BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
03-15-2012, 09:47 PM | #71 |
Drives: '06 AM V8V Coupe
I think electronic stability control stuff only corrects after it detects slip, so if you get stickier tires then the intervention just kicks in later.
03-15-2012, 09:49 PM | #72 |
Drives: Lightning Red BRZ MT Limited
Hope that's the case cuz I'm planing to change to high grip tires due to road conditions
03-15-2012, 10:42 PM | #73 | ||
Drives: 1998 Toyota Altezza RS200
Despite our miscommunications I pretty much agree with what you`re saying. On an accelerometer a driver trail braking isn`t going to have a wider grip circle than one who only brakes in a straight line. The only way to change that is to get better tires (assuming your setup makes the best use of the ones you`ve got. The difference is just how you use the available grip of the tires. All I am saying is that it is a better use of the available grip of the tires to combine longitudinal and lateral forces when possible and practical because that will produce better lap times. As for why, that is what I have been trying to illustrate above. Quote:
03-16-2012, 12:28 AM | #74 | |
Drives: 4 Wheels Auto
Just to chime in w.r.t. the "squash" circle. In order to fill in the top portion of the circle, you need to accelerate fully while making small steering angle. Would it be the case because this scenario does not happen frequently on a track? Thinking like a long radius curve with a bank or something so that you can keep accelerating.
03-16-2012, 12:57 AM | #76 |
Drives: pos
03-16-2012, 02:40 AM | #77 | |
The car in question used to make that plot was an AWD Talon with about 350 whp and racing tires, and the plot was taken from a ProSolo competition (basically autocross with a drag style start). The biggest factor is the tires; expensive racing tires provide an obscene amount of grip and although it`s comparatively easy to go into a corner faster to use the lateral grip, it takes a LOT of power to make use of all their longitudinal grip under acceleration. So to start us off, the top of the `stem`comes from hard straight line acceleration aided by AWD at the beginning, and the points below illustrate how longitudinal force (that feeling of being pushed back in your seat under acceleration) tapers off as the car gains speed. It`s for this same reason that the graph appears smushed on top. If the car had enough power you`d expect it to follow half of the grip circle, from bottom to top, through the course of taking a given corner. At entry you`d begin with maximum braking, transition to trail braking as you approach the apex, achieve max cornering grip crossing the apex, then transition into acceleration as you unwind the wheel towards the exit. At every point of a corner you are creating some combination of lateral and longitudinal force and further than that, you are creating them in proportion to each other. You increase steering angle which in turn increases lateral force as you release brake pedal pressure while trail braking, decreasing longitudinal force. After crossing the apex you do the opposite; add throttle and thus longitudinal force in proportion to how much you`re unwinding the wheel which reduces lateral force. What this means is that if you`re driving well (read: smoothly) you would expect there to be a roughly equal amount of points all around the perimeter of the grip circle which represent the different phases and your smooth transition between them of every corner on the track. On a normal non-autocross track there`d probably also be a disproportionate amount of dots on the positive side of the Y axis that represent accelerating on straight sections which is where you spend most of your time. The reality however is it takes more power to `fill in` that top area of the plot than most cars have. The smushed area then represents where the car could not produce enough longitudinal grip to follow the perimeter of the circle. This is certainly not the fault of the driver as the plot plainly shows he was driving to the best of the car`s ability, but rather is the result of a lack of power. In such a situation all you can really do is give it max throttle and adjust your steering/lines so you`re using as much cornering force as possible in combination with the power the car can produce, and this is what causes the plot to look smushed. Now you do have a point as well. If a track were designed predominately with strange increasing radius turns and the such you might end up with an equally strange accelerometer plot showing a driver that went from full lock to straight line acceleration. I think it`s likely that given such a situation the driver would find the best lap times by finding a way to use the rest of the grip circle though. Last edited by Corey; 03-16-2012 at 02:54 AM. |
03-16-2012, 09:44 AM | #78 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
03-19-2012, 12:38 AM | #79 |
Drives: Dark Gray BRZ Premium MT
My BRZ will be a year round car, but I expect most of my miles to be put on in the winter since I am mostly on a motorcycle in the summer. I almost bought a WRX: when I discovered the BRZ, I started thinking of all the great times I had in my s13 primarily because it was RWD.
As others have said, RWD + snow tires = lots of fun. The winter is when I do my drifting - I don't like the speeds required to drift on dry tar on public roads. In the snow is actually where I learned how to handle a RWD car. My advice is to embrace some RWD driving time in the snow - just go somewhere without people or telephone poles or curbs or deep ditches or... Then just play with caution. You'll probably learn a lot. I've driven through all sorts of snow in FWD and RWD cars with all sorts of tires. I highly recommend snows! In fact, I don't plan on going through a MN winter without them again, because it makes such a huge difference in how safe and confident feel. I can't say about whether you should bother with snows in VA though, but summer tires (or bald tires) in the snow is a disaster. |
03-19-2012, 04:05 AM | #80 | |
Because compromise ®
Drives: Red Herring
03-20-2012, 09:10 AM | #81 |
FWD cars reduce oversteer with acceleration, not understeer. The reason FWD cars are notorious for understeering mostly has to do with the fact that they use the front tires for both accelerating and turning. Combine that with the fact that the laws of physics are working against them (accelerating shifts weight off of the drive wheels) and you have a pretty poor formula for traction. This is why FWD autocross cars usually "point and shoot" by running really stiff rear springs to rotate the car in the right direction and lessen weight transfer to the rear so they can just accelerate in a straight line.
03-22-2012, 09:50 AM | #82 |
Drives: '95 Honda Civic HB/'13 Subaru BRZ
BRZ is going to be my daily driver while I redo my Civic for shows again... but I'll probably do simple mods on BRZ (always had that tuner itch).
Just don't go driving crazy and it'll be fine in snow... as long as it's not too high, that is. My Civic is a pain in snow only because of height and the city not plowing... I plan on getting a set of rims and tires for winter anyway... and another set for summer and/or show. |
Tags |
brz, daily driver, snow |
Similar Threads | ||||
FT-86 -- daily driver, weekend car, or garage queen? | My86 | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 05-28-2012 12:28 AM |
Good sporty daily driver? | Staticz | Scion FR-S / Toyota 86 GT86 General Forum | 80 | 03-01-2012 04:20 PM |
Comfort and daily driving - Should I go with a sports coupe? | Undecided | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 03-01-2012 02:17 AM |
The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 01:14 PM |
