Old 02-14-2021, 09:18 PM   #183
ML
ML's Avatar
Drives: 13 White MT FR-S
Well so much for 2021....leak down test confirmed the piston rings in the #2 cylinder is cracked or something. I let the car idle to temp the other day and smoke was pouring out of the engine bay. Apparently the header had cracked and blowby from the cylinder was coming into the exhaust port and running down the crack of the header and burning off....Well I have another motor already started for an engine build! So not all bad just means I'm not going to be tracking the car like I was hoping this year. But I do have my buddy's miata that I'm going to take to HPDEs just to keep up on my skills.
Old 02-14-2021, 10:31 PM   #184
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
That is too bad about your engine. Glad to hear you have a new engine build already coming along.
I love those Wilwood pedals. Did you have to do anything custom to get them to work with the car?
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
ML (02-15-2021)
Old 02-15-2021, 09:17 AM   #185
ML
ML's Avatar
yeah, it was a lot of work. I hand made all the lines, and had to come up with a way to mount them on an angle, and make a pushrod system to actuate the stock drive by wire pedal.
Old 02-15-2021, 09:40 AM   #186
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Sorry to hear about that. Maybe it is time to K swap. At least that is my plan and we tend to do the same things. If not, I am selling my 2013 FA20 engine. Shes a trooper 50k miles and no issues other than coil packs.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-15-2021, 09:47 AM   #187
ML
ML's Avatar
I just don't have the money for the kswap, I'd love to otherwise. Already started on building a new fa20
The Following 2 Users Say Thank You to ML For This Useful Post:
drew_kar (02-16-2021), Takumi788 (02-15-2021)
Old 04-26-2021, 01:01 AM   #188
asnatlas
Drives: 2013 - BRZ - SWP
Any updates ?
asnatlas is offline   Reply With Quote
Old 04-26-2021, 08:24 AM   #189
ML
ML's Avatar
Originally Posted by asnatlas View Post
Any updates ?
YEAH! I really didn't think anyone was following this thread so kinda let it go recently.
It has been determined that I DO have the money for the Kpower Kswap and have since purchased a K24a2 and a Supercharger bracket from a company in England.
As far as the FA20, I noticed that the smoke seems to clear up with some throttle, and I believe its the piston rings (or possible valve seals) blowing blowby into the exhaust port. Either way I decided to just get the largest catch can I could find (see below), and just run the car until the motor formally resigned.
I have had one track event since then, and the car ran fine all day. It was also the first day on my new brake setup with no ABS and no brake booster/dual master cylinders, and I got back up to the same pace as last time I was at that track but it is still going to take some fine tuning on my end as heel-toeing is a lot harder now.
The Following 3 Users Say Thank You to ML For This Useful Post:
beltax90 (04-26-2021), Berserker (05-05-2021), Stonehorsw (04-28-2021)
Old 04-26-2021, 10:47 AM   #190
Takumi788
JHerbert Racing
Takumi788's Avatar
for the record.....I am following this thread. <3
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
Berserker (05-05-2021), ML (04-26-2021)
Old 05-01-2021, 12:35 PM   #191
ML
ML's Avatar
Got new springs for my FA510s. went from 10k front to 11k , and 8k rear to 9k. Car has had issues rubbing on the frame at full compression with the aero like at charlotte motorspeed way (130mph nascar turn), and I'm trying desperately not to raise it. Put some new 2 piece wilwood rotors on, replaced the battery with an Anti-Gravity battery that weighs 3lbs. The little battery I had leaked laying on its side.
Next event is Carolina Motorsports Park May 12, VIR May 19, and Road Atlanta June 20th.
Code Monkey (05-01-2021), Takumi788 (05-03-2021), villainous_frx (05-03-2021)
Old 05-05-2021, 07:00 PM   #192
ML
ML's Avatar
Weighed the car today, came in at 2424 with a quarter tank and no driver
The Following 4 Users Say Thank You to ML For This Useful Post:
Berserker (05-05-2021), Code Monkey (05-05-2021), new2subaru (05-07-2021), Takumi788 (05-06-2021)
Old 05-06-2021, 06:56 AM   #193
Takumi788
JHerbert Racing
Takumi788's Avatar
Wow! You got me by 50 lbs! All that interior work (HVAC, doors, dash ect) made more of a difference than I thought!
The Following User Says Thank You to Takumi788 For This Useful Post:
ML (05-06-2021)
Old 05-06-2021, 08:11 AM   #194
ML
ML's Avatar
According to kpower guys they lost 124lbs doing their kswap, so that would potentially bring it down to 2300 even. Plus a few other things, I should have a 22xx lbs 86.
Stonehorsw (05-11-2021), Takumi788 (05-06-2021)
Old 05-26-2021, 03:56 PM   #195
ML
ML's Avatar
Got my k24 for the swap in. Need to start doing all the maintenance stuff.
NoHaveMSG (05-27-2021), Stonehorsw (05-28-2021), Takumi788 (05-27-2021)
Old 05-26-2021, 04:00 PM   #196
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
This car looks amazing! Well done! Subbed.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
ML (05-26-2021)
Whiteout FRS Eric_86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 08-28-2012 11:27 AM
MT Whiteout available now... JohnATL Southeast 8 08-09-2012 01:12 AM
Another WHITEOUT in the bay.. :) tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 31 08-06-2012 02:13 AM
My new Whiteout FR-S! Flawless22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-05-2012 02:46 AM
My whiteout fr-s F3dzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-04-2012 07:25 AM
