Old 06-23-2020, 10:37 AM   #43
trinidadj
Drives: '16 FRS-MT Ablaze Red
Hey just to update everyone that the whiteline KLC180-215 endlinks worked great for fixing my sway bar and lower control arm from touching. See the pics below. I used some home made wheel cribs at all 4 wheels and adjusted the links until the pre load was gone.
trinidadj is offline   Reply With Quote
The Following 4 Users Say Thank You to trinidadj For This Useful Post:
new2subaru (06-24-2020), NoHaveMSG (06-23-2020), pslater (06-23-2020), Racecomp Engineering (06-23-2020)
Old 06-23-2020, 10:50 AM   #44
pslater
Drives: 2017 Golf R
thanks for the update! nice job on the blocks, too.
i am patiently waiting for my set of these endlinks too. they apparently an unobtanium in canada...
pslater is offline   Reply With Quote
Old 06-23-2020, 10:55 AM   #45
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Has anyone used the Hotchkis front/rear endlinks with KW based coilovers? I have RCE SS-1 and I noticed the geometry of the stock endlinks does not look correct when the car is very low. The Hotchkis endlinks are very low profile and feature stock looking bushings rather than spherical so I am interested in getting them before my next alignment, but I am not sure if they are short enough?
Old 07-07-2020, 12:16 PM   #46
pslater
Drives: 2017 Golf R
which hotchkis end links are you referring to? a quick google search for me yielded adjustable ones.
as an aside, i finally received my whiteline KLC180-215's and they worked out great. while i was waiting for them, i also picked up a set of aftermarket [BMW] E36 M3 end links, which are roughly 3/4" shorter than the stock end links; length-wise they kind of end up between the stock links and the whitelines. i didn't install them yet, but they would likely be short enough and at $45/pair they were about 30% of the cost of the whiteline units. food for thought.
Old 07-07-2020, 02:53 PM   #47
Mike_ZN6
Mike_ZN6's Avatar
I was referring to the adjustable ones. I guess my question was actually can the Hotchkis end links be adjusted short enough for a very low car with KW coils? I swear I read somewhere on this forum that somebody had to cut theirs because they were too long even in the shortest position.
Old 07-07-2020, 04:08 PM   #48
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Call them and ask how long they are and what the adjustment range is. Then compare them to the whiteline parts the rest of us are using. Whiteline lists the lengths and adjustment ranges of theirs on their website.
Old 07-07-2020, 05:01 PM   #49
Mike_ZN6
Mike_ZN6's Avatar
I actually emailed them about it a few weeks ago and they never got back to me. I guess I will need to give them a call.
Old 07-07-2020, 10:51 PM   #50
pslater
Drives: 2017 Golf R
well, you may might want to hold off on that.
i took a few minutes to google this, and someone was kind enough to leave an amazon review with some details on the length:
"These certainly are made well and easy to install and adjust, but they are barely shorter than the OEM endlinks at their shortest setting. If you're looking for shorter endlinks to address a lowered FR-S's swaybar clearance issues, I would look elsewhere."
(from: https://www.amazon.ca/Hotchkis-25445...ustomerReviews)
if the RCE SS-1 you're running has got the same body or mounting dimensions as their Tarmac 0 (which i have on my car), then you definitely want to look into the whiteline KLC180-215. i am lowered about 25-30mm from stock height and i have plenty of clearance with the KLC180-215's.
The Following User Says Thank You to pslater For This Useful Post:
Mike_ZN6 (07-08-2020)
Old 07-08-2020, 10:15 AM   #51
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
I cut the Hotchis shorter because they were too long on even the shortest position with RCE T2s and T3s.
I have used those that way with the OEM sway bar and a Whiteline sway bar.
Once cut down, they were fine.
The Whiteline endlinks were too thick for me and would contact the inner fender, because of all the camber.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
The Following User Says Thank You to sifl For This Useful Post:
Old 12-27-2023, 07:56 PM   #52
J95
J95's Avatar
Guys I'm really lost with this topic, I've read literally everything: some say you need shorter links, others say longer, others say that up to 40mm drop you can use oem ones
Please someone who is 100% sure, which length of end links I need for my setup: KW v3, oem sway bar, ~1.3"/33mm drop?
J95 is offline   Reply With Quote
Old 01-05-2024, 03:01 AM   #53
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
You do not need to change them with kW v3 / cs
Ruben_86_ is offline   Reply With Quote
The Following User Says Thank You to Ruben_86_ For This Useful Post:
J95 (01-12-2024)
Old 01-13-2024, 04:08 PM   #54
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had to change them with T2's which are V3 based
Old 01-14-2024, 07:38 AM   #55
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I know some people with V3 without those problems.
Old 01-15-2024, 02:11 PM   #56
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I guess we need to take different sway bars into account. I have the Perrin adjustable on the softest mounting point. Moving the mounting point may have also caused an issue.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
J95 (01-23-2024)
Search this Thread:
Advanced Search
ISO Front sway bar and end links vladniko86 Want-To-Buy Requests 0 05-30-2019 02:59 PM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
Need help! coilovers/sway links issue P_say86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-19-2015 08:35 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
Stance super sport coilovers with front sway bar end links 900.00 kimchangil424 Brakes, Suspension, Chassis 4 02-06-2013 02:25 AM
