Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
10-19-2016, 01:03 PM | #1 |
Barefoot skidding
Drives: 2013 FR-S Whiteout 6MT
Clutch whine during cold start
Hi all. First of all, sorry if this is a repost but I did do a fairly extensive search into the issue but never really found anything conclusive.
Lately during cold starts my car has been making a noticeable whining noise, particularly when I press the clutch pedal. It does get higher in pitch as the revs increase but I never have a problem with engagement or shifting. The whining noise goes away after about 15 minutes when the car is warmed up. The clutch travel also feels completely normal except for a small clutch fork squeak. I am quite worried that this is an early sign of a bad throwout bearing or something like that. My car is a 2013 model with about 47k miles. I have tracked the car in the past, but I was never did any hard launches or clutch kicks. Nowadays, I drive the car pretty gently and rarely rev the engine above 4000 rpm. I have a habit of short shifting and I don't ride the clutch. Can anybody tell me what's going on here? Any help would be appreciated. |
10-19-2016, 01:19 PM | #2 |
義理チョコ
Throwout bearing. You didn't break it. They just suck. Get it replaced before it kills the rest of your clutch.
The Following User Says Thank You to Ultramaroon For This Useful Post: | sato (01-20-2022) |
10-19-2016, 01:45 PM | #3 | |
I concur^^^^^^^
10-19-2016, 04:13 PM | #4 |
Drives: 2013 Subaru BRZ
10-19-2016, 04:19 PM | #5 |
And that is the way of the TOB.
10-19-2016, 04:44 PM | #6 |
If it's making noise with the clutch not depressed, it shouldn't be the throw out bearing. Typical TOB symptoms are no noise clutch out, noise as soon as you start pushing the clutch.
10-19-2016, 07:17 PM | #7 |
Thupercharged
I've had cars where the TOB is in constant contact with the pressure plate fingers by design, and had the throwout bearing go bad... would make noise without touching the clutch pedal
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
10-19-2016, 07:47 PM | #8 | |
義理チョコ
01-16-2022, 04:05 PM | #9 |
Drives: 10Series 0945
Old thread I know …
Is it possible that Cold starts during the cold winter months cause the TOB to make the whirring sound when pressing clutch? It goes away after car is warmed up. Clutch feels fine, no issues shifting. |
01-17-2022, 04:52 PM | #10 |
義理チョコ
It is never acceptable for a bearing to make any noise. It is failing now and won't improve on its own.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (01-17-2022) |
01-20-2022, 12:21 AM | #11 |
Drives: 2013 Rally Blue BRZ
Yeah likely the TOB. I'm mid rebuild and mine had been making a noise. It was very "crunchy" spinning it once I had it out.
The Following User Says Thank You to demasrv For This Useful Post: | sato (01-20-2022) |
09-28-2023, 01:32 AM | #12 | |
I have same car and observation. Did you ever figure it out?
09-28-2023, 08:21 PM | #13 |
ProCrastinationConsultant
did you read the thread?
The Following User Says Thank You to soundman98 For This Useful Post: | blsfrs (09-30-2023) |
09-29-2023, 01:04 AM | #14 |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (09-30-2023) |
Tags |
clutch whine |
Similar Threads | ||||
Clutch Engage Whine? | PDM 2 | Issues | Warranty | Recalls / TSB | 12 | 10-25-2016 03:11 AM |
The dreaded clutch whine | RichardsFRS | Issues | Warranty | Recalls / TSB | 10 | 06-08-2016 06:44 AM |
Clutch Rattle at cold start | shellslinger | Issues | Warranty | Recalls / TSB | 16 | 10-11-2015 01:45 PM |
RPM varies, cold start, clutch in and out | 00NissanNinja | Issues | Warranty | Recalls / TSB | 8 | 03-04-2014 11:40 PM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
