Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 04-24-2018, 12:30 PM   #57
jubella2
jubella2's Avatar
Drives: DGM BRZ
Wow, COTA really put your car through some abuse!
jubella2 is offline   Reply With Quote
The Following User Says Thank You to jubella2 For This Useful Post:
Code Monkey (04-24-2018)
Old 05-10-2018, 05:31 PM   #58
Code Monkey
Drives: Subaru BRZ
Whiteline camber bolts went back in, got an alignment, and bled brakes and clutch.
-3.6 camber in front, rear camber is what it is because I can only change it in 0.5 degree increments with the UCA, still should work well.
Code Monkey is offline   Reply With Quote
Old 05-24-2018, 05:10 PM   #59
Code Monkey
Drives: Subaru BRZ
Is this too much lean? I feel like sway bars are in order.
The Following User Says Thank You to Code Monkey For This Useful Post:
Tristor (05-25-2018)
Old 05-31-2018, 03:52 PM   #60
Code Monkey
Drives: Subaru BRZ
Flex Fuel kit installed.
Old 05-31-2018, 05:27 PM   #61
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: 2013 Whiteout FR-S
Can you post up some more pics that show how you routed the fuel line? Looks like you came up with a different way to do it that keeps it further away from the engine.
Originally Posted by humfrz
I'm old and lazy
Code Monkey (05-31-2018)
Old 05-31-2018, 09:07 PM   #62
Code Monkey
Drives: Subaru BRZ
Good eye for detail!
I did not like the suggested routing around the abs unit for the long fuel line so I routed it under the abs unit. First, I put some expandable braided sleeving on the fuel line, then wiggled the line through. No rubbing anywhere as far as I can tell but when I change wheels for the track, I will pull the wheel liner and see if I can add a rubber loop clamp to hold the line further.
Clipdat (05-31-2018)
Old 05-31-2018, 09:48 PM   #63
Clipdat
Proud of BOXER
Clipdat's Avatar
Looks great, thank you so much for the additional pics. Great job routing it, and that nylon sheath looks like it'll add another layer of protection from abrasion/friction.
I'm still not totally content with mine that's using the suggested/default routing, but I went for a drive today and then popped the hood and touched the line at it's closest point to the engine, and it didn't even feel warm/hot to the touch. I still might put a reflective gold jacket around it for peace of mind.
Thanks again.
I'm old and lazy
Old 06-08-2018, 10:20 PM   #64
Code Monkey
Drives: Subaru BRZ
Finished e85 tune (green and blue curves, the red curve is 93 octane).
Old 06-10-2018, 08:45 PM   #65
Code Monkey
Drives: Subaru BRZ
Installed Hotchkis 25mm front sway bar, Hotchkis 19mm rear sway bar, and Hotchkis rear endlinks. I have the front sway bar on the soft setting, and the rear on the second soft setting. Aimed for a 3/8" rake with the right side a bit taller than the left side to account for drivers weight, pinch weld heights:
Code:
4.66    4.52
5.02    4.88
Changed the transmission fluid while the whole car was up on platforms (10,069 miles).
Old 06-21-2018, 10:32 PM   #66
Code Monkey
Drives: Subaru BRZ
Another oil change (10,190 miles) in preparation for the upcoming two hpde's. Also changed the diff fluid.
Old 06-21-2018, 10:39 PM   #67
Code Monkey
Drives: Subaru BRZ
Pulled the fender liner to see if the flex fuel line was rubbing anywhere. Did not notice anything problematic but secured the line with a p-clamp just in case it moves too much during hpde.
Old 06-25-2018, 08:31 AM   #68
Voltwings
Drives: In the market for an 86 twin
Did you find out what was making the squeak on Saturday?
Voltwings is offline   Reply With Quote
Old 06-25-2018, 08:33 AM   #69
Code Monkey
Drives: Subaru BRZ
Never heard the squeak again, something random, I guess. I will check all the nuts and bolts under the car just in case before I head out to MSR Cresson.
Old 06-25-2018, 02:48 PM   #70
Voltwings
Could it have been your pads, or was it not that kind of squeak? I noticed you and Joe were both making a little noise on decel when they brought yall into the hot pits.
Search this Thread:
Advanced Search
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 04:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 08:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 06:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 05:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 10:53 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
