05-19-2013, 04:55 PM | #1415 | |
Drives: FR-S Firestorm 6MT
What he said ^^.
But they would fit and 225/40R18 is a good size for this wheel. |
05-19-2013, 05:02 PM | #1416 |
Quick google search indicates that these wheels are actually 28.5 lbs. Even if they include the box in the weight, that is way too heavy. Find another set of wheels you like that are closer to 20 lbs or less.
05-19-2013, 06:20 PM | #1417 | ||
Baby LFA
Drives: Baby LFA
:happy0180: |
05-21-2013, 09:07 AM | #1418 |
Drives: Subaru BRZ limited WRB
Target setup:
Front - 18x8.5 +30 -> 225/40/18 Rear - 18x9.5 +35 -> 255/35/18 Questions: 1) Would they fit stock height and alignment? 2) Would they fit with 1" or 1.5" lowering, front camber... |
05-21-2013, 09:17 AM | #1419 |
Drives: 2013 86 GTS - Pegasus White
I think you'll be fine. With an offset of 30 up front, you will poke some.
05-22-2013, 02:53 AM | #1420 |
Drives: '13 Whiteout FRS
Sorry if this has been covered. Will these fit without fender mods:
17x9 +25 square on wither 235 or 245 rubber Sitting on Fortune Auto 500's and will be getting camber bolts for the rear. Currently at -1.5F -2.5R
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
05-22-2013, 09:04 AM | #1421 | |
You can add camber bolts to the front (not available on the rear) and it will give you somewhere between .5 to .75 more negative camber. For reference, here is a 9" wide +35 wheel with spring compressed to static height (suspension Eibach ProKit with camber bolts installed): |
05-22-2013, 08:37 PM | #1422 |
Drives: 5th Gen Toyota 4Runner
How would a 18x8.5 et +38 square with a 245/35x18 tire sit up front? I am on stock suspension right now but will eventually throw coils on and lower about 1" all around. I know the rear will be tucked but will I have issues up front?
05-22-2013, 09:38 PM | #1423 |
Good fitment, you will have no issues up front even with lowering or camber bolts.
The Following 2 Users Say Thank You to Slick For This Useful Post: | Overland'n'5thGEN (05-23-2013), WithNolock (05-25-2013) |
05-22-2013, 11:31 PM | #1424 |
Drives: frs
sorry if this is already been covered but i bought a set of xxr 530 in 18x8.75 +33 and looking for tires. i was planning to go with 225/45/18 fronts and 245/40/18 rear and keep car STOCK height, which is why i went with bigger profile. i was told this could cause rubbing issues and i should go 225/40/18 and 245/35/18, is this true and will my initial tire size fit? i want to cover up as much wheel gap/wheel well as much as possible on stock height. thanks
05-23-2013, 12:19 AM | #1425 |
Drives: nissan frontier, DGM MT BRZ
Wheel 17X8 +45 i know will fit tire that the guy has on 235/45/17 i would have to replace the tires right?
05-23-2013, 09:08 AM | #1426 | |
Stick to the closest diameter to the OEM size and gearing will not change as a result, so yes, 225/40R18 for front and 245/35R18 for rear will get you almost perfect diameter. Not sure if there is a reason you are running staggered tires, you could run the same tires front and rear if you have the same wheels and offsets. Even a 245/35R18 all around will not rub on stock suspension. This is an ideal tire size for that wheel width, unless you like the stretched look. |
05-23-2013, 09:20 AM | #1427 | |
Not sure I understand your question. Your stock tires will fit on these wheels, with a bit of stretch. If you are buying wheels and they already have 235/45R17, (I think is what you're asking) they will fit although they are taller, and it will alter your gearing by 2.8% (you will be travelling 2.8% faster than your indicated speed). But it will affect your acceleration more because of the gearing, which is not a good thing (unless you don't care about it). But they will fit and not rub. Better tire size would be 245/40R17 which is almost exactly same as stock. |
05-23-2013, 09:23 AM | #1428 |
Drives: FR-s
I am going for stance look so does anyone know if a 18x9.5+20 front and 18x10+15 has ever been tryed i know i will have to do a fender pull in the fornt and rear with some camber. can anyone suggest some tire sizes for me i was thinking like a 225/35 front and rear any suggestions ?
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
