Drives: 2017 toyota 86
Sold
I installed these and drove about 20mins less than 15miles and decided to go back to my STI mounts. Combined with trans mount insert, rear diff collar inserts, and 1pc carbon driveshaft the vibration under 2k rpm was too much for me on my daily driver. Above 2k rpm it wasn’t really different.
My loss is your gain. Can’t get any newer “used” mounts. 150$ shipped. Last edited by 86TOYO2k17; 09-19-2020 at 07:15 PM. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Joveen (07-19-2020) |
#2 |
Drives: 2013 Subaru BRZ / 2011 Lexus ISF
PM sent
The Following User Says Thank You to kevtronzero For This Useful Post: | Joveen (07-19-2020) |
#3 | |
Panda Trueno
Drives: 2014 Wrb limited
#4 |
Bump still for sale
#5 |
Drives: Bone stock
Are you NA or FI? I think that would make a difference. If have them when I get some funds I'll take them.
Sent from my SM-N960U using Tapatalk |
#6 | |
I knew the cuscos would add vibration at idle and below 2k rpm and thought I wouldn’t mind but i couldn’t do it. Above 2k rpm it’s not much different. Definitely does what it’s supposed to do. Just PM me if/when ready to buy if I haven't posted as sold yet. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Joveen (07-20-2020) |
#7 |
Bump
#8 |
Wes
Drives: 2017 Toyota 86
Heh. I have the new Perrin ones and love the extra racket, especially while redlining it and/or with ac on, but I heard the Cusco might be even more extreme
Instagram: @gt86wes
#9 | |
I was thinking about going Perrin but read/saw too many stories of failures and the bushings melting because of how close it is to the header and it doesn't have a heat shield like the other designs. This turned me off from ever wanting to use them. |
#10 | |
Wes
Instagram: @gt86wes
#11 | |
Do you have pictures of old vs new? When i see the pics of the ones for sale on the websites they look identical to the pictures i see of the melted mounts on the forums. |
#12 | |
No, my car doesn't run
Old style - https://emnotek.com/products/perrin-...yABEgLMF_D_BwE New style - https://www.rallysportdirect.com/par...iABEgJn7vD_BwE |
#13 | |
I have seen those Perrin V2 mounts, I always thought they where an even more solid version. like 1 step down from actual solid mounts. and a much stiffer option than the V1, didn't realize it was the replacement for the V1, I wonder how they compare. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | DarkPira7e (07-28-2020) |
#14 | |
Wes
Instagram: @gt86wes
Tags |
cusco, cusco engine mounts, engine, engine mounts, mounts |
FS Cusco engine mounts MO | amcp1 | Engine, Exhaust, Bolt-Ons | 1 | 11-08-2019 01:48 AM |
Cusco engine mounts | amcp1 | Engine, Exhaust, Transmission | 9 | 09-26-2018 11:11 AM |
FS: Cusco engine mounts (new) | in_sherman | Engine, Exhaust, Bolt-Ons | 3 | 08-14-2018 11:30 AM |
Cusco engine mounts | spitfire481 | Engine, Exhaust, Bolt-Ons | 6 | 05-07-2014 03:07 PM |
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 02:11 PM |
