Old 06-25-2020, 02:20 AM   #911
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
I have a Blitz. Cusco, Megan, beatrush. Most anything with a lift.
So which ones do you recommend? Cusco seem plentiful. Is there a specific model that fits. It’s mentioned at the start of this thread that the STI fits as well. Doesn’t supply the model number though..
Bodalenko is offline   Reply With Quote
Old 06-25-2020, 09:09 AM   #912
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
STI is suppose to be best but whatever you like. They are cosmetic with a little effect.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Bodalenko (06-26-2020)
Old 06-26-2020, 10:29 PM   #913
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Here is Sti's sales pitch on their flexible bars. The tS BRZ models also include flexible V-braces.
https://www.sti.jp/en/parts/feature/...etowerbar.html
The Following User Says Thank You to Kiske For This Useful Post:
Bodalenko (06-27-2020)
Old 06-27-2020, 06:32 AM   #914
grumpysnapper
grumpysnapper's Avatar
I just went with the alloy Whiteline, but had it powder coated black. Plenty of room for the Harrop.
But as was pointed out above, the existing diagonal braces do the real work...and the strut brace is less significant (on the road at least).
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
Bodalenko (06-28-2020)
Old 06-28-2020, 02:43 AM   #915
Bodalenko
Steve Bodalenko
Judging by the replies the Harrop doesn’t sit as high as I thought.I’ve settled for the basic Whiteline. If the effects are minimal I’m glad I spent as little as I did...
The Following User Says Thank You to Bodalenko For This Useful Post:
grumpysnapper (06-28-2020)
Old 06-30-2020, 07:01 PM   #916
BAT_BRZ
BAT_BRZ's Avatar
Drives: 2013 Subaru BRZ "sti"
Still pending the CARB approval letter? I saw some posts about CARB saying the order is pending but no official document like which was released for Edelbrock kit.
BAT_BRZ is offline   Reply With Quote
Old 07-01-2020, 09:57 PM   #917
Irace86.2.0
I’m sure it is delayed even more NOW because of coronavirus. Which posts are you referring to because they have been pending CARB for years?
Old 07-06-2020, 06:47 PM   #918
Irace86.2.0
I added the Edelbrock coolant reservoir to my setup. I found that even though the fill plugs were topped off when I checked, there was still low coolant levels as I circulated the pump during this install. After adding a few cups worth of coolant, all the hoses felt much firmer. I'm sure there is still some air in the system, but considering the reservoir almost ran dry multiple times, I have to believe that this will be much better. I'm surprised it was this bad considering how many times I purged the system and topped off the fill plugs. Then again, I have custom coolant lines. By the temperature of the hoses, this setup seems to be circulating coolant much better.
The bracket and reservoir were solid pieces. I did file off the Edelbrock logo. My only complaint is the lid is the type where you over tighten it, and it jumps a thread and needs retightening, which leaves someone always feeling like it needs to be tighter. If it had a stronger locking cap and if it didn't purge air to the atmosphere, and instead, had a line I could 'T' into the existing coolant overflow reservoir then that would seem best. Overall, I am happy with the addition.
grumpysnapper (07-07-2020)
Old 07-07-2020, 02:58 AM   #919
grumpysnapper
Very nicely done, looks great. The reservoir mod makes more sense to me now
Interested on why (and how) you decided to re-route your coolant hoses?
Old 07-07-2020, 03:55 AM   #920
Bodalenko
Steve Bodalenko
Strange that Harrop haven't included this in their kits. Seems like a no brainer. If you did self install you know how much coolant you used. I had Harrop install mine so hop its at the right level. A clear reservoir would make it simple. Must be a work around for us in Oz. Buying a Edelbrock one here would probably be impossible or impossibly expensive.
What size pipe is used?
Old 07-07-2020, 11:49 AM   #921
Irace86.2.0
It was aesthetics. I routed them under the supercharger to the back then they follow the same path as the Edelbrock kit. I also mounted the coolant pump next to my battery to better position the pump closer to the middle of the car. I don't know if the position of the pump or longer route of the lines is problematic, but in a closed fluid system, there shouldn't be any issue.
Harrop's routing is much more direct than mine or Edelbrock's, so maybe they figured it wasn't necessary, as there weren't any horizontal tubes in the system, so there is less chance that air is trapped in the line.
5/8 or 3/4. Whatever size is the piping that connects to the pump.
I called up Edelbrock and ordered it through them. I have no idea if they would ship internationally or what that would cost.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Bodalenko (07-31-2020), grumpysnapper (07-07-2020)
Old 07-09-2020, 02:39 PM   #922
sw20kosh
Drives: 2013 Black FR-S
Looks slick! Does the top of this bottle sit above the plane of the top of the supercharger? Wouldn't you want that since air would collect at the highest cavity in the system? I thought about replacing the fill plugs with fittings that then connected to a reservoir up near the battery.
The Following User Says Thank You to sw20kosh For This Useful Post:
Irace86.2.0 (07-09-2020)
Old 07-09-2020, 05:23 PM   #923
Irace86.2.0
Your idea would be better, and yes, ideally it would be better to have it higher than any other part of the system, which would include the supercharger.
My setup is different than stock, so it makes more sense to add this into my setup than for everyone to do this. I have the top two bleed holes and this, and it made a difference.
https://imgur.com/1SbPvd2
sw20kosh (07-09-2020)
Old 07-31-2020, 07:55 AM   #924
Bodalenko
Steve Bodalenko
Been thinking of doing similar but very difficult to get a fluid container that is identical to the Edelbrock. If you’ve found one that’s suitable would appreciate a link.
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
JDL turbo kit owners thread yomny Forced Induction 1346 08-29-2023 11:07 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
