everything I've experienced, rebuilding an FA20 for power and reliability is not for novice mechanics.
The Following 4 Users Say Thank You to blsfrs For This Useful Post: |
01-21-2022, 11:17 AM | #7 |
Drives: frs
How much you paid? I want oil capability, maybe FI in the future
01-21-2022, 04:59 PM | #9 | |
Drives: None
Maybe I've been misinformed. The guy I bought my Jack's transmission from had two of them and I know they both went back to be refreshed due to broken things. He ran the car competitively in ST4 with small pulley Harrop torque with the top chopped off for power to weight reasons.
The Following User Says Thank You to RedReplicant For This Useful Post: | NoHaveMSG (01-21-2022) |
01-21-2022, 05:03 PM | #10 | |
Drives: Crapcan
04-01-2022, 05:51 AM | #11 | |
04-01-2022, 06:59 AM | #12 | |
Most of the work myself apart from any machining. I have rebuilt 3 engine's from the ground up previously. I used the wrong wording and what I meant was I've never modded/upgraded an engine before. |
The Following User Says Thank You to SeddyBRZ For This Useful Post: | blsfrs (04-01-2022) |
04-01-2022, 09:51 PM | #13 |
Drives: 2016 scion frs
As someone that is a novice mechanic that did most of the work myself it can be done. BUT whats in bold is key...my built engine is sitting garage right now. Ive pulled that thing wayy too many times to count. Anyways, make sure your ready for lots of waiting and down time.
The Following User Says Thank You to jrhudson For This Useful Post: | blsfrs (04-02-2022) |
04-02-2022, 01:13 PM | #14 | |
Are you still just working with the stock block? Where are you seeing weakness/problems? Asking as the guy who just replaced my small block. I'm just wrapping up my break-in period. |
Similar Threads | ||||
Performing FA20 swap with new FA20 | Ctoner2653 | Engine Swaps | 8 | 09-24-2021 08:40 AM |
Blown 2016 FA20 swap 2017 FA20 | HRLQN | Engine Swaps | 11 | 10-15-2019 07:17 AM |
Building an FA20...Wise or Waste? | bobel | Engine, Exhaust, Transmission | 8 | 04-15-2018 08:36 PM |
building the fa20 | ggiddix | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 08-02-2014 12:04 PM |
Building my FR-S | Gillams | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-06-2013 12:37 PM |
